WJ trailer hitch install/info Q's - JeepForum.com
post #1 of 6 Old 02-25-2012, 02:16 PM Thread Starter
wyattrhicks
i have a 2000 WJ but mine didnt come with a factory hitch, and wondering if i order a hitch..would my jeep have that plug in harness that is somewhere in the tailgate..for my hitch to plug into, even though i dont have a factory hitch? thanks in advance for any info.
/JeepBoy/
wyattrhicks is offline
post #2 of 6 Old 02-25-2012, 03:37 PM
PhantomWJ
2003 WJ
your WJ would have the female end of the plug in harness, you would have to source a new one from e-trailer or a used one from somewhere and then its plug and play from there....
also, you would need the bezel for the rear bumper....
I have a bezel for nearly free on the classifieds there is also another member selling the hitch, bezel, and wiring harness (i think) also on the classifieds...
PhantomWJ is offline
post #3 of 6 Old 02-25-2012, 03:40 PM
Augie56
Any WJ should have the green 10-pin connector behind drivers side rear hatch area trim panel no matter if it came with tow package or not. You'll need either a factory tow harness WITH the relay pack, or an aftermarket harness that also has a relay module (etrailer.com). The aftermarket ones will plug in just the same as factory. If you source a factory harness from a junkyard, be sure to also get the relay pack that is attached to the trailer harness (don't snip anything...just unplug the green connector and take everything that's connected to it). The system won't work without it. Check my other posts to see why I know this if you're curious.
Also, you truly don't need the trim bezel if you cut out the bumper nice and neat....I like the look of mine after I took my time and made my cuts laser-straight.
Augie56 is offline
post #4 of 6 Old 02-25-2012, 04:40 PM
WJhappened
Check out my recent thread.
I discovered that mine had the wiring harness already.
If you need one afterall, I have one for sale at 1/2 price, PM me if interested.
WJhappened is offline
post #5 of 6 Old 02-25-2012, 09:17 PM
WiLieR
http://www.wjjeeps.com/trailer.htm
This has all the info you might need, including install pics and instructions.
99 WJ Laredo - Mine once again!
WiLieR is offline
post #6 of 6 Old 08-24-2013, 04:02 AM
veiri86
2003 WJ
Hi,
I know it is an old thread, but any of you guys still have the tow hitch bezel?
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
'01 WJ Trailer Hitch Job Farlander WJ Grand Cherokee Forum 19 05-30-2013 12:14 AM
OEM Trailer Hitch and Wiring Install... Augie56 WJ Grand Cherokee Forum 5 02-21-2012 08:25 AM
Trailer Hitch Install PDXCoug WJ Grand Cherokee Forum 10 06-05-2011 10:17 PM
Trailer Hitch flash WJ Grand Cherokee Forum 6 05-05-2011 11:22 PM
Trailer Hitch Install SGT Superman WJ Grand Cherokee Forum 1 06-23-2010 08:32 PM
