Won't downshift at full throttle? - JeepForum.com
post #1 of 21 Old 05-06-2012, 08:06 PM Thread Starter
jeep04
OK so here's the issue,,, I had installed a cheap DIY cold air intake and a classic chambered power stick exhaust and it seemed to run great, but then I noticed when I floored it the trans wouldn't down shift.
So I figured at 75k maybe time for my third tune up, I changed the plugs, fuel filter, PCV valve and every fluid the jeep has. I also put the factory intake back on, but still wouldn't kick down.
Could this be related to the open style exhaust causing a loss of back pressure?, its coming off anyway as soon as I get a super 44 as the power stick sounds good but way to loud.
04 Jeep wj Limited 4.7 <> 6.5" Iron Rock long arms front & Adjustable lowers on rear <> Bilstein 5100's <> 285/70r17 Goodyear Duratracs <> M/T black classic lock wheels <> Addco swaybars <> Superchips 3875 <> Magnaflow Stainless exhaust <> 2 Kicker comp 12's <> Kenwood head unit.
jeep04 is offline
post #2 of 21 Old 05-06-2012, 10:14 PM
pinky2252s
Do you have the I6 or V8? (Im on my phone so no profile details). I have a CAI, and no muffler. It hasnt affected my shifting. But, it could be a back pressure problem. Im just not sure where. Is everything tight and secure for the CAI?
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #3 of 21 Old 05-06-2012, 10:15 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
The Jeep will still downshift at full throttle with open headers... Just don't ask how I know So I don't think back pressure is your problem.
In the garage: M1 4bbl
McCloudsZJ is offline
post #4 of 21 Old 05-06-2012, 10:32 PM
Jeepgcl9947
I have headers, no catalytic converter with a flowmaster 44 and I'm have the same trouble so maybe it is open exhaust. Time to put cats back on!
Jeepgcl9947 is offline
post #5 of 21 Old 05-06-2012, 10:34 PM
pinky2252s
Agreed, the engine has to have some back pressure. As a suggestion, get a flow master free flowing cat. I dunno if you need the pre cats, but having a big cat will create some back pressure.
Is it broken?
post #6 of 21 Old 05-06-2012, 10:36 PM
Jeepgcl9947
Can I add a cat but keep it loud? I love how loud it is now and I think adding a cat will quiet it up a bit.
post #7 of 21 Old 05-06-2012, 11:28 PM
pinky2252s
It might quiet it some, but its the least restrictive that you can get and still retain some back pressure. Honestly, I have all 3 stock cats, no muffler and a CAI, and my exhaust is pretty darn loud. Backfires some too.
Is it broken?
post #8 of 21 Old 05-07-2012, 03:28 AM
kfxnando
spot on.
maybe rather have a look at a throttle position sensor and it wiring for reason for not down shifting
cats have no influence on the down shift
good luck
maybe also disconnect and recollect the battery to give every thing a reset
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #9 of 21 Old 05-07-2012, 07:07 AM Thread Starter
jeep04
I still have the factory pre cats, mine never had the big cat and as said above the cai is off.
So either the powerstick or the tps sensor as kfxnando suggested, i dunno i do know its annoying when merging.
Thanks for everyones help so far
jeep04 is offline
post #10 of 21 Old 05-07-2012, 07:56 AM
narnwv
narnwv's Avatar
what about the kick down cable?
~Aaron
narnwv is offline
post #11 of 21 Old 05-07-2012, 09:10 AM Thread Starter
jeep04
is this located on the trans somewhere, could it have failed somehow or stretched?
jeep04 is offline
post #12 of 21 Old 05-07-2012, 09:36 AM
kfxnando
was thinking about this, and remembered that there is a earth strap on the exhaust close to the cat at the bottom, that earth also goes to the gearbox, seeing that someone worked on the exhaust, maybe that is missing or loose or damaged
apparently these jeeps are very sensitive to minor electrical issues
good luck
kfxnando is offline
post #13 of 21 Old 05-07-2012, 09:49 AM
seu83
I don't exactly where on the 4.7 but it should be attached to the throttle body and the adjustment should be up top near where it connects. Again I'm not 100% sure this is the case for the 4.7.
seu83 is offline
post #14 of 21 Old 05-07-2012, 10:24 AM
kfxnando
self am under the impression that these jeep don't have kickdown cables, me thought that it all happens electronically
depending on signals from the map sensor and tps, rev and speeds
could be wrong
kfxnando is offline
post #15 of 21 Old 05-07-2012, 10:37 AM
04Overland47
04Overland47's Avatar
could be wrong
You are right, the 42re trans have the kickdown cable but the 545rfe is controlled electronically.
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
2002 WJ Overland 4.7HO
04Overland47 is offline
bogging down,loss of power under full throttle seancy85 WJ Grand Cherokee Forum 8 07-27-2013 05:37 PM
42re no 1st 2nd, no downshift tom2001wj WJ Grand Cherokee Forum 3 12-03-2011 03:51 PM
Runs Rough After Full Throttle psychobike WJ Grand Cherokee Forum 3 11-18-2011 08:02 AM
Late downshift to 1st when stopping. machbuffet WJ Grand Cherokee Forum 4 06-07-2011 08:04 PM
Won't Downshift at stop snow2surf WJ Grand Cherokee Forum 12 05-25-2011 01:51 PM
