WJ Picture Thread - Page 17 - JeepForum.com
 69Likes
post #241 of 1960 Old 03-06-2012, 12:14 AM
BlingBlingZJ
Here's mine
Its an 02 limited V8 2WD
3" exhaust with 40 series flowmaster
stock wheels
its a street jeep for now
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #242 of 1960 Old 03-14-2012, 09:42 AM
Virge
99 WJ Limited V8 Quadradrive
3" IRO Lift
265/75/16 BFG Rugged Trail T/A
Sorry no flex pic yet....
Virge is offline
post #243 of 1960 Old 03-14-2012, 08:44 PM
USFORCES
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #244 of 1960 Old 03-28-2012, 03:57 PM
MURDEREDWJ
Washed, clay barred, and waxed!
Stock wj v8
Engine enameled grille
Engine enameled rims
Stock full skid plates under
Ionic predator bull bar
Hella black magics
New style headlights
ZxE headlights (love them)
VHT rears
K&N drop on
265/70/16 Destination A/T's
BB this summer$$
**MURDER IT**
MURDEREDWJ is offline
post #245 of 1960 Old 03-28-2012, 06:41 PM
4x4Jeep
2" coil spacers
Rancho SS
stock shocks
stock wheels & tires 225/75/16
Build -
SOLD
4x4Jeep is offline
post #246 of 1960 Old 04-05-2012, 11:21 PM
nhcd538
2" Budget boost (everything else stock)
265/75/15 Wild Country APT tires
Jegs black d-window rims, 15x7 (4" backspacing) w/ factory JK center caps
Before:
After:
1999 TJ 2.5L AX5 NP231 D35/30 4.11's
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #247 of 1960 Old 04-09-2012, 07:49 PM
MatthewWJ
Wj 2001 WJ IRO 3" w/.75 bb adjustable upper and lowers
2001 WJ IRO 3" w/.75 bb adjustable upper and lowers, ss, adjustable tracbar, Doetsch Tech shocks. 17" XD wheels and 265x65 17 General grabbers (almost 32" tires). and an updated Double cardian front drive shaft from Tattons.
MatthewWJ is offline
post #248 of 1960 Old 04-12-2012, 07:40 PM
musicpuppy
Wj
Originally Posted by justn View Post
Stock height, stock wheels, stock tire size 225/75/16 BFG LongTrail T/A Tour's.
wow sir, the agony of defeat, not good for this site, but love the honesty.
musicpuppy is offline
post #249 of 1960 Old 04-12-2012, 07:44 PM
musicpuppy
Wj
Originally Posted by USFORCES View Post
04 Overland 4.7 H.O paid $4k out the door... but I had it repainted and did a lot of work in replacing worn out parts from the ground up.
Lifted with IRO 6.5" all adj. then a complete whole new suspension ball joints, bearing, axles you name it.
33" BFG 285/75/16 on MB offroad rims.
EBC brakes and rotors
New brake calipers (complete calipers)
Bliston 5150's
Front & Rear Addco swaybars
H.I.D lighting and H.I.D lens with matching rear tail lights.
Brand new in the box factory nav unit, only reason is I got it cheap!
1/2 thick 2 1/2 qts. (over stock) trans pan plus new oil pan.
All new fluids brakes, power steering, transfer ect ect..
Complete new exhaust system.
Higher cranking battery.
New plugs, belt, intake system.
New rebuilt 242HD 6pinion, installed selec-trac shifter assy.
New spring isolators
Sorry no flex photos, I'll update it soon
Is photoshop great or what...
Update 1/29/12, 242HD with the hummer 6pinion planetary installed.
Below and above, you guys have some sweet WJ's!!
Great lookind ride my friend, and the photoshop aint bad either, but id rather have the ride. lol
post #250 of 1960 Old 04-12-2012, 08:49 PM
fourninetwo
20" Fuel Offroad Wheels
33's Nitto Terra Grapplers
fourninetwo is offline
post #251 of 1960 Old 04-13-2012, 06:03 PM
aleet25
2003 WJ
2003 WJ Laredo
2" OME HD Springs
2" Daystar Spring spacers
265/75/R16 ProComp Extreme Mud Terrains
aleet25 is offline
post #252 of 1960 Old 04-14-2012, 09:02 PM
Jacko84
I'm still on stock suspension and tires but I saw this rock and couldn't resist...
Jacko84 is offline
post #253 of 1960 Old 04-19-2012, 11:09 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Snobrdrkid's WJ
Current Specs:
Suspension - Stock with 1 inch spacers on all 4 corners.
Stock Rims with 245/70/16's (Second set of rims are 235/65/17's)
Some crappy shocks. Sadly the suspension is still stock. But I still have fun!
Little Bit of Flex
With the OME HD's on!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #254 of 1960 Old 04-20-2012, 12:04 AM
Cirruslydakota
2" BDS/Billzcat lift combo. (2" springs with 3/4 spacers on the front to level it out)
245/75/16 Kumho KL78's on JK steel wheels. Summer tires are Michelin LTX 245/70/16 on stock trashed Timberlines.
Shocks are advance auto Monroe specials with a lifetime warranty. Theyre junk.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #255 of 1960 Old 04-21-2012, 02:00 PM
04dubjay
Thought you guys may enjoy this!!! Might get flamed but whatever...
Then...
[img]
and now...
[img][/img]
2004 Columbia Edition WJ (I6/Selectrac) -{RC/Ironman4x4fab/JKS/KOR/Nitto/Carolina}
04dubjay is offline
WJ - Front axle loose, clunky Pls read - detailed - Search Completed :-) swirls WJ Grand Cherokee Forum 20 02-27-2011 01:54 PM
WJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones WJ Grand Cherokee Forum 4 10-16-2009 01:11 AM
Pulled Trans Pan - 142K miles on original fluid! Pics! Pics! Pics! Soft 8 WJ Grand Cherokee Forum 11 02-02-2009 05:10 PM
Pics of WJ xj9598 WJ Grand Cherokee Forum 4 03-02-2003 09:54 PM
new pics 2002grand WJ Grand Cherokee Forum 2 01-05-2003 05:25 PM
