Wobbling when applying brakes when going ~100KM/hr - JeepForum.com
post #1 of 20 Old 06-18-2013, 11:48 AM Thread Starter
steve_80
For a little while now, when I'm on the freeway going around 100 KM/hr and apply my brakes softly, my steering wheel wobbles left and right about 1-2" either way.
The jeep of course wobbles as well and it scares my wife quite a bit since the 2 kids are in the back.
What is causing this? A warped rotor? Should I replace this ASAP? I had my rotors and calipers replaced over 5 years ago.
The 2000 WJ has 158k.
steve_80 is online now
post #2 of 20 Old 06-18-2013, 12:30 PM
1ATony
Vendor
1ATony's Avatar
If I had to bet is sounds like a warped rotor to me. If you need them we now ship internationally. Here's a link to them on our website for your Jeep.
Jeep Grand Cherokee Brake Pad & Rotor Kits
SHOP HERE FOR AWESOME
1ATony is offline
post #3 of 20 Old 06-18-2013, 01:39 PM Thread Starter
steve_80
So many to choose from! How do I know which to get? I wouldn't mine getting the better type of calipers (teves vs akebono).
post #4 of 20 Old 06-20-2013, 07:25 PM
JeepDrew_94
I am experiencing the same thing. 2000 WJ 110,000 Miles. Also got a lil bit of a squeaking noise when I hit a bump or pot home. Worse in the morning.
JeepDrew_94 is offline
post #5 of 20 Old 06-20-2013, 07:28 PM
lazyWJ
2006 XK Commander
I found the easiest fix was to remove the wife and kids.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #6 of 20 Old 06-21-2013, 03:41 AM
cykaaro
I would as well, check your track bar and front control arms for bad bushings. Going over 80km when I brake harder, feels like my rotors are warped, but they aren't. My lower control arms still need replacing. (tops done, lowers waiting to get in, which causes it) Any time I've had warped rotors I usually feel it easily anywhere above 60km.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #7 of 20 Old 06-21-2013, 06:52 AM
georged
That sounds like a Chrysler solution to our gas tank concerns!
georged is offline
post #8 of 20 Old 06-21-2013, 08:27 AM
lazyWJ
2006 XK Commander
2004 Imola BMW ZHP
"Bought, Not Built"
lazyWJ is offline
post #9 of 20 Old 06-21-2013, 09:02 AM
maloj2003wj
2006 WK
I bet one of your front calipers is sticking. Upgrade to akebono and replace your brakes. Worked like a charm for me. Had the exact same issue between 50-40mph.
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #10 of 20 Old 06-21-2013, 09:23 AM
RIPNBST
Warped rotor. I got stoptech rotors and love them.
RIPNBST is offline
post #11 of 20 Old 06-21-2013, 11:00 AM
elcorvino
2003 WJ
I had the same exact problem and TJSWJ was nice enough to help me out yesterday.
My caliper was sticking, and it almost certainly seemed like the reason was brake related, but upon removing my front axle - the bushing on my axle was shot.
elcorvino is offline
post #12 of 20 Old 07-02-2013, 09:57 AM Thread Starter
steve_80
If I take a front wheel off, how can I check to see if the rotor is actually warped? Is there a tool I need or will it be obvious?
Also, I went on a road trip over the long weekend and the steering wheel shook so violently that the wheels wobbled back and forth (with clunking) and I felt like I was going to drive off the road (it actually scared me, and I dont scare easily). Weird thing is, it happens randomly when braking at high speeds.... some times it happened, sometimes it didn't.
Could this still be a warped rotor?
post #13 of 20 Old 07-02-2013, 10:47 AM
Robertc2012
You could be suffering the death wobble induced by a brake problem.
Robertc2012 is offline
post #14 of 20 Old 07-02-2013, 02:52 PM
RIPNBST
What you are describing is what we in the Jeep community refer to as the "death wobble."
RIPNBST is offline
post #15 of 20 Old 07-02-2013, 03:17 PM
cykaaro
Yep. Warped rotors will give you pulsation. There's no tool that I know of to use, but you can definitely feel them when you brake if they are. As for getting death wobble? Look for and replace worn steering parts for starters.
cykaaro is offline
