WJ rear coil springs - How strong and resistible they are to heavy load? - JeepForum.com
post #1 of 8 Old 10-29-2003, 11:40 AM Thread Starter
SBrudzinsky
SBrudzinsky's Avatar
Question WJ rear coil springs - How strong and resistible they are to heavy load?
Hi everyone!
I need your thoughts on this.
I'm planning to buy some new home appliances and most likely will transport them one by one in my cargo compartment. Some appliances are relatively heavy (refrigerator, oven, and so on..). Is there any way that I can privent rear-end sagging that I assumed can occur afterwards? Or Jeep's rear coil springs are strong enough to resist heavy load up to allowable/recommended by manufacturer maximum load weight? Any ideas? Any experience with?
Thank you!
SBrudzinsky is offline
post #2 of 8 Old 10-29-2003, 05:17 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I really don't think that a refrigerator will fit yet, I wouldn't put something that heavy back there.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 8 Old 10-30-2003, 09:38 AM
RED01TJ
You have nothing to worry about. I towed a a 5000 pound trailer from Alaska to the midwest, the jeep barely sagged with the weight
2001 Jeep Wrangler. 4.0, 5 speed. rubicon express 5.5" 1" body lift, 1" mml, 35x12.5 Goodyear MT/R's, 4.56 gears 8.8 in the rear w/ARB true-trac upfront,warn F/R bumpers w/tire carrier, warn M8000
2003 WJ 2.5" Anthonys BB, 265/70/17 BFG AT's, Qaudradrive, the rest still in the planning stage
RED01TJ is offline
post #4 of 8 Old 10-30-2003, 10:03 AM Thread Starter
SBrudzinsky
Originally Posted by Texas ZJ1
... I wouldn't put something that heavy back there. ...
Why not? Are there any specific reasons?
The refrigerator has about ~360 - 400 lbs. net weight. Is that too much for cargo compartment load?
Just curious ...
post #5 of 8 Old 10-30-2003, 10:08 AM
RED01TJ
If you can get it to fit, in the back. Your payload max is 1000 lbs(cargo and pass)
RED01TJ is offline
post #6 of 8 Old 10-30-2003, 10:31 AM
97RedBird
2009 MK Compass
I've had a dishwasher and washing machine at two different occasions. If the refrig. will fit, the jeep can handle it. The only thing to watch is if you are at max capacity, take it easy on corners, accelerations, and decelerations and your jeep will be okay. Definitly no off roading with the refrig. in the back and you will be fine.
97RedBird is offline
post #7 of 8 Old 10-30-2003, 11:35 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I was thinking of like a 21 cubic ft frig. If you can fit it back there, go for it.
Of course, I had a huge generator, two coolers, and towed a 15 ft camper to gse. Yeah, the springs will take it.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #8 of 8 Old 10-30-2003, 09:35 PM Thread Starter
SBrudzinsky
Originally Posted by RED01TJ
.... Your payload max is 1000 lbs(cargo and pass)
Yes, I know that and this part is a bit confusing. The certification label attached to the driver's side door pillar says that GVWR (Gross Vehicle Weight Rating) is about 5,450lbs and Rear GAWR (Gross Axle Weight Rating) is 2,950lbs, and the manual says "load weight should not exceed the GVWR and F/R GAWR.
If load weight should not exceed the GVWR does that mean that I can load vehicle more than recommended "max. Payload"?
So, what's the correlation between "payload" and “GVWR”?
Smoking under heavy load ZeJokee ZJ Grand Cherokee Forum 8 08-26-2009 10:23 PM
99 WJ OME Heavy duty coil question Coops ZJ Grand Cherokee Forum 8 08-25-2009 09:33 AM
WJ Coil Springs MeWJWifeZJ ZJ Grand Cherokee Forum 3 05-13-2009 12:41 PM
WJ Heavy Duty Coil Springs BucYouUp68 ZJ Grand Cherokee Forum 6 08-18-2007 06:49 PM
Up Country springs vs. Quadra Coil Springs JGC03WJ ZJ Grand Cherokee Forum 7 04-01-2007 07:00 PM
