wj sunroof problems - JeepForum.com
post #1 of 7 Old 04-14-2011, 03:21 PM Thread Starter
wjgiants39
2014 JK Wrangler
wj sunroof problems
tried to use my sunroof today.. tilts up fine but will not go all the way back. i played with it and eventually got it to go all the way back, the motor seemed to be very sluggish while moving the glass back. when i tried to close it again it went foward, stopped and went backwards and stayed open. eventually had to pull it shut by hand while pressing the button to close it. anyone have ideas what the issue could be? loose connection or bad fuse maybe?
wjgiants39 is offline
post #2 of 7 Old 04-14-2011, 05:50 PM
Double E
Double E's Avatar
Here comes the next "blend door" of the WJ. I'm in the same boat. The motorized carrier is often cracked or partially seperated from the part that slides due to debris, friction that increases as a result and then it breaks.
Headliner has to come down, sunroof assembly replaced. Dealer only item and there's no schematic of the assembly in the Service Manual.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 7 Old 04-15-2011, 11:20 AM Thread Starter
wjgiants39
2014 JK Wrangler
great i was hoping for something that was an easy fix haha
post #4 of 7 Old 04-19-2011, 12:41 PM
n8man1068
2003 WJ
Dang, I'm in the same boat. It'll go up just fine, but not back. It seems like the drivers side portion will start to move, but the passenger side doesn't and hangs.
Depending on the cost, i'm not sure I'd care to have it replaced.
03 WJ IRO 3" lift, DT8000 shocks, Addco swaybars, JKS quick disconnects, IRO xfer skid, IRO adc control arms, Rola roof rack, Uniden 510xl+firestick 2, K&N drop in filter, Cragar soft 8's, Hankook Dynapro ATM/RF10tires
n8man1068 is offline
post #5 of 7 Old 04-19-2011, 12:45 PM
drwolcot
I have a broken tab on mine...... if I hold the black plastic piece down while it is closing it opens and closes fine.... if not it starts to jam and the motor struggles. Mine has been like this for about a year and I still use it all the time....
It's pretty easy to keep it from jamming and isn't that much of an inconvenience.... I just live with it cause I love my sunroof
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #6 of 7 Old 04-19-2011, 01:24 PM
nassin2
2005 WK
You might try putting a little white fishing reel grease on the tracks. That helped mine when it got a little sluggish.
04 WJ Limited 4.7, Quadradrive, 2 inch BB, Skyjacker 8000 nitros, rough country stabilizer, hella lights <--Totalled
05 WK Limited Hemi, QD2, K&N intake, Magnaflow exhaust
Black WK Club Member #11
nassin2 is offline
post #7 of 7 Old 04-19-2011, 03:11 PM
corvettekid82
Had that issue on mine as well, the 'air foil' would get in the way... so I just removed it. Works great since then
Mike - 02 WJ Ltd. 4.7 HO, 3" IRO, 32's | 80 Corvette | 01 Z-28 Convertible
http://www.fquick.com/Corvettekid82
corvettekid82 is offline
Sunroof help Johan2 WJ Grand Cherokee Forum 2 03-22-2011 06:52 AM
WJ sunroof motor FIX..help... blazepsi WJ Grand Cherokee Forum 0 06-20-2010 03:15 AM
wj sunroof problems kathan21 WJ Grand Cherokee Forum 0 05-29-2010 12:56 PM
Sunroof Problems grovesj2 WJ Grand Cherokee Forum 3 05-11-2010 04:58 PM
sunroof issue please help WJ-matt WJ Grand Cherokee Forum 2 03-21-2010 06:08 PM
