WJ Rear sway bar upgrade - JeepForum.com
post #1 of 25 Old 11-04-2003, 07:35 PM Thread Starter
chuma_1
Hi All,
I am thinking about upgrading my rear sway bar to the ADDCO heavy duty bar. I am told this removes a lot of body roll and movement and improves handling.
Has anyone else in this forum done this? What were the results?
Cheers
Chuma
2000 WJ Grand Cherokee Laredo.
chuma_1 is offline
post #2 of 25 Old 11-04-2003, 08:17 PM
Bob K
Bob K's Avatar
The write-up sounds really good. http://www.wjjeeps.com/swaybars.htm
I'm very interested. But $235 is a lot of money for a piece of bent metal. I'll be curious to hear first hand accounts.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 25 Old 11-05-2003, 07:16 AM
SteveinDFW
Since when did it go to $235? Got mine for $125 from kolak on JU. While the Addco rear sway improves performance on road, (one of the better mods i've spent money on) it will dampen performance offroad, it unhook mine while off. It is a worth while investment...that is all
SteveinDFW is offline
post #4 of 25 Old 11-05-2003, 12:31 PM
Bob K
Bob K's Avatar
I got that price off of Addco's website. Please tell me more about where you ordered yours. You feel the on-road improvement is as good as they claim?
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Bob K is offline
post #5 of 25 Old 12-20-2013, 04:11 PM
AntZ57
I have a 4in lift on my 01 WJ and I want to upgrade the front and rear sway bars would I have to get new links as well? Also does anyone have any suggestions on what brand to go with?
AntZ57 is offline
post #6 of 25 Old 12-20-2013, 04:43 PM
Thomahawk
^^^yes endlinks length will need to be correct for your lift to keep the endlink swaybar working angle correct.
And YES!!!! It reduces bodyroll and highway stability, at stock height it cornered as a sportscar, with the 2" lift, it was also impressive handling curves
I think the rear one makes the most difference, as That bouncy *** needs to be controled.
Highly recomended mod!
Always Get my parts from santa Kolak
Buildthread
Thomahawk is offline
post #7 of 25 Old 12-20-2013, 05:33 PM
Tollmtn
Originally Posted by chuma_1 View Post
Hi All,
Cheers
Chuma
Your front bar may look big but from 1999 to late 2003 the front bars were hollow. It is not a good idea to have a rear bar as strong as your front bar, it messes up weight transfer when cornering.
So for other than 2004 WJs to get the best handling you should upgrade your front bar first. You can either buy Addco's solid front bar or buy a 2004 WJ bar that is also a solid front bar from a wrecking yard. The 04 bar is about 1/16" smaller than an ADDCO bar but it is forged so it is likely very close to Addco bar in stiffness. For our friends across the pond, all the export WJs with diesel engines have a different part number, I believe they have solid bars but can not confirm that.
Tollmtn is offline
post #8 of 25 Old 12-20-2013, 05:36 PM
jmahle67
I was having major rear end sway while braking and the addco bar majorly improved that. A definite upgrade. I would check price on amazon too
jmahle67 is offline
post #9 of 25 Old 12-20-2013, 06:07 PM
Darnice
Tried it, dumped it, went back to stock. They bang and rattle over every bump. Also, some people have actually torn the mount and cracked the unibody frame from using the bar. Too bad your not in southern ontario canada, I would give you the bar for free.
Darnice is offline
post #10 of 25 Old 12-20-2013, 08:17 PM
Planetcat
2010 WK
I've got about 50K miles on both front and rear Addco swaybars. A dramatic improvement over the stock coat hanger ones. Some good shocks will help too.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #11 of 25 Old 12-20-2013, 11:36 PM
Kolak
Vendor
Kolak's Avatar
Send me a PM if you'd like information about the Addcos. I've been an Addco dealer for their Jeep products for over 15 years and would be happy to answer technical questions and I have good pricing too.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #12 of 25 Old 12-20-2013, 11:58 PM
texlurch
Definately check your front bar; doesn't seem to be any rhyme or reason as to which bar is installed.
If it's the hollow one, the solid or Addco front bar makes the most difference
Also be aware you need spacers on the rear Addco or it will rub on the cover.
If mine spent all the time on the pavement I would add the rear, but it most definately limits flex and has been known to rip out the stock mounts offroad.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #13 of 25 Old 12-21-2013, 07:57 PM
jbaldry
Does the addco/2004 front sway bar limit off road ability. And does anyone else have good things to say about upgrading the front?
2000 Jeep Grand Cherokee Limited, Quadradrive, 4.7 V8
Living life mod by mod
jbaldry is offline
post #14 of 25 Old 12-21-2013, 08:06 PM
mycreativename
Any thicker/stiffer sway bar will limit off road ability while connected, however you can simply unbolt them and tie them up out of the way to disconnect them and then your WJ will flex like Arnold at a strong-man competition. You can also purchase commercially made quick disconnects which make it a simple pin pull to disconnect rather than unbolting. Personally I don't mind spending five minutes disconnecting rather than spending (what I believe to be) too much money on those.
My Addco does not rub on the cover at all. That is only an issue if you have a larger cover I thought. And the only times I've heard of it ripping out stock mounts was when incorrect link length was used.
Also why not just disconnect offroad? (Not trying to pick on you, genuinely asking) Of the time spent on road, my Addco makes a ton of difference, but offroad I agree it limits flex a ton, which is why I just unbolt the links from the bar before getting on the trail.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #15 of 25 Old 12-21-2013, 08:09 PM
jbaldry
Ok I just remembered the front you can get quick disconnects so forget about the off road question. But does it still help on road?
jbaldry is offline
Rear bushing slipping out after Addco rear sway bar install n8man1068 ZJ Grand Cherokee Forum 3 08-04-2009 02:27 PM
Upgrade Rear Sway Bar? steve0410 ZJ Grand Cherokee Forum 8 05-20-2009 09:19 PM
WJ series upgrade sway bars ADVICE PLEASE Vette71 ZJ Grand Cherokee Forum 7 08-15-2008 12:25 PM
WJ Rear Sway Bar WJMex ZJ Grand Cherokee Forum 30 10-26-2006 08:03 AM
upgrade rear sway bar laredo 01 sylbarr ZJ Grand Cherokee Forum 12 04-03-2005 06:36 PM
