WJ or WK - Page 2 - JeepForum.com
post #16 of 35 Old 07-15-2013, 02:58 PM
briandor
Originally Posted by sserg25 View Post
I loved the v6. I was just wondering if the v8 was the extra cash and lower mpg. Thanks for the info guys
He's giving you a hard time because the WJ has an I6 (straight 6) and not a V6. The V6 started in in the WK model Grand Cherokee.
briandor is offline
post #17 of 35 Old 07-15-2013, 03:26 PM
leadsled jeep
I am surprised no one has pointed out no WJ came with a V6. I-6's only.
Must be folks had typo-brain f@rts. I have them frequently too.
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #18 of 35 Old 07-15-2013, 04:15 PM
brouwmat
LOL I was there but didn't say it outright. If you are thinking a 6cyl is enough then definitely go with the WJ.. That I6 was in production for that long for a reason. Darn good motor. I heard that the only reason Chrysler discontinued it was because the machinery used to make it was shot. It was massive and old and it was much cheaper for them to use an engine from their other lineups. The only thing they did to it to ruin it was put crappy aluminum pistons on there that are prone to crack. Use an oil with ZDP (I think that is what it is called) and you won't have an issue. I also hear Rotella T5 is a wise choice because it is technically a long block. My mother in law saw almost 300 k with her 97 Cherokee with the same block before she sold it.
brouwmat is offline
post #19 of 35 Old 07-15-2013, 04:29 PM
99WJ539918
If you don't have plans for crazy off roading adventures and you want the technology upgrades that the WK has then get that. I prefer the 4.7L or the 5.7L, the 3.7L is a dog. If you're going to get a WJ, you're used to what the I6 offers so you know what you're getting there. As far the WJ, I'd like a V8 personally.
Build Thread
99WJ539918 is offline
post #20 of 35 Old 07-15-2013, 05:54 PM
wickedwj99
I have had both wj and wk and I went back to wj cause to me it felt better and plus it is. Cheaper to work on and get a lift for it. Rough country makes a spacer lift for the wk but it is steel, superlift and a few others make lifts but they cost a lot of money.
I have also heard those stick on chrome vents from Walmart add like 75+ HP..
wickedwj99 is offline
post #21 of 35 Old 07-15-2013, 07:11 PM Thread Starter
sserg25
Sorry guys I usually say inline 6 instead of v6. I was posting from my phone.
sserg25 is offline
post #22 of 35 Old 07-15-2013, 07:28 PM Thread Starter
sserg25
Pics of my old WJ
sserg25 is offline
post #23 of 35 Old 07-15-2013, 07:43 PM
maloj2003wj
2006 WK
4.7 HO is worth every single penny, In my opinion. I went from 6 cylinder to 4.7 HO! BIGGER IS BETTER =) the engine is a lot quieter and much more powerful! Gas consumption is about the same, for highway driving.
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #24 of 35 Old 07-15-2013, 07:43 PM Thread Starter
sserg25
4.7 it is!
sserg25 is offline
post #25 of 35 Old 07-15-2013, 09:02 PM
bigredhawkeye
You're posting on a WJ board, so you have to assume the majority of us are going to say get a WJ.
Pick up a nice WJ with a 4.7, and you will be very happy. Much more affordable to lift, and more durable with the solid front axle.
bigredhawkeye is offline
post #26 of 35 Old 07-15-2013, 09:27 PM
rebelbowtie
But then you have an XJ guy like me with a non biased opinion saying get the WJ
rebelbowtie is offline
post #27 of 35 Old 07-16-2013, 12:18 AM
Olese
Hello board, I'm looking to purchase a Jeep in the near future. I plan to lift it and put bigger tire on it. I used to own a stock 2000 WJ V6, and I traded it in years ago. The only thing I hated about the WJ was the brakes. I haven't had a chance to drive the WK, I was wondering if it performed better than the WJ.
In my opinion the WJ is the last real 4X4 of the Grands (straight axles). I also think that the WK is the ugliest Grand made (the ZJ, WJ, and WK2 are all better looking). 4.7 all the way and yes, the HO is worth it (forged steal crank, floating wrist pins, domed pistons with increased compression ratio, modified combustion chambers, modified intake manifold, bigger cams, higher flow rate injectors blah blah blah...). Put a larger diameter throttle body, K&N CIA, larger Borla (or similar) exhaust, and a Superchip in performance mode and they are impressive!!!
As far as the brakes go, if you get an early WJ do the Akebono swap for sure and then on any WJ add SS brake lines and EBC 7000 greens. These last two things really help out with a firm pedal. When I put bigger tires and steel wheels (lots more rotating mass), that's when I noticed my brakes sucking but these things will add new life to stopping power.
The WK rides nicer and handles better on the street and you can get a Hemi, that's about all that I can say about the WK (the Hemi screams, wish it wasn't such a pain to stuff into a WJ!).
It would be funny to see this thread in the WK forum and read the responses
Olese is offline
post #28 of 35 Old 07-16-2013, 12:30 AM
USFORCES
Haha! Olese's right someone should post the same question in the WK section and give us the link, lol
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #29 of 35 Old 07-16-2013, 06:43 AM Thread Starter
sserg25
Bigred you're right about the bias opinions. I was leaning toward another WJ, I just wanted some opinions since I haven't had the chance to drive a WK.
sserg25 is offline
post #30 of 35 Old 07-16-2013, 11:55 AM
rdkendrick
2003 WJ
I saw a little more than 435,000 before my engine went in my '91 Cherokee Laredo.
Sent from my iPad using Forum Runner
rdkendrick is offline
