WJ + XJ Rotella T5 10w-30 vs. Mobil 1 high mileage vs. Castrol high mileage. - Page 7 - JeepForum.com
post #91 of 117 Old 04-02-2013, 03:47 PM
KayCeeJeep
Originally Posted by billzcat1 View Post
KayCee - I'd be really interested to see your UOAs with Castrol HM. With its low-zinc formula it will be interesting to see how it treats you in the 4.0.
This is an old thread but I remembered it, I had said I'd post a UOA of Castrol HM when I got one. Well I've got one and I am underwhelmed to say the least.
This is why you do UOA's, my 4.0 ran so smooth and quiet on the Castrol HM I was totally sold. But the UOA shows I can do better. UOA's are a great tool, I also learned my use is much closer to severe use than I would have guessed. So I'm cutting my OCI's back. The scary part is I ran the same stuff a full 5k without a UOA prior to this.
This was a winter blend of 5w20 and 5w30 that should have resulted in a standard 5w30, the original kv@100 was about 10.5. The moly is coming from a full can of MoS2 which I also added to the brew. I will not be using that any longer as it's not cost effective for shorter OCI's.
KayCeeJeep is offline
post #92 of 117 Old 04-02-2013, 05:01 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I'm curious - what are you trying in lieu of the Castrol? (now that you are no longer impressed by it).
That UOA isn't all that bad for a 4.0 though.
~Richard
billzcat1 is offline
post #93 of 117 Old 04-02-2013, 06:48 PM
KayCeeJeep
I refilled with the Quaker State Defy. Added another can of MoS2 since it was my last one but I'm probably done with that. I'll be fiddling with some proven low cost performers in the future, Rotella, Maxlife, PYB, and Quaker State. I have some expensive Edge I bought on BOGO but that's the only way I'd run something like that.
I agree it's not a "terrible" UOA but I've seen plenty better so I have something to work toward. It appears the engine is healthy but this oil was clearly not optimal. My Jeep buddy on BITOG ran Pennzoil Yellow bottle 5w30 simultaneously for the same miles and he had less shear and wear numbers that were only 1/3 to 1/2 of what I got. I believe a lot of the wear numbers here were because the oil dropped to a 20 grade, so a heavier Castrol HM would likely do better but I'm out of it and not buying anymore, they changed the formula anyway so I'd be starting over again.
post #94 of 117 Old 04-02-2013, 08:23 PM
86cj74.2L
86cj74.2L's Avatar
Have you thought about the Rotella T6?
I run it all year round in the 4.2l in the CJ. And their all but the same engine.
86cj74.2L is offline
post #95 of 117 Old 04-02-2013, 08:42 PM
KayCeeJeep
T6 is very popular for good reason I know, never tried it I've run the 10w30 versions of Rotella, the T6 seems a little rich for my blood. Delo has a full syn 5w40 now that is a couple bucks cheaper though.
I'd have it on my "someday" list but I've probably got at least 2 years worth of oil as I type this that I need to get through.
post #96 of 117 Old 04-03-2013, 03:00 PM
billzcat1
2003 WJ
The add packs and TBNs between Rotella (base), T5, and T6 are pretty much identical. The difference is dino\semi-syn\syn. The only one I've seen locally in the 10W-30 weight is the T5.
~Richard
post #97 of 117 Old 04-03-2013, 04:05 PM
86cj74.2L
86cj74.2L's Avatar
Walmart sells the T6. And TSC (tractor supply center) sometimes has it on sale for 19 dollars.
I use the T6 in everything but the 4.7l
post #98 of 117 Old 04-04-2013, 07:08 AM
ChrisHager
Administrator
ChrisHager's Avatar
I feel like this has come up before and I may have been proven incorrect but isn't the T6 only offered in 5W-40?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #99 of 117 Old 04-04-2013, 08:44 AM
KayCeeJeep
You are right you can't tell the difference between dino Rotella and T5 from a UOA/VOA, base stock is the only difference add packs are clones.
Wally's has T5 reasonable, $16 bucks a jug, I usually run Rotella T dino 10w30 though which I can get here from AAP or O'Reilly's on sale for about $13 bucks a jug. Napa has it too but never on sale and they want more for it than Wally's does for T5.
post #100 of 117 Old 04-04-2013, 08:46 AM
KayCeeJeep
You are right T6 is a 5w40 AFAIK but it's a full syn with good flow, and a light 40 grade anyway, so a lot of guys use it with good success.
post #101 of 117 Old 10-10-2013, 08:38 PM Thread Starter
02grandy
Wj
switching to Valvoline 10w-30 high mileage syn blend from walmart. will be changing in about a week
http://www.walmart.com/ip/Valvoline-...1-Qt./15125757
02grandy is offline
post #102 of 117 Old 10-10-2013, 08:50 PM
WJ2000
I've been using T6, works fine for me !
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #103 of 117 Old 10-11-2013, 04:51 AM
dlundblad
2003 WJ
Originally Posted by 02grandy
switching to Valvoline 10w-30 high mileage syn blend from walmart. will be changing in about a week http://www.walmart.com/ip/Valvoline-...1-Qt./15125757
I've been referring to this thread a lot these last few weeks. Have you tried mobil 1 high mileage? Now that stuff makes my jeep run quiet.
03 WJ Laredo 4.Sl0w
2" BB, Overland Skids
2nd set of 245/75/16 DuraTracs
dlundblad is offline
post #104 of 117 Old 10-11-2013, 07:40 PM Thread Starter
02grandy
really I think I tried that for awhile and was making it loud lol
02grandy is offline
post #105 of 117 Old 10-11-2013, 09:27 PM
dlundblad
2003 WJ
Our jeeps seem to be polar opposite then. I should give T5 and T6 a try. Lol.
How's the Valvoline HM going for you? What's the zddp content?
03 WJ Laredo 4.Sl0w
mobil 1 for high mileage suv djoy WJ Grand Cherokee Forum 37 06-30-2011 09:39 PM
Would you buy this High Mileage? xJoshxx WJ Grand Cherokee Forum 8 06-27-2011 07:41 PM
High Mileage Oil xbucux WJ Grand Cherokee Forum 6 03-07-2011 09:07 PM
High Mileage Points of interest jjfrieze WJ Grand Cherokee Forum 8 01-17-2011 12:55 PM
what oil to use in a high mileage jeep with ticking?? flandaz13 WJ Grand Cherokee Forum 12 01-04-2011 12:37 AM
