WJ Picture Thread - Page 46 - JeepForum.com
 70Likes
post #676 of 1960 Old 06-17-2013, 08:55 PM
lance-tek
Originally Posted by Jaysun1994 View Post
Is there a way to get the color matched grill without the chrome rings like this one. I cant find any online?
on the limited's the bumper and the grille were attached to one another and color matched to the body. On the Laredo they are separate (and the grille is chrome).
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #677 of 1960 Old 06-17-2013, 09:19 PM
cde02ltd
I believe the 99 to 2001 limited models did not have the chrome inserts in the grill. Our 02 limited has color matched grill with chrome inserts.
cde02ltd is offline
post #678 of 1960 Old 06-18-2013, 04:06 AM
-OIIIIIIIO-01
Under Construction
-OIIIIIIIO-01's Avatar
2001 limited has body match color with the Chrome rings.
91 YJ 4.0/AX15/231J AA SYE
3.5" BDS Springs / .75" Shackle / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is offline
post #679 of 1960 Old 06-18-2013, 07:45 AM
brouwmat
http://www.wjjeeps.com/grilles/grillesrem.htm
This link has a ton of info on the WJ including everything you ever wanted to know about grilles.
I believe you could replicate this look by painting a stock chrome Laredo grille from 99-03 if you have any other model. The other grilles would have that ridge around the outside that even if you painted it would still be there. Sand it down well with med and then fine sandpaper first (after you take out the black inserts) and it should hold paint decently. There are a ton of pages out there on line that describes how to do this.
Good luck and post pics when/if you decide to do it.
brouwmat is offline
post #680 of 1960 Old 06-18-2013, 10:42 AM
Jaysun1994
thanks for the help I might get a chrome one then and color match it to my wj because i hate the chrome rings so much.
Jaysun1994 is offline
post #681 of 1960 Old 06-18-2013, 11:05 AM
PAJeep6
I may be wrong, but I believe you can just remove the chrome rings. I've see them for sale separately from the grille. I have been wanting to remove mine too, but just haven't gotten around to it yet.
02 WJ - 4.7 | Black Rocks | 33" Treadwright Guard Dogs | 3" exhaust | 6.5" LA lift...
PAJeep6 is offline
post #682 of 1960 Old 06-18-2013, 02:47 PM
Russell84
2003 WJ
Originally Posted by wjjeepman34 View Post
Why did this thread lose it's "sticky" status???
I'm assuming because nobody bothers to follow the rules of the thread anymore. Just a guess, though.
-Rusty
2003 WJ Overland 4.7 HO, Clayton Long Arms, Teraflex 4.5" coils, JKS adj trackbar, JKS Quicker Discos, 17x9 Eagle Alloy Series 185, 285/70/17 BFG KM2, cut fenders/bumpers
Russell84 is offline
post #683 of 1960 Old 06-18-2013, 03:47 PM
adavis39
you CAN remove them, but it will look like crap. they are held in with little clips thats you have to brake to get them off. You would be left with little holes around each grille "loop". Best bet is to find a 99 or 2000 limited at the junk yard and cut the grille from the bumper......then just bolt it on to your laredo. Its easy to cut and youll never notice. I cut my grille so that I can run without the bumper on the trail. once you put the bumper cover back on you never notice it ever been cut into 2 pieces
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #684 of 1960 Old 06-18-2013, 05:48 PM
Jeep99wj
Jeep99wj is offline
post #685 of 1960 Old 06-19-2013, 07:24 PM
rloew275
rloew275 is offline
post #686 of 1960 Old 06-24-2013, 06:06 PM
evilcairn
Because Beer > Mud
WJ 2001 V8 , 6.5" lift IRO , 35" BF , Front DS TomWoods mutilCV, Fender Iceland, TrueTrac Eaton Front, Gears 4:56 , Custom Front bumper, custom rock slidder ....
evilcairn is offline
post #687 of 1960 Old 06-25-2013, 02:36 AM
ADragg
2003 WJ
My Jeep is finally cool enough to post pictures of!
Pointless barely flexing picture...
electricd likes this.
3.5" lifted '03 Limited Quadra Drive WJ - OME HD coils, Bilstein 5100 shocks, JKS track bar, IRO extended links, OME 10mm spacers, Moog SS, JK Moab wheels w/ 265/70/17 (32") Goodyear Duratracs.
ADragg is offline
post #688 of 1960 Old 06-26-2013, 06:07 PM
wjjeepman34
04 WJ 4.7 V8-Fully loaded, K&N FIPK, V-force muffler, Duratracs, OME HD coils, Bilsteins, JKS track bar, JKS quicker disconnects, IRO aux mounted SS, Rear sway bar delete, Custom winch bumper.
wjjeepman34 is offline
post #689 of 1960 Old 07-02-2013, 09:49 AM
JustStew
New pic:
4" IRO
265/70 MTZ
JKS QDs
JustStew is offline
post #690 of 1960 Old 07-02-2013, 11:27 AM
pkess3
Nice looking WJ!! We should hit the trail together sometime. I'm in Henderson and have a similarly modified 04 Overland.
pkess3 is offline
WJ - Front axle loose, clunky Pls read - detailed - Search Completed :-) swirls WJ Grand Cherokee Forum 20 02-27-2011 01:54 PM
WJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones WJ Grand Cherokee Forum 4 10-16-2009 01:11 AM
Pulled Trans Pan - 142K miles on original fluid! Pics! Pics! Pics! Soft 8 WJ Grand Cherokee Forum 11 02-02-2009 05:10 PM
Pics of WJ xj9598 WJ Grand Cherokee Forum 4 03-02-2003 09:54 PM
new pics 2002grand WJ Grand Cherokee Forum 2 01-05-2003 05:25 PM
