WJ Rear Axle Swap - Page 2 - JeepForum.com
post #16 of 37 Old 02-17-2005, 10:09 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The Super 35 won't work for the Wj. It does however work very well for those of us who use them.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #17 of 37 Old 02-17-2005, 05:51 PM
cajunmudder
cajunmudder's Avatar
Somebody find some custom 30 spline shafts and a locker that will work with them and weld up a truss- Super Custom 35
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
Custom Fiberglass Box
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
Dunlop 265/75/16 mud rovers
cajunmudder is offline
post #18 of 37 Old 02-18-2005, 11:30 AM Thread Starter
ArmyWJ
Does anyone know of a axle that is close to 63.5" WMS?
Danny
2000 WJ Grand Cherokee Lerado.
ArmyWJ is offline
post #19 of 37 Old 02-21-2005, 09:53 AM Thread Starter
ArmyWJ
Ok I found the wheel mounting serface (wms) of the D35 it is 63.5".
What is the WMS for the D30 up front?
Danny
ArmyWJ is offline
post #20 of 37 Old 06-29-2005, 07:56 AM
Bariga
I have a 1999 wj from early in the year of production.
I had Diff noise and brought it in to Minot Motorworks in Marshfield, MA and they have "fixed" it twice. The hum goes a way for a little while then comes back. This most recent time it only Hums at certain speeds. Every time I talk to the guy he says "it's jeep" "jeep sucks" others just say the 99 wj has a bad diff. Wouldn't that have been taken care of if it were "fixed"?
Well I know the jerk has been ripping me off and that is why I have started doing my own work, at least the very simple stuff. I would sue but I don't really want to mes around with this hack, If he can prey on poor people like me, he probably has a way to defend himself.
I am hoping to start improving the drive train then lifting the WJ a bit.
What should I do about this Diff problem? I was thinking about a swap because that "swap-ability" is what I love about jeeps. I'm broke and I won't have the ability to rebuild the one that is in it now so I think it would be best to get one that is ready to go.
What would be the smartest most plug and play swap for a better rear end?
Bariga is offline
post #21 of 37 Old 06-29-2005, 08:40 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
the D44a is the easiest swap from the D35c, and if you have a D44a, the D35c swap is the easiest What axle do you have right now? In your sig post the stats on your Jeep (Year, Model, Engine, and Transfercase). Putting in a Ford 8.8 is the most popular alternative axle I have seen used. It isn't just plug and play though, as far as I know (AFAIK) you have to weld on some mounting brackets for springs/shocks etc..
-Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #22 of 37 Old 06-29-2005, 10:03 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by ArmyWJ
Any clue what the WMS is for the 9"? I was told that the WJ's wms is 63.5".
It depends...there are a ton of different 9"s out there.
Wheelin98TJ is offline
post #23 of 37 Old 06-29-2005, 01:11 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
The D44a is a strong axel. It is the same as the reg D44 only it has an aluminum housing. The only bad thing about running this axel is there is no locker for it. But if you get one from a WJ with quadradrive it will have LSD. Also it is a direct swap becuase it is from a WJ...
2013 FR-S
BlaineWasHere is offline
post #24 of 37 Old 06-29-2005, 02:35 PM
PumaZJ
this guy gave up on building his WJ back in february. just a little FYI.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #25 of 37 Old 06-29-2005, 09:52 PM
BlaineWasHere
BecauseRacecar
Someone brought it back and we started talking about it again.
2013 FR-S
post #26 of 37 Old 06-30-2005, 05:50 AM
wreck76
wreck76's Avatar
so if i change my rear to a towing package dana44 (currently have 3.55 in the back), do i have to worry about my front diff gearing too? (selec-trak tc)
wreck
-I am a man. And I can change. If I have too. I guess.-
Red Green
Canadian Jeep Club Member#17
wreck76 is offline
post #27 of 37 Old 06-30-2005, 07:11 AM
01grander
If you dont plan on using 4wd then you dont have to worry about it. But like most of us use 4wd then yes you would have to get the front regeared. You could technically use it in really heavy muck b/c you wouldnt be getting any traction but as soon as you get good traction on both back and front your in trouble. Think about it this way your wheels would be going at 2 diff paces and if thats on an ideal traction surface then it def wouldnt be a good thing.
01 Grand Cherokee Laredo 4.0
245/75r16's w/ 2" of lift
ARB and Surco roof rack
Plenty of Hellas.
01grander is offline
post #28 of 37 Old 06-30-2005, 07:12 AM
ArloGuthroJeep
Mr. Hyde!
Yes, otherwise the second you engaged 4wd your fronts would be spinning faster then your rear, but a lot. Front and rear gearing need to match (or be very close like 4.10 and 4.11).
-Ryan
post #29 of 37 Old 06-11-2013, 12:58 PM
Gabedingoxx
2003 WJ
if you run the d44hd that you can get out of the v8 dubjs there is one Spartan locker you can put in
Gabedingoxx is offline
post #30 of 37 Old 06-11-2013, 03:04 PM
PolkaPower
PolkaPower is offline
Dana 44 Axle Swap in Rear of WJ --WJ-- ZJ Grand Cherokee Forum 18 12-03-2009 03:04 PM
Another try at a Rear Axle swap zjilla ZJ Grand Cherokee Forum 7 02-22-2009 03:28 PM
rear end/axle swap rannej ZJ Grand Cherokee Forum 5 11-29-2008 01:21 AM
9.25 Rear Axle Swap for WJ? StrokedWJ ZJ Grand Cherokee Forum 7 10-12-2008 02:43 AM
D35 to D44 Rear Axle swap Q's GrandFormer2134 ZJ Grand Cherokee Forum 15 12-21-2006 09:08 PM
