WJ Trans Limp mode - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ Trans Limp mode
Brand New! Quadratec LED Headlights!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 06-10-2014, 08:04 AM   #1
ChrisJan
Wj WJ Trans Limp mode
Hi Guys this is my first post in the forum ,, and unfortunately its not something good,, i have a 2003 4.7 wj grand. its doing something very strange. on startup shes fine, but drive about 30km and the trans goes into limp mode were shes stuck in 2, 0r when in drive 3rd gear. but if i switch her off and parked off for about 10mins and i startup and go shes 100% . ive replaced speed and press sensors and the prob still the same. i dont know if its temp related.? the box has new clutches in. and now sensors aswell. the code that pops up in limp mode is p0700 (drbii to be plugged in) but it goes off when i pull off again and comes on when limp mode comes back. the oil has i light silver shine after the clutches were done and i assume (hope) they put new filters in. the trans has i very small leak.. more a seeping through than leak. i know my crank sensor is on the way out as well, ive ordered a new one in the meantime.. any ideas of what could cause such a fault ? oh and it started after i went up a serious mud climb one afternoon and had i good spin trying to get out the top of the climb. could the oil overheat and fail ? the trans overtemp light never came on ?
please if anyone could post some advice i would appreciate it.
ive been reading sites nonstop and ive found only that it might be solinoid pack or temp related or even a cracked valve body. dont know if the filter might be faulty
ChrisJan is offline   Reply With Quote
Unread 06-10-2014, 08:13 AM   #2
dlundblad
2003 WJ
Welcome!
Since you mentioned the fluid looked a bit off, I would start with a fluid drain and fill as well as changing the filters. The v8 has an in pan filter as well as a spin on filter. Be sure to replace both and use only ATF+4 fluid. A quick Google search told me where you lived: South Africa. That fluid might be a bit hard to come by there.. Not too sure.
David_Silver WJ Laredo 4.0
2"BB with Monroe Reflex shocks on 245/75/16 Goodyear Duratracs
OME SS_IPF series 868 lights
Plus a few other junkyard goodies...
dlundblad is offline   Reply With Quote
Unread 06-10-2014, 08:18 AM   #3
ChrisJan
we can only get atf+4 from the jeep agents but at a price ofcoars . ill def do that and see if anything has changed. thank you for the quick reply
Unread 06-10-2014, 08:19 AM   #4
dlundblad
2003 WJ
Check this link out too. Very helpful site.
http://www.wjjeeps.com/service/transmission.htm
Unread 06-10-2014, 08:22 AM   #5
WXman
Originally Posted by dlundblad View Post
Welcome!
I agree. I'd start by installing two new filters, fresh ATF +4 fluid only, and get the leak sealed up. See what happens then. Apparently Chrysler vehicles are very sensitive to non-specified fluids and/or dirty fluid.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is online now   Reply With Quote
Unread 06-17-2014, 11:04 AM   #6
ChrisJan
ive now orderd new fluid and filters.. thinking of adding a aux oil cooler for the trans infront of the rad. i saw something weird today , the dash light had i lite flickering , so i pulled into the garage and held the revs at 2000 and the batt charge indicator wasnt stable at 14V as usual. it was shaky at about 13.5V . could this cauze my trans trouble ? i was driving earlier and it went into limp mode. stopped switched off for 15sec and started her, drove off without a prob. ? very strange
Unread 06-17-2014, 02:45 PM   #7
fosterjd79
It should throw codes if it goes into limp mode. No check engine light? I'd blame the solenoid pack but check the fluid and filters first.
[URL=http://www.jeepforum.com/forum/f197/fosterjd79s-wj-build-thread-1498923/][COLOR="white"]Fosterjd79 Build Thread[/COLOR][/url]
fosterjd79 is offline   Reply With Quote
Unread 06-18-2014, 09:18 AM   #8
ChrisJan
it shows p0700 yes. i also think its solinoids. and i think its a good idea to have the alternator and batt tested
Unread 08-21-2014, 10:53 AM   #9
ChrisJan
just an update.. i did a trans service .. new oil and filters and cleaned the valvebody.. and she is now runnig flawles.. but that said i unfortunatly snapped the diff side cv on the propshaft. for the second time now
