WJ Track bar washer size - JeepForum.com
post #1 of 5 Old 03-23-2010, 05:22 PM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
I have a feeling my track bar hole has started to oval. I am going to be doing some work to the suspension soon so I figure now would be a good time to weld a washer on there to fix and hopefully prevent any future problems.
Anybody know the size of washer I need? I have a ton of washers at the shop but need to make sure I have the correct one.
Thanks
Brian
WJ, WK, CJ5
GraKee99 is offline
post #2 of 5 Old 03-23-2010, 06:00 PM
sdowney717
On my ZJ, I simply drilled the axle mount and bushing out to 7/16 inch.
using a std grade 8 nut you can clear the bolt if you get the right length. otherwise the bolt screws in so far you cant get the box end wrench out.
I like the idea of a larger bolt, gives it more metal surface area to work against.
sdowney717 is offline
post #3 of 5 Old 03-23-2010, 06:32 PM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
I know I can drill it out and go to a larger bolt, but I would rather just weld the washer on and leave it the same.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 5 Old 03-23-2010, 06:33 PM
xJoshxx
2012 WK
Ask Gatorayde or quadra Token. i know he welded a washer onto raydes
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #5 of 5 Old 03-23-2010, 06:49 PM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
Just asked quadratokn and he wasn't sure.
Brian
WJ, WK, CJ5
GraKee99 is offline
ZJ Rear Track Bar Bolt size CLNinja ZJ Grand Cherokee Forum 8 05-23-2012 07:30 PM
CRD Sump Plug washer size? DarrylFlynn WK Grand Cherokee & XK Commander Forum 5 01-17-2010 12:36 PM
WJ Track Bar bolt size upgrade MACHJGC ZJ Grand Cherokee Forum 2 03-14-2009 04:11 PM
IRO track bar bushing size MACHJGC ZJ Grand Cherokee Forum 14 11-22-2008 07:34 PM
Rear Track Bar, Torx Size? ZJcrawler45 ZJ Grand Cherokee Forum 3 08-25-2007 07:13 PM
