WJ Window Regulator Replacement Problems - JeepForum.com
post #1 of 3 Old 09-22-2013, 09:04 PM Thread Starter
DakMan96
I replaced my 99 WJs drivers side front window regulator and now when the window is rolled down, no problems. When I role it up its like it catches on the side of the window closest to the rear of vehicle and tips forward getting stuck. I have to hold that side down gently while rolling it up for it to work. Any ideas how to fix this?
DakMan96 is offline
post #2 of 3 Old 09-22-2013, 09:21 PM
cykaaro
Have to see what it's hitting. Should move smoothly along the 'tracks' it uses. As well, if the window is able to tip forward, it's possibly not attached right. Isn't there two screws that fasten it to the regulator? Been awhile since I've had mine apart. With no regulator, window should easily slide up/down. Once regulator is in, it simply bolts the window to it.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 3 Old 09-23-2013, 06:50 AM Thread Starter
DakMan96
Yes, there are two clips holding it on. It's possible only one of the clips is in place. I'll check next chance I get, hopefully that's it.. If not it could be a dirty window gasket causing it to drag and get caught
DakMan96 is offline
