WJ Track Bar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ Track Bar
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 04-23-2010, 09:59 PM   #1
KBOD
WJ Track Bar
I am installing an IRO 4'' Lift onto my WJ and was doing alright until we couldnt get the track bar off to put the new adjustable track bar on. Does anybody have any tips/advice for getting the track bar off?
Please help
KBOD is offline   Reply With Quote
Unread 04-23-2010, 10:12 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
What can't you get off? The bolts?
Once the two bolts are removed, just pry it out.
The axle end just has a bolt to remove (the nut is welded on the back side). The other side has a bolt & nut (so hold the nut to prevent it from spinning). On the frame side it is helpful to remove the bump stop to get to the bolt/nut easier. Using a couple large screw drivers and several curse words, pry the rubber pieces out. Once it is out, 2 bolts (13mm I think) hold the bump stop bracket in there. Remove it to make life easier. I find removing the tire on the drivers side to be nice to make access a lot better
ArloGuthroJeep is offline   Reply With Quote
Unread 04-24-2010, 08:49 AM   #3
patrick983
i just took mine out to change bushings and unbolted, wiggled the steering wheel kinda hard and it literally fell out (almost) once i got the body side free its easier to wiggle the axle side loose.
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn [B]SOLD and missed very badly[/B]
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline   Reply With Quote
Unread 04-25-2010, 09:34 PM   #4
KBOD
Well we were taking it out to install the new adjustable track bar, the problem was that the bolts werent coming off. The drivers side bolt was easy to take off, just was hard to push through becuase of the bump stop and it got stuck. The passenger side bolt was a ton harder to get off; that was the one I really couldnt get off
Unread 04-25-2010, 10:01 PM   #5
99WJCHRIS
Just spray the crap out of it with PB blaster and get a longer bar to go over the wrench so you can get some good torque on it. I just did mine a couple days ago and it took some serious pulling on the wrench.
99 WJ,4" Lift, 265/75/16 Treadwrights, RC wheel spacers, Sound System, CB, HID's with amberless headlights, Rola Rack...ect.ect. Money pit!
99WJCHRIS is offline   Reply With Quote
Unread 04-26-2010, 08:16 PM   #6
KBOD
Well I do have a 2wd wj, and still do a lot of off roading and absolutly love my jeep. And I was looking at the difference between the 4wd and mine, and it looks like a different mounting system for the track bar. Cam anyone maybe tell me the difference and why it's so hard to get it off?
Unread 04-29-2010, 02:58 PM   #7
rangerwj
is all the weight off of it? if you jack up or lower the axle to the right position it helps
rangerwj is offline   Reply With Quote
Unread 04-30-2010, 08:05 AM   #8
drwolcot
drwolcot's Avatar
Location: Alpharetta/Statesboro/Americus Georgia, Georgia
There is absolutely no difference between the 2WD and the 4WD trackbar, mounting, etc. As a matter of fact the entire suspension is the same. Trust me I know I did the 4WD swap in my 2WD
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
WJ 2WD-->4WD Conversion Build Thread
2003 WJ Overland - SOLD
drwolcot is offline   Reply With Quote
