WJ V8->I-6 front axle swap - JeepForum.com
post #1 of 4 Old 05-16-2010, 10:01 PM Thread Starter
dkpulsford
so i've got a '00 WJ 4.0 with a bombed front axle. found a local guy parting out a 99 WJ 4.7. will the axle from his 4.7 WJ bolt up to my 4.0 WJ?? are the gear ratios any different?? or anything else for that matter?? i know i should do a better swap up to something like a d44 or a d60, but money is tight and this is more in my price range
"Bad roads bring good people; good roads bring bad people." -Chris Collard
88 MJ
01 TJ
dkpulsford is offline
post #2 of 4 Old 05-16-2010, 11:27 PM
PDXCoug
Honestly I don't think there is an issue. Just make sure he has the same gears that you have in the rear
Washington State University GO COUGS!
PDXCoug is offline
post #3 of 4 Old 05-16-2010, 11:39 PM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
same, check gear ratios though.
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #4 of 4 Old 05-17-2010, 12:02 AM
the88thpianoman
2003 WJ
I'll elaborate a little on what these guys have already said...
There is a good chance you have 3.55 gears and the donor axle has 3.73. Be sure of what you have and then be sure of what the donor is. If it's all the same, go for it. If the gears are different, keep looking. You should be able to find a 3.55 D30 for next to nothing since it's not a highly sought after axle and untold numbers of WJ's left the factory with that combination.
The other thing you'll need to look at is the pinion yoke, which is based on what drive shaft you have in the front. If you have a u-joint at the diff, you'll probably be fine (but check the donor axle to verify). If you have a CV joint at the diff, you may need to swap pinion yokes (which when done correctly involves opening up the diff to set preload and whatnot), but it would probably be way easier/cheaper to just swap your front drive shaft entirely. You can find a used stock shaft to bolt up to whatever yoke/flange is at the t case, and the u joint at the diff that the donor axle most likely has. It's a very easily overcome problem, just something you'll want to be aware of.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
Front axle swap help 02RecoveryWJ ZJ Grand Cherokee Forum 12 07-30-2009 10:29 PM
Front axle swap in 96 ZJ 97DCZJ ZJ Grand Cherokee Forum 3 06-06-2009 02:28 PM
front axle swap nick3209 ZJ Grand Cherokee Forum 4 03-19-2009 03:52 PM
ZJ WJ front axle swap Raitinger ZJ Grand Cherokee Forum 5 11-19-2008 11:24 AM
front axle swap ??'s grandman17 ZJ Grand Cherokee Forum 13 10-30-2005 07:14 PM
