wj Power locks & Windows not working - JeepForum.com
post #1 of 23 Old 03-03-2012, 02:55 PM Thread Starter
xxFLETCHxx
Question wj Power locks & Windows not working
Whats up fella's. Well I have a 2004 wj and oneday my keyless entry quit working. So I went out and got batteries for it and it still wont work. If i go to my passanger side lock. I can lock and unlock all of my doors except my driver side door. Now all of a sudden none of my windows will go up on any of my doors!?!?!?!? Any ideas??????????
2004 JEEP GRAND CHEROKEE
4.7L V8
xxFLETCHxx is offline
post #2 of 23 Old 03-03-2012, 03:37 PM Thread Starter
xxFLETCHxx
checked all fuses, battery is brand new as well
4.7L V8
post #3 of 23 Old 03-03-2012, 03:51 PM
ajr2409
Check wiring in drivers side door "boot" between door and body for any broken wires.
All men are created equal, then a few become firemen.
ajr2409 is offline
post #4 of 23 Old 03-03-2012, 03:56 PM
the88thpianoman
2003 WJ
This. It's a broken ground wire running into the driver's door.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 23 Old 03-03-2012, 04:01 PM Thread Starter
xxFLETCHxx
I'll go rip it open and see what I find, iLL Keep ya updated........
4.7L V8
post #6 of 23 Old 03-03-2012, 04:18 PM Thread Starter
xxFLETCHxx
You guys are a awesome! Broken Black wire right in the rubber boot! Going to pull it out. Soder a new wire in there and try it out!
4.7L V8
post #7 of 23 Old 03-03-2012, 05:03 PM Thread Starter
xxFLETCHxx
Ok that problem is fixed! Any Idea why my remote lock isnt working? I just replaced the battery a week ago. I replaced them because the remote just quit working..........do i have to program the remote?
4.7L V8
post #8 of 23 Old 03-04-2012, 10:20 AM
BLACK04WJ
try unlocking our jeep with your remote right underneath the passenger side mirror.. if it works there then it's your antenna that has gone bad. my wife's 2004 wj remote lock only works from like a foot away from the mirror and I need to go into the door panel and fix the antenna (small black box inside the passenger door). luckily my 2004 wj still works with no problems.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #9 of 23 Old 03-04-2012, 11:25 AM Thread Starter
xxFLETCHxx
Ok well a quick story...Lastnight I kept hitting the lock button from about 50ft away and after the 15th time i could lock and unlock my door. This morning I went and stood right next to it....nothing. I tried the passager door as well..........nothing.......
4.7L V8
post #10 of 23 Old 05-31-2012, 07:00 PM
aliens8443
2008 WK
Hey guys, so I've been looking for information regarding the issue with the power locks and windows not working. It initially started with none of the power things working when the passenger door was open. If it was closed then everything worked fine. Then the other day everything on the passenger side stopped working - both the switches on each door and from the master control on the drivers side. Unfortunately, the back window was cracked and now I can't get it to come back up. Most people who have this issue have a broken wire in the boot. I checked the wires on both passenger side doors and the driver's door and they look perfect. But, I only checked the section that goes to the door. Could there be a broken wire on the end that goes into the frame?? If not, any suggestions?? Luckily I'm in Albuquerque where it only rains like 10 days a year, but I'd hate for a random summer storm to flood the car with the window being cracked open.
2004 Grand Cherokee Special Edition - Black, 4.0L I6
2010 Patriot - Silver, 2.4L I4, FD1
Ex - 2002 Liberty Limited - Blue, 3.7L V6
Ex - 2008 Grand Cherokee Limited - Black, 5.7L HEMI, QD2 (HEMI Club Member #50 Black WK Club Member #14)
aliens8443 is offline
post #11 of 23 Old 05-31-2012, 07:51 PM
mustangwarrior
same issue here ^^^ seems like 95% of the threads i read they have a broken wire, i do not and don't know what to do
KCCO! -Nick
2001 Jeep WJ, I6, Select Trac, IRO 3", Cooper ST maxx 265-75, 16" Raceline Rockcrusher Wheels, Custom Tire carrier, 30" Seward LED Light bar, rear Aussie Locker
mustangwarrior is offline
post #12 of 23 Old 06-01-2012, 07:53 PM
hamilton5
kill it with fire
hamilton5 is offline
post #13 of 23 Old 07-03-2012, 03:40 PM
benlee248
The wj I am currently working on has no windows operating and no locks are operating. could this be just the drivers or pass door causing it all? or what else? the other thing is the pass tail light isn't working even after I've replaced it with 3 bulbs none work.
l_______
/l ,[_____],
l---L -OlllllllO-
()_) ()_)--o-)_)
benlee248 is offline
post #14 of 23 Old 07-03-2012, 04:13 PM
aliens8443
2008 WK
I still haven't figured the problem with mine. All the wires are intact. A guy at Advanced Auto Parts thinks it may be the motor involved in the locking mechanism. But, I do also have had issues with my brake lights, which I hadn't thought was related with the doors but may be. The bulbs are all fine, and the brake light on the trunk door works.
Sent from my Samsung Epic using JeepForum
post #15 of 23 Old 07-04-2012, 12:08 AM
pastryslayer
2006 WK
I dunno if this will help or if you tried it already, but disconnect the battery for about 20 minutes and reconnect it. It'll reset the computer and may solve some of your problems.
I messed mine up by pulling the stereo while the battery was still connected. (I know, I know). After six months going crazy with no power locks , and giving the dealer $50 to tell me the fobs were fine, I stumbled on this tip. Voila.
pastryslayer is offline
Power Windows and Locks do not work roid WJ Grand Cherokee Forum 13 07-07-2014 02:08 PM
Windows and locks... Help!!! ajr2409 WJ Grand Cherokee Forum 18 03-16-2012 11:45 AM
No Power Locks, Windows or Interior Lights TheJeepGod WJ Grand Cherokee Forum 5 03-08-2012 10:12 AM
Power windows and door locks, help please Mason_99 WJ Grand Cherokee Forum 0 12-08-2011 06:34 PM
Locks and Windows Not Working jrushane WJ Grand Cherokee Forum 1 08-08-2010 11:25 PM
