WJ Quadra-Drive & RC 4" X-Series lift - JeepForum.com
post #1 of 26 Old 06-21-2010, 02:43 PM Thread Starter
sno
Junior Member
Does anyone run this setup?
The Rough Country website says the kit won't fit "AWD Models" and the Quadra-Drive system possesses a 4-All Time option, as well as Neutral and 4-Lo. The NV247 transfer case used by the Quadra-Drive system is the same as the Quadra-Trac II, which has the option for 4-Lo, Neutral, and 2wd, right? The only other option is the Quadra-Trac I which doesn't have 4-Lo or Neutral (NV147 transfer case).
I can't find any information anywhere.
sno is offline
post #2 of 26 Old 06-21-2010, 04:33 PM
platinum5.9
2003 WJ
there is no reason i can see as to why it would matter...I run 3.5" lift with quadra drive!
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #3 of 26 Old 06-21-2010, 04:35 PM
KDog223
I can't imagine why they would say it wouldn't fit AWD models. Just get the Zone kit, it worked for me.
KDog223 is offline
post #4 of 26 Old 06-21-2010, 04:44 PM Thread Starter
sno
Junior Member
I got a reply from Ryan @ RC. He says that as long as I have the options for 4-Lo and Neutral, it will fit. I guess that means the NV247 transfer case fits but the NV147 transfer case does not.
sno is offline
post #5 of 26 Old 06-21-2010, 05:06 PM
xJoshxx
2012 WK
There is no difference the Front drive shaft might be the difference hell they put 4wd lifts on 2wd jeeps kthx
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 26 Old 06-21-2010, 05:28 PM Thread Starter
sno
Junior Member
Your post is misleading...
sno is offline
post #7 of 26 Old 06-21-2010, 06:37 PM
metalhead
2011 WK
I saw that remark about the awd on rough country's site too. I am still debating on 3 or 4 inches but mostly it depends on if I can get it in and out of the garage door openning is only 78 inches high. Don't see what the problem would be everyone else that offers 4 inch kits don't have that statement.
metalhead is offline
post #8 of 26 Old 06-21-2010, 09:25 PM Thread Starter
sno
Junior Member
Yeah, I'm not sure why they say that it won't fit but I'll trust their judgment.
sno is offline
post #9 of 26 Old 06-22-2010, 12:06 AM
ZJ5point2GCL
the only reason they say to not lift awd jeep is because if you have warn u-joint in the front driveshaft, of your pinion angle isn't as good as it should be, your more prone to get vibrations that you wouldn't of at stock height.
right now i am waiting for adjustable front upper control arms to ship, but in 2wd i have no vibrations except for deceleration vibrations, but i have a bad vibration in either 4by mode.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #10 of 26 Old 06-22-2010, 09:50 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
This is the setup I ran. I have since swapped out my transfer case with a 242. The quadra drive and quadra trac II are the exact same TC, both with 4wd, N, and 4-low. The only difference between the two systems is the quadra drive comes with vari-loc diffs front and rear, while the quadra trac II has open diffs.
There is absolutely no reason why it wouldnt "fit." The suspension geometry is exactly the same between models with a 247 TC and a 242 TC. The only issue you MIGHT have is that your front pinion angle may be too far off causing some drive line vibes (I dont have this issue, but some people do.) Some adjustable front upper control arms will fix that and no 4" kit on the market comes with adj front uppers. There is nothing in this kit that would make it "not fit" that is different than any other 4" kit on the market. In fact, this is one of the few kits (if not the only kit) that comes standard with an adjustable track bar and adjustable front lower CAs.
It is by far the best bang for your buck, especially if you order it through casanova4x4. Shoot him a PM and see what kind of discount he can get you. I got my kit from him, with a new steering stabilizer, shipped to my door for under $700.
~James
ezflip is offline
post #11 of 26 Old 06-22-2010, 11:14 AM
Th0r
I'm running a 4" RC with Quadra-Drive and no issues
Th0r is offline
post #12 of 26 Old 06-22-2010, 11:20 AM
JJAMISON_
2015 JK Wrangler
I have a RCX 4" on my 04 WJ. no issues . you will just need to replace the front DS sometime later. I have the 247 tcase and no issues. i didn't think the 147 was in anything but WKs. recon this a bit and get back with me. I am curious now.
JJAMISON_ is offline
post #13 of 26 Old 06-22-2010, 12:19 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Correct, no WJ's came with the 147. The only cases WJ's came with are the 247 and 242.
~James
ezflip is offline
post #14 of 26 Old 06-22-2010, 12:43 PM
drwolcot
actually you can get the 147 transfer case in a WJ. I found some that had the trail rated badge but there is no shifter in the console but there is a front axle. The reason there is no shifter is because it is a single speed auto transfer case. It is like the 247 without the 4-low gear range. Jeep Grand Cherokee WJ - WJ Four-Wheel Drive Systems
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #15 of 26 Old 06-22-2010, 01:01 PM
RedJeep2002
2000 JK Wrangler
you have the same question I had so while I was at the rough country website I clicked on the live chat tab at the top of the page and asked why it wouldnt fit and they said that it will fit but it MAY vibrate while driving and he said I could buy different drive shafts to correct the vibration. and I plan on buying a wj soon and am going to be buying this lift kit and if it does vibrate than I will look for the right drive shafts.
RedJeep2002 is offline
2010 Grand Cherokee LTD Quadra Drive II or Quadra Track II hobbie1 WK Grand Cherokee & XK Commander Forum 6 10-06-2010 04:04 PM
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
'99 Quadra Drive "popping" noise Jeff_h ZJ Grand Cherokee Forum 3 05-13-2005 12:02 PM
