-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   wj rear end swap (http://www.jeepforum.com/forum/f310/wj-rear-end-swap-1077858/)
zuki 07-27-2010 08:28 PM
wj rear end swap
Hello all, new to this :confused: so don't laugh, I have a 1999 grand cherokee that has a shot ring and pinion gear. I don't have alot of money right now so I'm looking to go as cheap as possible. Should I rebuild or swap from salvage yard? I don't think I can set the new gears myself. If salvage I can swap myself, but I cannot for the life of me find a rear end for this thing. It has a dana 35 selec-trac. Any suggestions? Is there another jeep model that uses the same rear end? Should I just pull it and rebuild the whole darn thing? I'll buy the beers! :cheers2:
StrokedWJ 07-27-2010 08:50 PM
Search car-part.com for a used axle. The WJ axle is unique so you will only find it in other WJ's. Look for WJ's with the 4.0 to get the D35. Most of them will have 3.55's but a few will have 3.73's, so just make sure the ratio match (if yours is 4wd). If you have 2wd, the gear ratio shouldn't matter.
zuki 07-27-2010 08:52 PM
ok thanks, it has 3.73's so i guess its rare? anyways thanks for the advice
GraKee99 07-27-2010 09:06 PM
If you have 3.73, you can get a D35 with those gears (might be hard to find) or a Dana44a out of a V8 grand. They all had 3.73 so one of those would work.
Where you from in Arkansas?
sicWJofNWA 07-27-2010 09:31 PM
fayetteville
GraKee99 07-27-2010 09:39 PM
Originally Posted by sicWJofNWA (Post 9862407)
fayetteville
Was asking the OP because there is that u-pull-it in Little Rock he could go to. I have seen a few WJs there from time to time.
And cool, just graduated from school there in December. Born and raised in Little Rock. If you aren't, join up with rockcrawlers4x4.com. Great group of guys, I still check in from time to time and rocktoberfest is coming up soon. Always a blast.
sicWJofNWA 07-27-2010 10:40 PM
oh dude i am so stoked for rocktoberfest. its gonna be awesome
zuki 07-28-2010 09:11 AM
turns out i have a selec-trac dana 35 3.55 gears, if any body knows what vehicles interchange with that will be helpful.
also, i used to be a member of the rockcrawlers club when i had my sammy:)
i'll try and get in touch with someone there too. thanx
drwolcot 07-28-2010 09:23 AM
on vehicle you can get that from is another WJ with the d35 and 3.55 gears..... d35 only came with models with the 4.0... so you should be able to find any 4.0 WJ 2wd or 4wd and swap unless it came with the tow package and then it had 3.73 gears
rhediger 01-07-2013 07:50 AM
Related Q:--Will i be able to directly swap an rear diff from an 03 WJ into my 01? Both are D44's, with 3.73 gears. I don't see any reason why it shouldn't work out, but thought i'd get a 2nd opinion.
Gracias amigos
adavis39 01-07-2013 07:57 AM
Gracias amigos
yes...they are all the same
CoastieShep 01-07-2013 08:01 AM
Don't forget, selec-trac is the transfer case. Nothing to do with the axles.
shockracer 01-07-2013 05:47 PM
Also may look at if either one has veri-lock diff, just an FYI.
The time now is 06:08 AM.
