WJ Y-Link - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ Y-Link
Engo LED Flush Mount Lights *PAIR* Flood or Spot 1,600 LumYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 08-14-2014, 01:15 PM   #1
offroadGR4ND
Wj WJ Y-Link
Hey guys I'm looking for new rear upper control arm bushings on the ends of my Y-link. I'm curious as to if I should pay the $50 a pair on the heavy duty Mopar bushings or would I be fine to purchase regular $14 bushings? I know the obvious answer is the heavy duty but it seems most people just buy the regular ones, even with lift.
99' WJ 6" Lift, 33" Hercules. JKS quick discos, JKS adj. track bar, roof rack.
offroadGR4ND is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 01:46 PM   #2
MuddyWJ
Mopar!! Anything else seems to wear prematurely. I've got a brand new set if your interested. Going to an adjustable arm from endless mountain Fab. PM me for details.
MuddyWJ is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 01:51 PM   #3
Tollmtn
X2 on what Muddy said. Put another way..... Your Mopar bushings lasted 15 years. If you install Crown bushings over the next 15 years you may replace them 15 times. If you use Dorman they will last longer than Crown but NONE of the aftermarket bushings will last like Mopar bushings.
Tollmtn is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 02:54 PM   #4
birdie127
or go with Endless mountain fab. His design looks promising and he is getting ready to make a new batch, one for me too!
http://www.endlessmtnfab.com/
birdie127 is online now   Reply With Quote Quick reply to this message
Unread 08-14-2014, 03:01 PM   #5
offroadGR4ND
Sounds good looks like I'm going with the more expensive Mopar, but hey if you wanna play you gotta pay
^ And that design does look very promising. I'd like to see it in action!
Unread 09-29-2014, 08:08 PM   #6
birdie127
their doing another group order...
