Wj Problem - JeepForum.com
post #1 of 11 Old 10-26-2013, 11:29 AM Thread Starter
sn95guy
Wj Problem
ok i have a 04 wj limited with the 4.7 in it. In the last few weeks its been sounding like water under the dash, i have been busy with work so have not checked into it, my wife called me the other day, said check engine light came on, and said #8 cylinder missfire. Well, i just got home, checked coolant, its a lil low, gonna top it off, but i had topped it off about 2 months ago on our road trip. Oil looks fine, no antifreeze in it. I am gonna take to dealer monday as we have 800 miles left on warrenty. It will prob be void since i did a lift on the jeep with bigger tires though. Anyone got any ideas or common problems? I know these are known for head gaskets, anything else?
sn95guy is offline
post #2 of 11 Old 10-26-2013, 11:43 AM
Thomahawk
Heater core, check if pass side floor carpet Are wet, might just be air in your system as well.
Buildthread
Thomahawk is offline
post #3 of 11 Old 10-26-2013, 01:40 PM Thread Starter
sn95guy
floor is dry
sn95guy is offline
post #4 of 11 Old 10-26-2013, 03:51 PM
RussFromJersey
Hmmm... I'm getting something similar though isntead of water, its more like air sound... like a slow air brake on a tractor trailer
Interesting to read about heater core. I noticed in the summer time I'd get a wet spot on the passenger floor mat... but that only happened with the A/C going, a passenger actually complained of water dripping down on their feet. Not running the A/C resulted in no water seeping. Any ideas?
RussFromJersey is offline
post #5 of 11 Old 10-26-2013, 08:12 PM
narnwv
narnwv's Avatar
That would be a clogged ac drain
Typing on phones sucks.
~Aaron
narnwv is offline
post #6 of 11 Old 10-28-2013, 10:11 AM Thread Starter
sn95guy
the dealer has the jeep right now, trying to say its a spark plug bad(270$ to fix) and air in the coolant.. total bs i already bled the system last night, its burning coolant somewhere, i have 800 miles left on the engine warranty. I am making them do pressure test to see if the head gasket is leaking. This dealer is a total joke, but while under warranty they will continue to work on it..
sn95guy is offline
post #7 of 11 Old 10-28-2013, 12:54 PM
Fellows45
Hahahahaha 270 bucks?! What a rip off... You can do that yourself for 12... One of the easiest things to do on a jeep..
2002 Jeep WJ, 4.7, EBC Stage 4 brakes, Bilstein shocks (Still In progress)
1989 Wrangler YJ 2.5, 2 inch body lift, 33 inch tires
Fellows45 is offline
post #8 of 11 Old 10-28-2013, 12:55 PM Thread Starter
sn95guy
just got a call from dealer, head gasket is leaking, they have to call me back to see if its under warranty, since i added tires and a lift
sn95guy is offline
post #9 of 11 Old 10-28-2013, 01:00 PM
Fellows45
That's bull if they say it's not under warrenty...
post #10 of 11 Old 10-28-2013, 01:27 PM
gold01wj
That sucks big time! Fwiw in a wj, a leaking heater core won't always produce a wet carpet. It's rubber lined on the bottom so if the coolant is leaking behind the carpet you won't know unless you pull the carpet back.
2000 wj limited quadradrive 4.7 family vehicle-was stock, then lifted 4",now stock again
gold01wj is offline
post #11 of 11 Old 10-28-2013, 02:41 PM
rdkendrick
2003 WJ
I don't see how tires and a lift would cause a head gasket to break. Completely different system.
Sent from my iPad using my fingers
rdkendrick is offline
