Wj rear wheel bearing - JeepForum.com
post #1 of 14 Old 05-20-2013, 09:45 PM Thread Starter
Brandonsdad02
I'm doing my drivers rear wheel bearing right now and after cutting the old ones off and pressing the new ones on, the backing plate seems to be really loose. It won't stay centered on the axle so when I try to slide the axle back in, the 4 studs for the plate won't go in the holes. There seems to be at least a half inch of space from the backing plate and axle seal to the bearings. Did I not get it pressed on all the way?
Brandonsdad02 is offline
post #2 of 14 Old 05-21-2013, 07:12 AM Thread Starter
Brandonsdad02
Anyone?
post #3 of 14 Old 05-21-2013, 07:20 AM
3JsWJ
The bearing gets pressed on until it bottoms out on the shaft. You should be able to see this. Not letting the plate studs reach the holes would mean it is on too far, which is impossible. A pic here would really help.
04 WJ-4.7, 242HD, JK D44, JK HP30, 4" IRO, LSR Bumper, Warn M8000, 33" MTZ
03 WJ-SOLD
3JsWJ is offline
post #4 of 14 Old 05-21-2013, 10:56 AM Thread Starter
Brandonsdad02
The plate studs won't reach because the spacer in front on the bearing wont let the shaft go in far enough because its not pressed on enough. I brought the axle shaft to work with me and I'm going to use our 30 ton press to finish the job. I simply just didn't get it pressed on far enough
post #5 of 14 Old 05-21-2013, 07:52 PM Thread Starter
Brandonsdad02
Well I tried today at work to get it pressed on and i couldn't do it. I took it to a machine shop where they work on farm equipment. He said with a little heat it should go on the rest of the way. Anyone else ever had to use heat to get the bearing pressed on?
post #6 of 14 Old 05-21-2013, 07:58 PM
pinky2252s
I have heard of the opposite, freezing the shaft and then pressing the bearing on to make it easier.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #7 of 14 Old 05-21-2013, 08:13 PM
WiLieR
Heat the bearing and it will slide on easier.
Tossed onto the interwebs via iPhone
99 WJ Laredo - Mine once again!
WiLieR is offline
post #8 of 14 Old 05-21-2013, 08:14 PM Thread Starter
Brandonsdad02
That's the problem, it's already pressed on most of the way, just needs to go about a half inch more
post #9 of 14 Old 05-22-2013, 12:56 AM
alfaitalia
I always put mine on by hand...no press. Have done three as one of the new ones was faulty. Just use the old collar as a drift and bash it on with a few good hits of a good size lump hammer. Easy. The last one I did with no heat or cold as I was in a hurry and it was not that much more difficult to drive on.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #10 of 14 Old 05-22-2013, 05:30 AM Thread Starter
Brandonsdad02
Will heating it ruin the bearing?
post #11 of 14 Old 05-22-2013, 03:58 PM
alfaitalia
We are not talking blow torch here! I put the bearing in the oven at 200c for 20mins and the shaft in the freezer for an hour. Dropped the bearing on and it only took half a dozen taps with the hammer and drift to seat it. Obviously I repacked the bearing with grease before shaft went back in axle.
post #12 of 14 Old 05-22-2013, 04:46 PM
Galaxie500LTD
That's cool Did you put the retainer ring on right away? or refreeze, then do the retainer separately?
2001 WJ V8 QuadraDrive Stock
1966 Ford Galaxie 500 LTD, 390 CI (6.4L) V8 4V, two door hard top, black on black
Galaxie500LTD is offline
post #13 of 14 Old 05-22-2013, 06:26 PM
pinky2252s
Makes sense. Honestly I was thinking of some guy in a shop blasting the bearing with a blow torch...
Is it broken?
post #14 of 14 Old 05-22-2013, 08:34 PM Thread Starter
Brandonsdad02
Just got it back from the machine shop. It ended up being seated on all the way. My mistake was not taking the rotor off so I could line up the backing plate. Once the rotor was off, it was easy to do. Learn something new everyday.
