wj rear end swap - JeepForum.com
post #1 of 13 Old 07-27-2010, 08:28 PM Thread Starter
zuki
wj rear end swap
Hello all, new to this so don't laugh, I have a 1999 grand cherokee that has a shot ring and pinion gear. I don't have alot of money right now so I'm looking to go as cheap as possible. Should I rebuild or swap from salvage yard? I don't think I can set the new gears myself. If salvage I can swap myself, but I cannot for the life of me find a rear end for this thing. It has a dana 35 selec-trac. Any suggestions? Is there another jeep model that uses the same rear end? Should I just pull it and rebuild the whole darn thing? I'll buy the beers!
zuki is offline
post #2 of 13 Old 07-27-2010, 08:50 PM
StrokedWJ
StrokedWJ's Avatar
Search car-part.com for a used axle. The WJ axle is unique so you will only find it in other WJ's. Look for WJ's with the 4.0 to get the D35. Most of them will have 3.55's but a few will have 3.73's, so just make sure the ratio match (if yours is 4wd). If you have 2wd, the gear ratio shouldn't matter.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 13 Old 07-27-2010, 08:52 PM Thread Starter
zuki
ok thanks, it has 3.73's so i guess its rare? anyways thanks for the advice
zuki is offline
post #4 of 13 Old 07-27-2010, 09:06 PM
GraKee99
Rapist Wit
GraKee99's Avatar
If you have 3.73, you can get a D35 with those gears (might be hard to find) or a Dana44a out of a V8 grand. They all had 3.73 so one of those would work.
Where you from in Arkansas?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #5 of 13 Old 07-27-2010, 09:31 PM
sicWJofNWA
fayetteville
sicWJofNWA is offline
post #6 of 13 Old 07-27-2010, 09:39 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Originally Posted by sicWJofNWA View Post
fayetteville
Was asking the OP because there is that u-pull-it in Little Rock he could go to. I have seen a few WJs there from time to time.
And cool, just graduated from school there in December. Born and raised in Little Rock. If you aren't, join up with rockcrawlers4x4.com. Great group of guys, I still check in from time to time and rocktoberfest is coming up soon. Always a blast.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #7 of 13 Old 07-27-2010, 10:40 PM
sicWJofNWA
oh dude i am so stoked for rocktoberfest. its gonna be awesome
post #8 of 13 Old 07-28-2010, 09:11 AM Thread Starter
zuki
turns out i have a selec-trac dana 35 3.55 gears, if any body knows what vehicles interchange with that will be helpful.
also, i used to be a member of the rockcrawlers club when i had my sammy
i'll try and get in touch with someone there too. thanx
zuki is offline
post #9 of 13 Old 07-28-2010, 09:23 AM
drwolcot
on vehicle you can get that from is another WJ with the d35 and 3.55 gears..... d35 only came with models with the 4.0... so you should be able to find any 4.0 WJ 2wd or 4wd and swap unless it came with the tow package and then it had 3.73 gears
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #10 of 13 Old 01-07-2013, 07:50 AM
rhediger
Related Q:--Will i be able to directly swap an rear diff from an 03 WJ into my 01? Both are D44's, with 3.73 gears. I don't see any reason why it shouldn't work out, but thought i'd get a 2nd opinion.
Gracias amigos
rhediger is offline
post #11 of 13 Old 01-07-2013, 07:57 AM
adavis39
Gracias amigos
yes...they are all the same
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #12 of 13 Old 01-07-2013, 08:01 AM
CoastieShep
Don't forget, selec-trac is the transfer case. Nothing to do with the axles.
CoastieShep is offline
post #13 of 13 Old 01-07-2013, 05:47 PM
shockracer
Also may look at if either one has veri-lock diff, just an FYI.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
grand cherokee , jeep , wj
3.5 F>R swap now rear sag zjdamien ZJ Grand Cherokee Forum 23 05-19-2010 06:49 PM
Rear end swap abe51 ZJ Grand Cherokee Forum 18 08-02-2009 11:32 AM
Swap offset rear d60 into WJ? wheelNC93 ZJ Grand Cherokee Forum 27 10-17-2007 11:45 AM
Rear hatch swap...96 onto a 94 rxl ZJ Grand Cherokee Forum 1 07-18-2007 10:02 AM
Rear end swap ?'s jeepman75 ZJ Grand Cherokee Forum 9 10-16-2006 10:50 AM
