My uncles Jeep is an 04 Limited 4.7 with Quadra-trac 2. He just got the diffs serviced and drove it home. Now it wont move unless you put it into high rpms. Noticed the ground strap on the trans was broke, but we grounded that and no change. The trans just seems like it wont engage, regardless of gear (reverse, drive, 2, 1)... Shifted into 4lo, and still wouldnt move. Shifting back into 4hi, and it grinded a little as if it was receiving input. Still wouldnt move.
Might be in limp mode? Mine did that after stalling a bunch of times .. finally it gave me a check engine light and found out it was a p0700. Seemed like it was stuck in 3rd gear or something. Drove it about 8 miles.. seems fine now.
I hate threads with no conclusion, so although months later, it ended up being the solenoids in the trans, and it needed a rebuild.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
