WJ sounds like a tractor when starting. - JeepForum.com
post #1 of 13 Old 06-06-2013, 10:45 AM Thread Starter
iwheelinbama
Wj WJ sounds like a tractor when starting.
Started my WJ and all was well until it started choking and just stalled out. I have not been able to keep it running since because it just knocks and clunks and just dies. There is a fresh smell of gas in the engine bay after i try to start it but no leaks.. I drained the oil to see if i could find metal shavings but all looked well. Sounds almost like theres a midget in there with a sledge hammer going at it in my black. Could some one please help me solve this problem i miss my jeep.
Main problems: WJ cranks and turns over but you need to push the gas pedal all the way down to even start it and to keep it running. It clunks and knocks very loud that it scares me to even keep it running thinking it will blow up in my face. Idle bounces 200- 2500 and just chokes out. need help please.. Thanks!
iwheelinbama is offline
post #2 of 13 Old 06-06-2013, 12:44 PM
Jer-Bear
Not good....
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #3 of 13 Old 06-06-2013, 06:51 PM Thread Starter
iwheelinbama
pulled the back driver side plug and it seems as if something closed the gap to the spark plug. Any advice to what that could mean?
post #4 of 13 Old 06-06-2013, 07:03 PM
Jer-Bear
Your piston hit it. Maybe a thrown rod.
Jer-Bear is offline
post #5 of 13 Old 06-06-2013, 07:28 PM Thread Starter
iwheelinbama
Anyway i would be able to figure out the damage caused and what exactly is the problem?
post #6 of 13 Old 06-06-2013, 07:35 PM
Jer-Bear
Yeah man, I'm gonna say you'll have to rebuild the engine... Hopefully your block isn't damaged. You'll have to pull the heads and see exactly what is wrong. If I were you, I'd scrap the engine and drop a different one in it.
Jer-Bear is offline
post #7 of 13 Old 06-06-2013, 07:51 PM Thread Starter
iwheelinbama
There doesnt seem to be any chunks missing from the block or any leaks. If it does end up being blown what would be the cheapest way to go about it?
post #8 of 13 Old 06-06-2013, 07:56 PM
Jer-Bear
You won't know until it's been properly diagnosed. I think the first step should he finding out all of what's wrong. If you know a good mechanic or you're capable of the work yourself, I'd tear the engine down.
Jer-Bear is offline
post #9 of 13 Old 06-06-2013, 08:15 PM
milresq
Wj A tractor!!!
Case, John Deere, Kubota,Massey-Ferguson,New Holland, Oliver. What is it man, fill us in. Details, details, details.
Todd J. Kennedy
United States Navy
Ret. HOOYAH
2002 WJOE Stocker
milresq is offline
post #10 of 13 Old 06-06-2013, 10:48 PM Thread Starter
iwheelinbama
Well my dad use to work on cars when he was a kid and knows a good bit and confident we can at least diagnose it. Im of course going to be helping him because i myself enjoy working on my jeep with my father so i think it will be a good learning experience for the both of us. Is there any rebuild threads on the forum or any where else? I appreciate the help guys very helpful. ill keep you guys updated with questions if you dont mind. we're the do it at home mechanics, my choice mostly.
post #11 of 13 Old 06-07-2013, 01:10 AM
doorjamm
Personally, my first step would be pulling the motor since its looking like you're going to be rebuilding it anyways, but you can always work on it in the vehicle. You're gonna need to pull the intake manifold off, the valve covers, and then remove the heads. Send them to a shop and have them checked. Look at pistons and Rods, check for play and obvious wear. If one is gone, I'd suggest replacing all of them. If your cylinder is scratched or anything from a faulty piston, you might need to send the block to a machine shop and have it bored, requiring you to buy oversized pistons/rings. New bearings all around would be a good suggestion, and check your valves is your piston went all the way up to the spark plug. Then it's a matter of just buttoning it all back together and putting some oil and coolant in it.
doorjamm is offline
post #12 of 13 Old 06-07-2013, 08:32 AM
Double E
Double E's Avatar
Sounds like the engine ran hot at some point and it dropped a valve seat. That or a rocker arm fell off but from the description...I'd say valve seat dropped.
Bore scope is what I'd be doing right now to assess the internal damage. Harbor Freight has one for cheap but may not be the best built tool in the world.
If nothing else, run a little pick up tool magnet into the sparkplug hole and see what sticks.
Continuing to run it is only going to promote those chunks of metal and what remains of the piston digging into the cylinder walls and bending valves to break/drop point.
Reading pleasure:
http://www.jeepforum.com/forum/f19/m...seats-1507696/
http://dodgeforum.com/forum/jeeps/33...p-carnage.html
http://www.jeepforum.com/forum/f310/...-7-v8-1112272/
There will be no shavings, just big chunks.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #13 of 13 Old 06-07-2013, 12:06 PM Thread Starter
iwheelinbama
It did get a tic past 210 but i had never seen it get any hotter than that. Just saw my poor baby on a tow truck going to the shop to get bore scoped.. Almost brought a tear to my eye. Hopefully its just a loose piston but i highly doubt it would be that simple with my luck everything in there is torn up but who knows. Any advice on grooms engine or jaspers?
