WJ stock bumper tire carrier DIY - Page 4 - JeepForum.com
 1Likes
post #46 of 57 Old 07-30-2012, 09:25 AM
BLACK04WJ
thanks for the advice! my design should be able to swing away from the jeep so clearance shouldn't be an issue I hope.. 35's take up a lot of room. I'm using heims instead of a spindle.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #47 of 57 Old 09-15-2012, 07:41 PM
4x4Jeep
FYI subscribers: traded for MrJ's tire carrier so i'll be finishing this up on my WJ, but won't get started on it just yet, need more important things fixed first. let you know when i begin...
Build -
SOLD
4x4Jeep is offline
post #48 of 57 Old 01-06-2013, 09:18 AM
piratexpress
any updates ?
piratexpress is offline
post #49 of 57 Old 01-06-2013, 03:01 PM
thisguyhasadd2
Here's mine at work on the habitat homes in teton village
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #50 of 57 Old 01-07-2013, 03:38 AM
texlurch
Thinking I can get this:
http://www.ebay.com/itm/87-06-Jeep-W...ae8c4a&vxp=mtr
Add the beam across the stock bumper, gusset down to hitch mounts... ?
Or would it be plenty strong just welded to stock bumper/subframe?
I realize I need to extend the latch end a bit to clear the hatch, but sure would reduce the material cost and fab time...
thoughts?
texlurch is offline
post #51 of 57 Old 01-08-2013, 05:34 AM
Fawkes
WJ recovery gear
Fawkes's Avatar
Smunns did something similar to JCDriller for his Dub. When he built his bumper, I bought his swing-away and modded it a bit before installing on mine:
http://www.jeepforum.com/forum/f197/...hread-1147792/
I like how you've kept the weight near the pivot point. Smunns had his tire mount centered, and I moved it 6" left for better rear vision... outboard of the pivot on the right side.
With a 32" tire and steel wheel, that's a LOT of weight at the end of the arm.
Kris Fox
Fawkes is offline
post #52 of 57 Old 01-08-2013, 11:12 PM
thisguyhasadd2
thoughts?
That would increase fab time I feel. I see to much work to drop money on that
post #53 of 57 Old 01-08-2013, 11:45 PM
texlurch
Versus buying the raw steel and hinge and building from scratch?
texlurch is offline
post #54 of 57 Old 01-09-2013, 08:10 PM
4x4Jeep
Originally Posted by piratexpress View Post
any updates ?
it's still on my To Do List. the WJ hasn't been driven in 3 months...need trans./t-case fixed, been trying to save up for that which i will be fixing soon. then the work will begin. hopefully by Feb. or March.
Build -
SOLD
4x4Jeep is offline
post #55 of 57 Old 01-09-2013, 10:07 PM
thisguyhasadd2
Well maybe I was just really fortunate to have a metal distributor in town
post #56 of 57 Old 01-09-2013, 10:39 PM
texlurch
I have to go a ways to get steel; but not even figuring that in the equation
Based on steel prices, getting a hinge and latch, and time to cut it all out and weld it up; something already built that is "close" works out pretty even in cost.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #57 of 57 Old 01-10-2013, 07:00 AM
gcjeeping
gcjeeping's Avatar
Try and find a scrap metal yard. I get mine for 45-54 cents a pound. And a lot of it is new but in smaller pieces.
_____________
gcjeeping is offline
carrier , diy , rear , tire , wj
WJ Tube front winch bumper and rear bumper with tire carrier build pulsepb WJ Grand Cherokee Forum 19 12-11-2012 11:21 AM
Can I change my stock tire size while keeping the stock rim? 04Overland47 WJ Grand Cherokee Forum 2 10-04-2011 07:33 PM
WJ Rear Bumper Carrier. JulietheJeep WJ Grand Cherokee Forum 6 09-13-2011 10:39 PM
Rear Bumper with tire carrier Wup This WJ Grand Cherokee Forum 1 03-11-2011 08:04 AM
WJ: ProtoFab rear bumper with tire carrier ultimo WJ Grand Cherokee Forum 1 06-24-2010 08:49 AM
