WJ Rear Axle Swap - JeepForum.com
post #1 of 37 Old 02-16-2005, 04:11 PM Thread Starter
ArmyWJ
WJ Rear Axle Swap
I did a seach and cannot find anything about this. I have a 2000 WJ with the Dana 35C rear axle. I want to swap in a stronger rear axle, I was thinking about a ford 8.8. But i was told by a 4x4 shop and Clayton Off Road Mfg said the WMS on a Wj is wider than a ZJ. I know if you put a ford 8.8 into a ZJ you need 3/4" spacers on each side. I also know that the ZJ is a 5x4.5" and a WJ is a 5x5" lug pattern and the Dana 35C is 57" from backing plate to backing plate. What options do I have besides calling Dynatrac and spending $4000 for a new axle.
Thanks for the help.
Danny
2000 WJ Grand Cherokee Lerado.
ArmyWJ is offline
post #2 of 37 Old 02-16-2005, 05:11 PM
mr_user
Army man,
Over on JeepsUnlimited I believe Puma was the one who did an 8.8 swap just yesterday. Their server is down right now but I'll get you that link as soon as I come across it. He got the 8.8 of a wrecked Merc Mountaineer from the boneyard and seemed to go very well. Probably about 800 bucks in total.
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #3 of 37 Old 02-16-2005, 06:13 PM
LJ_Cool
2003 WJ
I beleive you can get a D44a from a Limited/laredo with Quadra drive, (tow package if you want 3.73s) you will get a slightly stronger axle and a LS, and it shouldn't cost you 4K, and you don't have to worry about your bolt pattern.
Anything else will require significant mods to fit, since WJ's have the center upper link on the pumpkin.
Regards
03 WJ Limited, 04 Overland
LJ_Cool is offline
post #4 of 37 Old 02-16-2005, 06:21 PM
cajunmudder
cajunmudder's Avatar
Would a super 35 kit work?
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
Custom Fiberglass Box
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
Dunlop 265/75/16 mud rovers
cajunmudder is offline
post #5 of 37 Old 02-16-2005, 07:23 PM
mr_user
Yep the Super 35 would work very well.
IIRC, that's what Hunter's running.
mr_user is offline
post #6 of 37 Old 02-16-2005, 07:27 PM
PumaZJ
dont bother with the super 35 kit. they're plenty good for TJ's and lighter rigs but not so much on our ZJ's/WJ's.
If you want somethin beefy find a 9" out of an older ford truck and build it up to put under your WJ. They can be found w/ the 5.5 bolt pattern so that wont be a problem. I know ur in NC also so if you need any help or advice just shoot me an IM on Puma297 or private message.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #7 of 37 Old 02-16-2005, 07:41 PM Thread Starter
ArmyWJ
puma what im yahoo or aol?
Danny
ArmyWJ is offline
post #8 of 37 Old 02-16-2005, 07:45 PM
PumaZJ
AOL instant messenger
2011 A4 - DD
PumaZJ is offline
post #9 of 37 Old 02-16-2005, 07:49 PM
cajunmudder
I am thinking about doing a 9 inch swap, only thing is the driveshaft has to come off to change the fluid.
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
post #10 of 37 Old 02-16-2005, 07:56 PM
PumaZJ
9" are definatley beef. Removable 3rd members are the new hotness.
2011 A4 - DD
PumaZJ is offline
post #11 of 37 Old 02-16-2005, 08:01 PM Thread Starter
ArmyWJ
whats the wms of a d35 and a 9"?
Danny
ArmyWJ is offline
post #12 of 37 Old 02-16-2005, 08:04 PM
cajunmudder
No clue but you can get ANYTHING for a ford 9 inch, they are used a lot in street rods and race cars, between them and quick changes thats all you see.
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
post #13 of 37 Old 02-16-2005, 10:59 PM
Trailzj
Are you saying that the driveshaft having to be removed in order to change the fluid is effecting whether or not you will do the swap?
Al
2 1/2" lift on 33" Pro Comp Xterrains
I traded my ZJ for an AR15
Function before fashion
Trailzj is offline
post #14 of 37 Old 02-17-2005, 05:52 AM
cajunmudder
No I'm just saying its not as easy as taking off the diff cover on the back.
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
post #15 of 37 Old 02-17-2005, 07:09 AM Thread Starter
ArmyWJ
Any clue what the WMS is for the 9"? I was told that the WJ's wms is 63.5".
Danny
ArmyWJ is offline
Dana 44 Axle Swap in Rear of WJ --WJ-- ZJ Grand Cherokee Forum 18 12-03-2009 03:04 PM
Another try at a Rear Axle swap zjilla ZJ Grand Cherokee Forum 7 02-22-2009 03:28 PM
rear end/axle swap rannej ZJ Grand Cherokee Forum 5 11-29-2008 01:21 AM
9.25 Rear Axle Swap for WJ? StrokedWJ ZJ Grand Cherokee Forum 7 10-12-2008 02:43 AM
D35 to D44 Rear Axle swap Q's GrandFormer2134 ZJ Grand Cherokee Forum 15 12-21-2006 09:08 PM
