WJ rock sliders build plans - JeepForum.com
post #1 of 20 Old 07-07-2010, 06:40 PM Thread Starter
Krisalrube
Any one made there own rock sliders and still have the plans, measurements and/or instructions on how to build them. Im looking to make my own but i have no idea how to. Any advice would be great.
Krisalrube is offline
post #2 of 20 Old 11-08-2010, 10:42 PM
JeeperCreeper94
Bump. I want em too!
1999 WJ 4" IRO, Cb, Baja Racing Lights, 31" Treadrights
JeeperCreeper94 is offline
post #3 of 20 Old 11-08-2010, 10:45 PM
Scibbyz99WJ
yep. ive got a few ideas for my own, but itd be nice to see some veteran work!!
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #4 of 20 Old 11-09-2010, 08:48 AM
smunns
Here's the ones I built.
Materials used:
1. (2) 68" long 2 1/2" x 1 1/2" 1/8" rectangular tubing for the sliders
2. (4) 9-10" long 1" x 1 1/2" rectangular tubing 3/16" for the supports + about 8" of the same material cut into 1" - 2" pieces to connect the sliders to the pinch seam and supports.
3. (4) 3" x 4" 3/16" flat plate for the frame mounts
4. (2) 1" x 48" 1/4" flat bar for the pinch seam.
Directions:
1. I cut out the four 3/16" frame mounts, and drilled four holes in them. I then marked where I wanted to mount them on the frame, drilled the holes in the frame, and tapped them. I then bolted the plates to the frame using 3/8" grade 8 hardware.
2. I drilled 6 or 7 holes along each piece of 1/4" flat bar for the pinch seams, clamped them to the pinch seams, drilled out the pinch seams, then bolted the flat bar to the pinch seams using 5/16" grade 8 hardware.
3. I held each 1" x1 1/2" support in place between the plates on the frame and the flat bar on the pinch seam, and measured the angles I needed to cut with a magnetic angle finder. I then cut the angles, and trimmed the supports so that they lined up with the face of the 1/4" flat bar bolted to the pinch seam.
4. Tack weld the supports to the frame plates and 1/4 flat bar bolted to the pinch seam. Cut some short sections of the left over 1" x 1 1/2" rectangular tubing, and tack weld them to the face of the supports/pinch seam flat bar.
5. Cut the sliders to 68" with whatever angle you'd like on the ends. I think I did 22.5 degrees. Tack weld the sliders in place.
6. After everything is tacked in place, remove the sliders and finish welding them up. I added a few 1" x 1/2" rectangular tubing supports between the 1/4" flat bar and sliders. I also capped the sliders.
Building off the mounts like this gave me a perfect fit.
smunns is offline
post #5 of 20 Old 11-09-2010, 08:59 AM Thread Starter
Krisalrube
Thanks a bunch Your jeep is amazing by the way!! Love the work youve done to it.
post #6 of 20 Old 11-09-2010, 09:05 AM
Jason_alex
WOW, thats a nice looking slider, love the flex
Jason_alex is offline
post #7 of 20 Old 11-12-2010, 03:11 PM
Jason_alex
How thick is the frame and is that fine or course threaded bolts?
post #8 of 20 Old 11-12-2010, 05:21 PM
MoonyJohn
Heres mine in my build thread. I have the measurements too, ill dig those up. They copy JCR sliders, i got the same measurements from somebody else on here who has them. I later on added a tube..
1. (2) 66-68" long 2" x 3" sq. tubing 3/16" as the slider
2. (3) 9 5/8" long 1" x 2" sq. tubing 3/16" for the posts
3. (6) 3" x 4" 3/16" flat bar for the shoes
4. (2) 60" long 1" x 1/4" flat stock
5. (12) 9/16" bolts with ceramic nuts
6. (24) 1 1/4" 3/8" self tapping sheet metal bolts (lax bolts)
7. As for paint.. 2 cans of rustoleum rubber undercoating spray paint
http://www.jeepforum.com/forum/f197/...9/index27.html
MoonyJohn is offline
post #9 of 20 Old 05-10-2011, 09:49 PM
markmacak
what are the round tube sizes on ur wj and whats best way to shape it the way u did???
markmacak is offline
post #10 of 20 Old 05-11-2011, 12:28 AM
PDXCoug
You can't go wrong by copying those 2
Washington State University GO COUGS!
PDXCoug is offline
post #11 of 20 Old 05-11-2011, 11:00 AM
PhantomWJ
2003 WJ
Materials used:
Directions:
Those look sweet...
PhantomWJ is offline
post #12 of 20 Old 05-11-2011, 12:34 PM
FleshEater
2014 JK Wrangler
When I get around to it I plan on building boat sides. I think the first set of sliders will work peferct for those and will save me from doing some measuring.
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #13 of 20 Old 05-11-2011, 06:56 PM
PhantomWJ
2003 WJ
smunns....thank you for the measurements....that is definately on the list after the bumper gets built (currently in progress)....
post #14 of 20 Old 10-09-2012, 07:57 AM
derekmac
Since there's a few threads asking about rock sliders, I figured I'd put this TTT.
2005 TJ Rubicon
derekmac is offline
post #15 of 20 Old 02-06-2014, 11:48 PM
wjidaho
Nice sliders guys
My build thread
wjidaho is offline
kor rock sliders tbick ZJ Grand Cherokee Forum 19 12-27-2008 07:57 AM
Rock Sliders takingback167 ZJ Grand Cherokee Forum 19 02-12-2007 07:20 AM
KOR Rock Sliders mrclover21 ZJ Grand Cherokee Forum 47 01-26-2007 05:37 PM
Rock Sliders! Id like to see some pictures! Going to build a set and need inspiration Soft 8 ZJ Grand Cherokee Forum 4 10-16-2006 12:10 PM
I need rock sliders thunderchooch ZJ Grand Cherokee Forum 3 07-08-2003 06:52 AM
