WJ transmission slips around corners - JeepForum.com
post #1 of 13 Old 03-07-2014, 06:10 PM Thread Starter
J33pWJ
Hello,
New to the forum and new to Jeeps. I have a 2000 WJ 4.7 Quadradrive with 105k miles that I bought a few weeks ago, so far I love it!
Anyway, I have noticed the transmission slips only when I drive around long right bends - the exits coming off the autobahn (I live in Germany). My speed is around 40mph / 2-3k rpm and when I accelerate during the bend the revs don't react (or they drop and I lose drive), after 2 seconds the transmission 'clunks' into gear and all is normal again as I exit onto a straight road.
Left bends, left/right in city traffic or straight line and it shifts perfectly.
I checked the transmission fluid when warm in neutral and park and the level is right in the middle between hot and cold. The fluid looks fresh (cherry red) and doesn't smell burnt or anything.
Does anyone have any ideas what it could be?
J33pWJ is offline
post #2 of 13 Old 03-07-2014, 08:43 PM
skiebuster
possible that the clip holding the bands in place in the back of transmission has broken and causing problems
its like a c clip sort of.
would have to pull the transfer case off and back of trans to see if its broken.
skiebuster is offline
post #3 of 13 Old 03-07-2014, 09:26 PM
88yjproject
Possibly cracked sump filter.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #4 of 13 Old 03-07-2014, 09:58 PM
03CUSEWJ
2003 WJ
This could very well be a case of low fluid. When you turn to the right all the fluid in the pan is pushed to the left side. If there is not enough fluid in the pan to feed the pick up you will get slipping. Check your fluid as directed by the dipstick/owners manual..
03CUSEWJ is offline
post #5 of 13 Old 03-07-2014, 10:02 PM
03CUSEWJ
2003 WJ
I meant to add that it doesnt take much for this to happen, top it off. Be sure to be on level ground.
03CUSEWJ is offline
post #6 of 13 Old 03-08-2014, 06:53 AM Thread Starter
J33pWJ
Thanks for the tips, will top off the fluid and see if it helps.
Would the wrong fluid cause this kind of problem? (I'm topping it up with ATF +4 but have no proof of what is in there at the moment although it looks fresh).
J33pWJ is offline
post #7 of 13 Old 03-08-2014, 08:57 AM
03CUSEWJ
2003 WJ
More than likely thats what is in there. Have you ever changed fluid/filter? Could be a malfunction with the filter as others have suggested. If fluid level does help I would pull the pan to have a look.
03CUSEWJ is offline
post #8 of 13 Old 03-08-2014, 03:52 PM
nhcd538
nhcd538's Avatar
Just had the same issue with mine, which I figured was due to low fluid. Sure enough upon inspection I found I was down about a quart of transmission fluid. Topped it off so that the fluid comes to the top hash mark on the dipstick when hot and in park and all is well. My tranny has 242,000 miles on it!
Something to consider, maybe add a little fluid and see if it improves.
1999 TJ 2.5L AX5 NP231 D35/30 4.11's
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #9 of 13 Old 03-11-2014, 11:08 PM
03CUSEWJ
2003 WJ
I am assuming that the fluid level was the issue?...
03CUSEWJ is offline
post #10 of 13 Old 03-14-2014, 10:13 AM Thread Starter
J33pWJ
Sorry for the late reply, I topped up 1 liter and the problem does seem to have disappeared, was driving the car all day yesterday. I am well happy!
Next move is to find someone to convert it to run on LPG, I want to use the WJ as my DD and fuel is a serious expense over here in Europe
J33pWJ is offline
post #11 of 13 Old 03-14-2014, 10:26 AM
03CUSEWJ
2003 WJ
Im glad to hear this. I hope your conversion goes well! I have friends and family in Denmark and they tell me 9-10 us per gal.. I would look at converting, too!
03CUSEWJ is offline
post #12 of 13 Old 03-14-2014, 11:44 AM
Thomahawk
In Norway we Are at 10-11$ a gallon
Buildthread
Thomahawk is offline
post #13 of 13 Old 03-14-2014, 01:40 PM
03CUSEWJ
2003 WJ
Thomahawk, thats the price you pay for beauty, I guess.. ...
03CUSEWJ is offline
