WJ + XJ Rotella T5 10w-30 vs. Mobil 1 high mileage vs. Castrol high mileage. - Page 4 - JeepForum.com
post #46 of 117 Old 11-14-2012, 09:23 AM
KayCeeJeep
Originally Posted by blackjeep05 View Post
I have a 98 with 260k and it has only had regular castrol the first 150k then the maxlife life the other 110k with no problems. People stress to much about ZDDP and truth be known 1992 ZDDP was only at 1200 and by 1996 was only at 900 to 1,000 so if it were that big of deal we would see several thousand 4.0s with problems. Not the case.
I agree, I've spent hours reading Jeep 4.0 UOA's and ZDDP, while definitely not a bad thing, doesn't seem to make a lick of difference in wear numbers.
KayCeeJeep is offline
post #47 of 117 Old 11-14-2012, 10:32 AM Thread Starter
02grandy
02grandy's Avatar
calebj stick with castrol or valvoline high mileage 10w-30 its quiet and running great dont change a thing. thats what im gonna be running from now on and sticking with it. everything i heard on the web says once you go with high mileage oil you have to stick with it because it swells up the seals and keeps then nice and blump lol. the overall idea is just to make sure your have clean oil and the right oil. dont get all fancy. also i do wix filters dont know about those pures
02grandy is offline
post #48 of 117 Old 11-14-2012, 10:38 AM
cherokeekid58
I usually run Rotella 10w-30 with a mopar filter. My question to you folks is, has anyone tried Zmax oil and gas addatives. Or should i just do frequent oil changes to clean the engine out? I think i might have some build up on the compression rings.
[QUOTE=sonoran_Tj
"If we collect data long enough, we may discover the root psychological cause for the "jeep thing".
So far it seems correlated to OCD and the need to look at one's poop."
cherokeekid58 is offline
post #49 of 117 Old 11-14-2012, 10:42 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Go google "zMax lawsuit" and tell us if you still think it's worth using. (THE ANSWER IS NO)
~Richard
billzcat1 is offline
post #50 of 117 Old 11-14-2012, 10:45 AM
blackjeep05
Man honestly, I would just use a good oil like Castrol or Valvoline and change it every 3k with a good filter like Wix are Purolater. If Zmax was that good oil companies would use it. Carrol Shelby got big bucks to talk about Zmax. 20 bucks a pop for 12 0z of product is a rip off. I know its suppose to soak into metal and all but, your motor oil does the same thing. Engines use oil some more than others so there gimmick of saying soaks into metal unlike regular oil is bs. All engines use a little oil some more than others otherwise some of you parts would not get the proper lubrication like the upper part of your oil control rings and such.
Soccer six in the mix.
blackjeep05 is offline
post #51 of 117 Old 11-14-2012, 10:46 AM
65novalt1ss
Billzcat am i correct that you run t5 5 w30? All i find here is 10w30. Thinking of running t5 in a 4.7 but didnt know if the 10 would be ok.
65novalt1ss is offline
post #52 of 117 Old 11-14-2012, 10:53 AM
blackjeep05
Use that 20 bucks and buy yourself another oil change with it. If you suspect you have build up I would either change it every few tank fill ups until it was clean or pull the oil pan to look and see and if its dirty clean it by hand. Other than that your not going to be able to do any better.
post #53 of 117 Old 11-14-2012, 10:54 AM
blackjeep05
As long as you stay away from Pennzoil and Quick Mistake I think you will be fine.
post #54 of 117 Old 11-14-2012, 12:30 PM
cherokeekid58
Are wix filters better than mopar filters?
[QUOTE=sonoran_Tj
post #55 of 117 Old 11-14-2012, 12:41 PM
blackjeep05
Well about the same. I prefer Purolater over both but, you have to be careful with Mopar because they are always changing vendors. I remember a while back they were using Fram and I think they have since then gone back to Purolater but, you never know what's going to happen. I just get the Purolater's from Wally World.
post #56 of 117 Old 11-15-2012, 08:25 AM
KayCeeJeep
Dude that's urban legend from like 40 years ago, get over it! Today's Pennzoil is one of the best conventionals on the market and there's nothing wrong with Quaker either although a few dollars will get you better.
And 3k oil changes should be dead, anything decent should be able to do 5k unless you are TRULY under severe service (very few people are).
Purolators are very good filters, Motorcrafts are made by Puro but have better features for almost the same price, my favorite "value" filter by far, Mopars have been Puro's like Motorcrafts for a while now but they cost more for some unexplained reason.
post #57 of 117 Old 11-15-2012, 09:30 AM
Upside
I drive about 60% highway and am about to do an oil change on my T5 10W30. It has about 7500 miles on it with a larger filter and I plan on having the analysis done.
Unfortunately I get some cold start valve train noise but I'm hesitant to go with a lighter oil because it rarely gets below 32F here.
Upside is offline
post #58 of 117 Old 11-15-2012, 09:51 AM
blackjeep05
Run what you want but, I wouldn't use Pennzoil are Quacker cake in my lawn mower. Pennzoil might be better but, I'm not about to test and see. I know Valvoline and Castrol are the best oils period. Every engine I've seen torn down had low wear and was clean as a mole's ***.
post #59 of 117 Old 11-15-2012, 09:52 AM
blackjeep05
You could probably go more than 3k but, me I will stick to what works. Why reinvent the wheel? All my engines have ran well over 200k with no problems doing it that way.
post #60 of 117 Old 11-15-2012, 10:19 AM
ChrisHager
Administrator
ChrisHager's Avatar
Bold claims without test results... Not looking to start anything, more suggesting that for the above comment to be correct, you're going to have to post test results from a controlled environment...
My brother's friend's uncle knew a guy that had this here tractor - only ran on 5 cylinders but by-golly them there pistons were shiny as all get out when they rebuilt it after 30 years of use. All they ever did was run some molasses and a little dish soap through it - couldn't afford oil back then. All I'll ever use nowadays because clearly, it's the best being that the tractor ran for 30 years on it...
...See what I mean?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
mobil 1 for high mileage suv djoy WJ Grand Cherokee Forum 37 06-30-2011 09:39 PM
Would you buy this High Mileage? xJoshxx WJ Grand Cherokee Forum 8 06-27-2011 07:41 PM
High Mileage Oil xbucux WJ Grand Cherokee Forum 6 03-07-2011 09:07 PM
High Mileage Points of interest jjfrieze WJ Grand Cherokee Forum 8 01-17-2011 12:55 PM
what oil to use in a high mileage jeep with ticking?? flandaz13 WJ Grand Cherokee Forum 12 01-04-2011 12:37 AM
