WJ temperature gauge acting up - JeepForum.com
post #1 of 6 Old 10-04-2013, 08:59 AM Thread Starter
jrafols
Wj WJ temperature gauge acting up
since last week, my engine temp gauge has been fluctuating from 100 to 210. It makes be believe the a sensor might be loose somewhere because it will read correct for the first 5 minutes when I start the car but after that it goes back down to 100. If I hit a bump on the road the gauge goes up to 210 and then back to 100.
Any ideas?
jrafols is offline
post #2 of 6 Old 10-04-2013, 09:26 AM
rdkendrick
2003 WJ
Originally Posted by jrafols View Post
since last week, my engine temp gauge has been fluctuating from 100 to 210. It makes be believe the a sensor might be loose somewhere because it will read correct for the first 5 minutes when I start the car but after that it goes back down to 100. If I hit a bump on the road the gauge goes up to 210 and then back to 100. Any ideas?
I think it's just a cruddy connector. Did you open the hood and check the connector on the coolant temperature sensor? I believe it is the connector as the sensor would make the gauge rise or fall slowly, because the sensor resistance rises as the heat rises and I don't believe it would just drop or rise, fast.
Sent from my iPad using my fingers
rdkendrick is offline
post #3 of 6 Old 10-04-2013, 02:41 PM Thread Starter
jrafols
where is that connector located?
jrafols is offline
post #4 of 6 Old 10-04-2013, 03:43 PM
99_wj_QD
The ECT (Engine Coolant Temp. Sensor) is a very basic sensor so the good news is that it will either be the connector having corrosion and getting intermittent signals or a slowly failing sensor. What engine do you have in the WJ?
99_wj_QD is offline
post #5 of 6 Old 10-04-2013, 04:14 PM Thread Starter
jrafols
Inline 6
jrafols is offline
post #6 of 6 Old 10-04-2013, 07:07 PM
new2site
It's on the right side of your thermostat housing.
new2site is offline
