WJ Wont move unless high rpms - JeepForum.com
post #1 of 10 Old 01-08-2013, 03:36 PM Thread Starter
MichiganDuck
My uncles Jeep is an 04 Limited 4.7 with Quadra-trac 2. He just got the diffs serviced and drove it home. Now it wont move unless you put it into high rpms. Noticed the ground strap on the trans was broke, but we grounded that and no change. The trans just seems like it wont engage, regardless of gear (reverse, drive, 2, 1)... Shifted into 4lo, and still wouldnt move. Shifting back into 4hi, and it grinded a little as if it was receiving input. Still wouldnt move.
Any thoughts?
MichiganDuck is offline
post #2 of 10 Old 01-08-2013, 03:37 PM Thread Starter
MichiganDuck
Trans fluid is newer, full and in good condition.
post #3 of 10 Old 01-08-2013, 03:40 PM Thread Starter
MichiganDuck
Trouble codes we pulled:
P0700 and P0455
post #4 of 10 Old 01-08-2013, 03:45 PM
XC_Jeeps
P0700 is a tcm code that needs to be read by a drb or other expensive scan tool. P0455 is an evap code iirc
2002 Special Edition 4.7L V8 2"BB
XC_Jeeps is offline
post #5 of 10 Old 01-08-2013, 03:50 PM
bradywgn71
bradywgn71's Avatar
Yea, P0700 will need further scanning to determine what it is. P0455 could just be a worn or loose gas cap.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #6 of 10 Old 01-08-2013, 03:58 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
in the mean time, do NOT continue to try and drive it.
get the codes and it'll tell you where you stand.
ratmonkey is offline
post #7 of 10 Old 01-08-2013, 04:18 PM
KSFLATLANDER
Does it roll in neutral? If not it could be brake calipers not releasing.
KSFLATLANDER is offline
post #8 of 10 Old 01-08-2013, 06:21 PM
MattND
Might be in limp mode? Mine did that after stalling a bunch of times .. finally it gave me a check engine light and found out it was a p0700. Seemed like it was stuck in 3rd gear or something. Drove it about 8 miles.. seems fine now.
2000 WJ Limited 4.7 V8, Quadradrive, 3" IRO, 32" Destination MTs, Rusty's exaust, Flowmaster 50, Carolina front driveshaft, IRO Premium sliders
MattND is offline
post #9 of 10 Old 01-08-2013, 06:26 PM
yrkoverland
Yes in limp mode with the 0700 code so it's in one gear hence why it won't move very well.
Could be a bad Tcm or ??
2000 WJ- 4.7L HO swap, 247, 4" tera-flex lift, 32's, KOR Rock Rails, IRO Skid, etc...
2007 VW Touareg V10 TDI gobs of torque!
2004 Audi A8L Luxobarge
2008 Z06 cammed and slammed
yrkoverland is offline
post #10 of 10 Old 10-05-2013, 06:01 AM Thread Starter
MichiganDuck
I hate threads with no conclusion, so although months later, it ended up being the solenoids in the trans, and it needed a rebuild.
