WJ recirculation door fix *pics* - Page 6 - JeepForum.com
post #76 of 129 Old 06-12-2012, 02:27 PM
KloppWJ
I found a calibration procedure for the AZC. Could this be the issue if the door is moving but still giving a code 52?
KloppWJ is offline
post #77 of 129 Old 06-12-2012, 03:16 PM
fumblefingers
2014 WK
I still get a 52 but my door still works ok. I am told the stops are worn which allows the rotation beyond limits and in time the plastic will become over stressed and break. I decided to simply wait and after a year, it is still working.
fumblefingers is offline
post #78 of 129 Old 06-29-2012, 11:24 AM
Zagorich
2003 WJ
I know this is an old post, but hopefully someone can answer... We are very close to purchasing a 2003 Grand Cherokee(Euro version), but the aircon makes a 'knocking' noise(Sounds like plastic inside) when first turned on. It goes for a few seconds, stops, then a few more times then stops and is fine. Previous owner says its done it for 3yrs that he has owned it. The aircon and what not all works perfectly though. Is this the blend door on it way out? Or something worse?
Zagorich is offline
post #79 of 129 Old 07-11-2012, 08:30 PM
Dylan484
Could this possible fix the no air to my passenger side problem?
Dylan484 is offline
post #80 of 129 Old 07-12-2012, 01:41 PM
fumblefingers
2014 WK
No......no air on pass side sounds like blend door problem. This is caused by plastic door shaft breaking. There is a easy MOPAR fix that one can do. One needs for tools a plunge saw (Sonicrafter) or heat knife to cut the plastic housing neatly for access and about 10 ft of copper wire to run from the battery to the work area to rotate the door actuator to the 2:00 position for easy insertion of the new blend doors. The kit comes with a template for cutting and I found that using a white magic marker allowed me to trace a visible line for cutting. Accurate cutting is necessary so that one does not puncture the evaporator coil which is near the access that one makes. The repair cost about $100 which is much cheaper than the $800 that the dealer wanted and the new blend doors had metal shafts. After repair the system needs to be calibrated using the AZC procedure.
post #81 of 129 Old 07-12-2012, 01:49 PM
fumblefingers
2014 WK
Originally Posted by Roosky81 View Post
What's better to use, 7mm Allen Key or what size Torx?
It is easier if you use a nut driver.
post #82 of 129 Old 07-12-2012, 01:54 PM
Dylan484
Blend doors only determine the mixture of hot to cold air right?
Dylan484 is offline
post #83 of 129 Old 07-12-2012, 07:13 PM
HVACNY
2013 WK
Yes
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #84 of 129 Old 07-12-2012, 10:57 PM
Dylan484
So why would that effect only my passenger side vents?
Dylan484 is offline
post #85 of 129 Old 07-18-2012, 06:56 PM
CrutchfieldMark
Thanks, what a thorough set of posts.
What fits your Jeep?? Find out below!!
CrutchfieldMark is offline
post #86 of 129 Old 07-28-2012, 03:34 PM
grecoroman33
Need Help ASAP
Hey guys-
Could anyone provide some brief directions from the point after the glove box is removed? How do you get access to remove the blower motor?
Thanks in advance.
Last edited by grecoroman33; 07-28-2012 at 03:43 PM. Reason: How do I remove the Blower Motor????
grecoroman33 is offline
post #87 of 129 Old 07-28-2012, 07:09 PM
fumblefingers
2014 WK
Blower motor is a squirrel cage under glove box held in place with 3 brass torx screws. Once screws removed, blower will drop down. It may be easier to reach one of the torx screws by removing the right foot pannel which is held in place with one screw. A nut driver is easier to use than a torx bit as the screws will fall out when loose. No need to disconnect electrical unless replacing blower.
post #88 of 129 Old 08-20-2012, 01:50 PM
grecoroman33
Thanks so much. I had taken the Jeep to two different mechanics, and neither were able to figure out the problem. With this tutorial I was able to fix in about 15 minutes.
post #89 of 129 Old 03-19-2013, 11:14 AM
robrilla
So how do you "correctly" fix the recirculation door problem? I'm taking apart the dash anyway to repair codes 54 / 56.
Thanks,
-Rob
robrilla is offline
post #90 of 129 Old 03-19-2013, 11:45 AM
reneveah
2003 WJ
Thank you thank you omg thank you!! Haha iv been on contact recirc for 3 years and damn it fogs up bad, this will fix that
03 Jeep WJ Overland>
91 Ford Taurus>
reneveah is offline
Recirculation Door Broken 2002 No Air schaebs ZJ Grand Cherokee Forum 0 01-29-2010 06:40 PM
Any NEW recirculation door fixes? Merc1973 ZJ Grand Cherokee Forum 1 01-21-2010 12:37 PM
recirculation button oscar_3 WK Grand Cherokee & XK Commander Forum 2 12-11-2007 07:07 AM
Recirculation Door 02grandchee ZJ Grand Cherokee Forum 3 08-17-2006 02:08 PM
Air Recirculation Broken Plysskin ZJ Grand Cherokee Forum 3 05-31-2006 07:09 AM
