WJ Throttle Position Sensor Replacement - JeepForum.com
post #1 of 7 Old 06-01-2010, 11:24 PM Thread Starter
spreadhead14
2003 WJ
I have a 2003 WJ Grand Cherokee with a 4.0 inline 6 engine. I need to replace the throttle position sensor. I purchased the TPS from the dealership and they wanted to charge me an arm and a leg to replace it, so I want to do it myself. What are the steps to tackling this job. I understand that you should clean the throttle body while doing this. Is there a thread that explains this in detail? I have looked but couldn't find anything. I appreciate any help on this!
2003 Grand Cherokee Laredo Brilliant Black
spreadhead14 is offline
post #2 of 7 Old 06-02-2010, 12:21 AM
myjeeplovesmud
go back to the dealer and buy MOPAR de-carbonizer. stuff works wonders, and is easy to use. blows sea foam out of the water. just spray it in the throttle while the jeep is running, open the throttle from time to time, you should see a black cloud come out of your exhaust, this is normal. thats all the junk coming out of your engine.
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
post #3 of 7 Old 06-02-2010, 10:32 AM
LordHobbit
The TPS is on the throttle body, as you described. It has a few screws and an electrical connector. Take those off, pop the sensor off, put the new one on, then the screws and the connector you should be good.
Those screws are likely to be torx, so you may need to go "aquire" a set.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 7 Old 06-02-2010, 10:44 AM
bigbill888
You don't need to clean the throttle body. The TPS is held on with two Torx screws (T20 I think). Make sure it is engaged with the throttle correctly before you screw it down. It will be obvious when you get there.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 7 Old 06-02-2010, 12:34 PM
PDXCoug
The screws are Torx 20 I want to say. They are a huge ***** to get at, since they are facing the back and it was almost impossible for me to get the screws to turn. That could have just been me though. I think Jeep could have positioned the unit a little better during assembly
Washington State University GO COUGS!
PDXCoug is offline
post #6 of 7 Old 06-02-2010, 05:11 PM Thread Starter
spreadhead14
2003 WJ
Thanks for all the help!! I will start this tomorrow.
post #7 of 7 Old 06-02-2010, 06:02 PM
myjeeplovesmud
if ya have to pull 1/3 of the motor off to get to this anyway, wouldn't it just be wise???
November 2010 GCOTM
Throttle Position Sensor hunt4cleanair ZJ Grand Cherokee Forum 16 10-01-2015 11:24 PM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 01:01 AM
Throttle position sensor Ari Haapaniemi ZJ Grand Cherokee Forum 1 10-31-2009 09:25 PM
Throttle Position Sensor PilotWolf ZJ Grand Cherokee Forum 6 12-28-2008 10:26 AM
Throttle position sensor fredp4rrot ZJ Grand Cherokee Forum 2 11-13-2007 05:46 PM
