WJ's in deep - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ's in deep
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 07-08-2013, 01:15 PM   #16
Double E
2000 Laredo V8
Double E's Avatar
Testing how far till the sand drops to soup...
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 07-08-2013, 05:38 PM   #17
alfaitalia
CRD Pilot!
alfaitalia's Avatar
No pics but im happy to take mine in to the top of the cladding and have done many times with no water getting in axles or interior. In last years floods I accidentally had water over the bonnet (ok hood!) but managed to keep going fast enough to form a good bow wave. No after effects except the alternator would not charge for a couple of miles until the water drained out of it!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline   Reply With Quote Quick reply to this message
Unread 07-08-2013, 11:44 PM   #18
zephyr80
Here's mine
Sent from your back seat!!!
zephyr80 is offline   Reply With Quote Quick reply to this message
Unread 07-09-2013, 12:14 AM   #19
silentbob21
not too deep here... but there are more pics of a much deeper hole I just dont have them
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 09:17 AM   #20
rcwj04
Just a tad bit deep, ended up with water seeping through the door seals.
[CENTER][COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Green"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #744[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR][/CENTER]
[QUOTE]You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
[/QUOTE]
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
[FONT="Century Gothic"]2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)[/FONT]
rcwj04 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 09:39 AM   #21
bugaboots
I dont think that i would want to try that with mine being a gasser. Now if i had the diesel like you, that would be a different story.
1995 Cherokee 4.0 Stock(for now)
2002 Grand Cherokee Sport, OME HD lift, Bilstien 5100's, 63mm Bored t-body, IRO 2.5 exaust, 245/75/16 Revo2, Front tow hooks, 4.6L long rod stroker, Factory Jeep brush gaurd
bugaboots is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 10:35 AM   #22
JayhawkADV
Oh no SALT water!!!
JayhawkADV is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 07:28 AM   #23
MattG60
Originally Posted by 85IrocZ-28 View Post
No snorkel here, just launching the boat about 150 feet offshore:
Bear Lake has areas that very gradually slope down into the lake, and you have to back pretty far out.
this is an amazing photo. I would be very tempted to drive a little fast out of that spot.
MattG60 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 11:58 PM   #24
Olese
Soooo close! I was doing okay until my front end dropped into a hole (I guess that I should say a hole in a hole!). The front was about a foot and a half lower than the back. As the interior filled, the tow strap that we had broke. We had to bail water until my friends could get back with another strap. My son was in the back seat bailing water until they returned. If he hadn't been bailing, it would have reached the fuse box!
Olese is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 12:04 AM   #25
Olese
That is awesome!!!
Originally Posted by Morphine View Post
My Old green WJ in Water
Unread 07-14-2013, 06:35 AM   #26
Notabene
Just this morning...My first time.
This isn't deep, but I was stuck on the axle for long enough, while I sorted the winch recovery, to swamp inside. Amp is fried, that's all so far. Stripped out the interior and dried it out. Left carpet out until it dries. Probably take a few days. It's very thick and heavy.
It got to here at the worst point.
Notabene is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 09:51 AM   #27
zephyr80
Well with my brilliant deduction of the steering wheel and keys being on the wrong side of the car, that puddle gave you a soggy bottom!!!
Unread 07-14-2013, 05:13 PM   #28
RIPNBST
So much for that snorkel. By the looks of it if you were ever in deep enough for your motor to need a snorkel you'd likely need one too.
RIPNBST is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 07:26 PM   #29
04dubjay
I'd never subject my dub to this! Youre all crazy! lol
2004 Columbia Edition WJ (I6/Selectrac) -{RC/Ironman4x4fab/JKS/KOR/Nitto/Carolina}
04dubjay is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 07:59 PM   #30
zephyr80
I always poke puddles with a stick before i drive in
