A WJ Power Inverter Install - Page 2 - JeepForum.com
post #16 of 57 Old 08-22-2010, 09:04 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Neat! Do you have any interference fitting plugs with the ashtray door there?
~Richard
billzcat1 is offline
post #17 of 57 Old 08-22-2010, 09:07 PM Thread Starter
Apollo21
yeah so i just trimmed part of the door as you can see from the pics
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #18 of 57 Old 08-22-2010, 09:31 PM
WJChris
WJChris's Avatar
I like it. Simple.
WJChris is offline
post #19 of 57 Old 08-22-2010, 10:58 PM
sinbad85
That looks really good, I just put my cb in the ash tray spot, but I like your idea better.
sinbad85 is offline
post #20 of 57 Old 08-22-2010, 11:21 PM
PDXCoug
Could you post some photos of the actual invertor installed. I would love to add an invertor.
I really like the look of where you put it. Nicely done
Washington State University GO COUGS!
PDXCoug is offline
post #21 of 57 Old 08-23-2010, 04:50 AM Thread Starter
Apollo21
Thanks guys, and PDXCoug what do you mean? of the inverter it'self that's back there?
SOLD
Apollo21 is offline
post #22 of 57 Old 08-23-2010, 07:04 AM
bradbb2005
2008 WK
How big is the inverter and wiring to the inverter, sorry if i missed it already.
Current:
2008 WK Limited 5.7L HEMI
Mods: | JK Moabs | 245/70-17 General Grabber AT2 | 1.25" Wheel Spacers
2008 KK 3.7L V6
Mods: | 225/65-16 General Grabber AT2 |
bradbb2005 is offline
post #23 of 57 Old 08-23-2010, 07:25 AM
PDXCoug
Did you remove the case and install the invertor? I guess Im just confused about how you fit the entire invertor behind the ash tray
PDXCoug is offline
post #24 of 57 Old 08-23-2010, 08:09 AM Thread Starter
Apollo21
Yes (pic in write up), and there is plenty of room back there. Enough to fit a CB so why not an inverter?
There is a pic in the write up.
SOLD
Apollo21 is offline
post #25 of 57 Old 08-23-2010, 09:20 AM
drwolcot
does the ashtray cover open enough to give you access to the outlets? seems like the angle would make it hard to plug up
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #26 of 57 Old 08-23-2010, 09:40 AM Thread Starter
Apollo21
It does, barely i'm going to trim and sand it more. I'll be honest i did this in secret because i was supposed to be paying attention to my family and girlfriend instead of working on the jeep. So this was late at night early morning. I still haven't sanded down the jig saw cuts.
SOLD
Apollo21 is offline
post #27 of 57 Old 08-23-2010, 01:36 PM
bradbb2005
2008 WK
I meant wattage and AWG of the wire...
Current:
2008 KK 3.7L V6
post #28 of 57 Old 08-23-2010, 01:41 PM Thread Starter
Apollo21
Also in the build thread but here it is again 400 watts and 800 watts "peak" so 8 AWG an a 80 amp fuse the inverter has 12 AWG wires coming from the circuit board which are soldered to it.
SOLD
Apollo21 is offline
post #29 of 57 Old 08-23-2010, 03:21 PM
straty1987
with 8/12 gauge and a 800 watt peak the wire might get hot, the 80 amp fuse is good for 800 watts max.
run something for a while and see if the lines can handle it.
the fuse holder looks good and could of use the 4 gauge wire i sold you.
might want to put a wire loom over the cables so when you wheel there not covered in dirt.
i have a power inverter just like yours and gave both the cables to power it off the cigarette out lite or direct to battery. i just mounted it under the CD changer in the cargo area and plug it in when i need to the cigarette back there. its held on by the double side tape plastic squares that you can run tie-raps threw.
straty1987 is offline
post #30 of 57 Old 08-23-2010, 04:18 PM Thread Starter
Apollo21
Yeah the 800 watt peak can't be held for that long (under an hour) but i can't see my self needing more than 400 at any time out of it.
I have a wire loom but i haven't put it on yet
SOLD
Apollo21 is offline
Power Antenna cultcab WJ Grand Cherokee Forum 20 04-15-2012 05:10 PM
power problem wj_jeep92 WJ Grand Cherokee Forum 2 06-24-2010 04:18 PM
Suggestions for strong battery (WJ) with power inverter adgjqetuo WJ Grand Cherokee Forum 22 06-04-2010 05:14 PM
WJ Power Door Locks DJGWJ WJ Grand Cherokee Forum 5 03-24-2010 02:17 PM
Power Steering ??? Astorm WJ Grand Cherokee Forum 1 02-27-2004 08:08 AM
