WJ spark plug change - JeepForum.com
post #1 of 16 Old 02-18-2005, 11:36 AM Thread Starter
oilcounter
Tomorrow I am going to change out my sparks for the 1st time. I have read all the posts in this forum that I could find for info.
btw - I'm using Champion truck plugs with the copper tips.
I'm nervous but excited about this project. Does anyone have any advice to hand out? Or warnings of things I should avoid during this..
Rob
2000 JEEP GRAND CHEROKEE I-6 (WJ)
All stock except for Mopar 3 disc In-dash CD player
Michelin M/S LTX 255/70/16
Metallic Taupe Jeep Club Member #15
oilcounter is offline
post #2 of 16 Old 02-18-2005, 11:53 AM
ojingalena
Before you install the new plugs make sure they are the correct ones and be sure they are "gapped" accordingly. Not all new plugs are the correct gap for your application. Check your owners manual for proper gap, or usually on the hood or inside the engine compartment on the emsissions tag.
Make sure no debris is around the plugs before you remove the old ones. Compressed air wooks well. OR a hair dryer to blow away debris.
Do not cross thread the plugs. Use your fingers to make sure they are threaded correctly. Do not over tighten the plugs.
Inspect the plugs for wear and proper firing. They should look used. Not oily, sooty, bent, damaged, fused, etc..
Pull the wires off one at a time by the boots, not the actual wire. (Label if needed)
Make sure the wires are reconnected all the way. You should hear a little snap or feel a slight click.
An old plug wire makes an excellect tool for hard to reach plugs.
Have a beer when finished..
HTH,
Jim
If loving the Buckeyes is wrong....I don't want to be right.
Mine: 95 ZJ 5.2 Quadratrac Char Gold Laredo, Tow Package, K&N FIPK, Kolak Mopar ECU, CatSound, AT50 Muffler, 2" TeraFlex BB, Bilstein 5100's, 265/70-15 110S Dueler AT Revo's. It's a start..more to come
Wifes: 99 WJ 4.0 Laredo pretty much stock....for now.
Mine: 06 KJ Renegade
ojingalena is offline
post #3 of 16 Old 02-18-2005, 12:54 PM
BostonBull
Make sure when you take your coil rail off that you dont bend/break the wire attached to it at the end near the fire wall. I usually leave it attached and bend the rail out of the way of the plugs. Use some dielectric grease on end of boots and anti sieze around threads. You dont have any wires so it shouldnt take anymore than a half hour!
Wicked Pissah
81
BostonBull is offline
post #4 of 16 Old 02-18-2005, 10:55 PM Thread Starter
oilcounter
when I gap the new sparks ( i have a gap tool), do I just use the tool to widen the gap? How accurate do I have to be here? I think I have the gap correct, but didn't know if it was an exact science here or not..
Thanks for the tips. I'll report back on my pending success
R
post #5 of 16 Old 02-18-2005, 11:10 PM
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
Precisely
Usually quite a few (if not all) plugs these days come pre-gapped...so the gap will already be pretty close to what you need...if not dead-on.
Just slip the right gap [of the tool] between the electrodes and you should feel just a bit of friction as you slip the tool in and slide it back out.
If it's too tight and the tool can barely slip in I gently rock the tool up and down to open the gap a bit more and try sliding the tool in and out again....be gentle, it's easy to open the gap too much.
There's no science to it.
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline
post #6 of 16 Old 02-19-2005, 09:19 AM
Stocker
How goes the project? If you need it, here's a site with torque specs and other basic info... http://www.nology.com/torque.html
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #7 of 16 Old 02-19-2005, 11:29 AM
Scottsdale Jack
A good way to start the new plug in the thread is to slip a piece of fuel line or similar hose over the top tip of the new spark plug. That way when you slide it down the hole you can start the plug in the thread by hand and have a good "feel" for the task. When the plug starts in the thread then you can just give a little tug and the hose will slip off the plug and then you can torque it in.
Scottsdale Jack is offline
post #8 of 16 Old 02-19-2005, 05:34 PM Thread Starter
oilcounter
I have finished changing the spark plugs. I really enjoyed myself. I am a complete novice when it comes to stuff like this. What a confindence builder..
Everything went smooth.. It was a little tough to get the sparks out from the very back one. Good thing I have small hands.. That boot got in my way a little but I managed nicely.
I encourage anyone who hasn't changed their spark plugs to go ahead and give it a try. It much easier that the instructions let on.
I did notice the old sparks (original w/jeep - currently 70K miles) Most of them were pretty crusty with grayish charing.. one plug was more dark than the others. I dont know if this is typical or not, but I'm glad I changed them]
A HUGE thank you to everyone who offered advice for me!!
Until my next project... (any suggestions )
Rob
post #9 of 16 Old 06-02-2014, 05:04 PM
rrose3000
I just finished changing out the spark plugs on my 2000 Jeep WJ 4.0L after reading all the forums on here. The recommended plugs on here vary but the consensus was that the engine is designed around Champion plugs and also NGK ZFR5N plugs which came stock in my Jeep. The sticker under the front hood says to use Champion RC12ECC plugs. I decided to buy the Champion #7034 which forum members are saying is a better plug then the RC12ECC. The engine seems to run good so far on these but when I go to the Champion cross reference it doesn't show the Champion RC12ECC is equivalent to the Chanpion #7034's double platnum plug which I installed. So now I'm left wondering if I put in the correct plug? Can someone comment on this and let me know that there not going to ruin my engine, I haven't drove it yet, I have only started the engine and it sounds good so far.......
rrose3000 is offline
post #10 of 16 Old 06-02-2014, 10:09 PM
Uniblurb
Uniblurb's Avatar
Not sure how you're using the cross reference on the Champion site but if you're comparing the RC12ECC (SKU) to the 7034 (Item/plug #) it may be confusing the site the way Champion has it organized. If you enter your 2000 4.0 WJ in the site it recommends the 438 (RC12ECC, nickel), the 3034 (PCPEC5, single platinum), and the 7034 (RCPEPB5, double platinum) as can be found below.
http://www.championsparkplugs.com/Ch...ive-c1343.aspx
Click on the "+" sign above the 7034 double platinum and it states, "This part exceeds the OE standards". So you'll be fine and I've seen others on the WJ forum say this is the plug they recommend.
When I changed the plugs on my 2004 4.7 last fall I just used the OE standard Champions (nickle w/copper core). Kind of a force of habit since on my ZJ many here say to just use the standard Champion copper plugs.
Not sure how this 9 year old WJ plug thread from 2005 ended up/stayed on the ZJ forum to begin with?? May be why you aren't getting a whole lot of input from ZJ owners. Lol and good luck!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #11 of 16 Old 06-03-2014, 12:23 AM
ROFLwaffles
Thread of the undead. lol
ROFLwaffles is offline
post #12 of 16 Old 06-03-2014, 03:52 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I was just getting ready to post myself.I'm the worlds worst about looking at the dates.
Originally Posted by HighLonesome
coralman is offline
post #13 of 16 Old 06-04-2014, 06:22 AM
Double E
Double E's Avatar
Back then, the ZJ and the WJ were a combined section.
(add old man voice: "and we liked it...up hill both ways, in the snow)
It split apart like in 2006 or sometime around then.
(add Walter Cronkite voice: "and that's the way it was").
Damn I'm getting old.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #14 of 16 Old 06-04-2014, 08:40 AM
Jeeples
Jeeples's Avatar
Ahhh yes, those were the days....
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #15 of 16 Old 06-04-2014, 12:56 PM
Uniblurb
Uniblurb's Avatar
Ahh.. that explain it, in they were combined, thanks! I'm sure I'm old enough since remember Walter well but just wasn't here...
Uniblurb is offline
Spark plug change today in my WJ 00RedWJ ZJ Grand Cherokee Forum 10 08-30-2009 07:50 PM
Still bad mileage after spark plug and oil change, what else can I do? Tbirdbassist ZJ Grand Cherokee Forum 4 07-19-2009 03:33 PM
Spark plug effort level & plug recomendations Bville-Bud WK Grand Cherokee & XK Commander Forum 3 11-26-2008 01:02 PM
spark plug change .. how difficult on the GC havent looked sanboy ZJ Grand Cherokee Forum 16 03-24-2006 11:57 AM
Spark Plug change- 2000 WJ oilcounter ZJ Grand Cherokee Forum 5 01-31-2005 07:56 PM
