WJ Picture Thread - Page 13 - JeepForum.com
 70Likes
post #181 of 1960 Old 07-03-2011, 09:42 PM
mrmef
267464_236211759736567_100000432350879_845974_1001324_n.jpg   264670_236212039736539_100000432350879_845976_4423283_n.jpg   270351_236211893069887_100000432350879_845975_1907848_n.jpg   269913_236212369736506_100000432350879_845978_5073560_n.jpg   270644_236212276403182_100000432350879_845977_916634_n.jpg
mrmef is offline
post #182 of 1960 Old 07-11-2011, 10:57 AM
srmitchell
2004 Grand, Special Edition package. (4.7, 247 case)
2 inch Spacer lift, 245/75/r16 All Terrains
3 inch Iron Rock lift. (coils, track bar, sway bar links)
Bilstien Shocks from IRO.
265/75r16 BFG All Terrains
Current Setup
3 inch IRO coils
1/2 inch rear spacer from OME
IRO Track Bar
Kevin's dual stabilizer kit
Bilstein Shocks
Addco rear sway bar (Removed, it rides fine without a rear bar)
255/75/17 Mud Terrains, and 17 inch Moabs.
Rubs on the front bumper, and fogs.
Did about 30 miles of trails this weekend. (No flex pics, sorry)
I work on Mopars
srmitchell is offline
post #183 of 1960 Old 07-11-2011, 08:05 PM
Weeder1
04 laredo
255/75/17 moabs and bfg mt made fit
they dont scrub anymore now...bb this week
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #184 of 1960 Old 07-11-2011, 08:24 PM
theksmith
2003 WJ
Originally Posted by theksmith View Post
Current Specs (8/2010):
  • 2003 WJ 4.7 H.O. Limited - Brilliant Black Crystal Pearl
  • Eagle Alloy Series 140 Black Wheels - 17"x8", 5 on 5, +2 mm offset, 4.517" BS, 29 lbs each
  • BFGoodrich Mud-Terrain T/A KM2 Tires - LT285/70R17 (~ 33" x 11.5")
  • Clayton Offroad 6" Hard Arm Lift
  • ~5" IRO Bump Stop Extension Front & Rear
  • JKS Track-bar, Drag-link, TieRod, Sway-bar Disconnects & Super-Nerfs
  • Clayton ZJ Belly Skid
  • Custom Radiator Support Skid
  • Relocated Steering Stabilizer to Drag-link
  • Removed Rear Sway-bar
  • Front Fenders trimmed to body line
  • Removed Front Bumper
  • Rear Fenders trimmed and rolled
  • Rear Bumper trimmed
  • Factory Dana 30 with ARB Locker
  • Factory Dana 44HD with Aussie Locker
  • 242HD T-case with Tom Woods SYE (and locally done heavy duty driveshafts)
  • Magnaflow High-flow 3" Cat, Flowmaster 50 Delta Flow muffler, 3" Mandrel-bent Turn-down
  • Custom Rack based on Rola with Shovel/Axe/Hi-Lift Mounts
  • Debadged
  • Custom CB and HAM Antenna Mounts
  • Towhooks in front, Receiver-mount Shackle in rear
  • Ebay Headlights and Taillights (OEM tails in last pic still)
  • Upgraded Headlight Harness
  • Grille Guy Front Grill Insert
  • Dual Battery (almost)
  • Dual Compressor On-Board-Air
  • Misc Interior Mods
Build Thread: http://www.jeepforum.com/forum/f197/...4-7-ho-526660/
guess i should update this thread - now has 35's and JK Rubi axles. here's some shots with the 35's, but no good pics with the JK axles yet (even though they are only 1 3/4" wider, you can see the difference):
theksmith is offline
post #185 of 1960 Old 07-12-2011, 06:54 PM
Brian891
•4inch RCX Lift including:
-Adj Front Lower Ctrl Arms
-Adj Trac Bar
-Quick Discos
-4" Lift Coils
-4" Lift Shocks
Custom Winch Bumper
Smittybilt XRC8 Winch
Mx5000 Code 3 Lightbar
33"x12.5" Dunlop Mud Rovers
15x8 Rebel Racing Rims
2" BB Spacers
1999 Grand Cherokee WJ
V8 4.7L - Quadratrac // 4 inch RCX Lift Kit // Rough Country Steering Stabilizer // Custom front bull bar with Skidplate // MVX5000 Police Lightbar
Brian891 is offline
post #186 of 1960 Old 07-20-2011, 12:30 PM
CruizinKev
Wj
my 2000 4.7 - stock wheels and everything except sides debadged, removed roof rack and magnaflow muffler (will replace it with flowmaster 50 suv soon). already ordered smoked LED tails and black 20x9 srt8 rims.
- Kevin -
2000 Jeep Grand Cherokee 4.7 Dailydriver
1979 Chevrolet Monte Carlo LS3 6.2 T56 Full Resto Project
CruizinKev is offline
post #187 of 1960 Old 07-25-2011, 04:39 PM
offroading.net
offroading.net's Avatar
3" OME HD springs, +2" Rough Country Shocks, 4.5" backspace 16" steel wheels with 245-75-16 Grabber AT2s, everything else standard for now & no trimming done or rubbing
Steve Wright
'02 4.7 v8 WG Limited
'99 4l I6 WG Limited
'16 Renegade Limited, Wifey Wagon
Previous Jeeps- 8 XJs, an MJ, a WJ, 2 TJ's & 2 KJs
offroading.net is offline
post #188 of 1960 Old 07-28-2011, 10:56 AM
scarrskey
1999 WJ 4.0 - 4.5" Rusty's coils, IRO front long arms, Rusty's Shocks, Rusty's track Bar, Rusty's rear fixed length CA's, Rusty's A-arm spacer, JKS BPE's, 4" extended bumpstops, KOR Steering Stabilizer, Pro Comp 16x8 Steelies w/ 4.25 BS, Maxxis Bighorns 285/75/16 (3/4" spacer added to front - not shown in pictures)
scarrskey is offline
post #189 of 1960 Old 08-10-2011, 11:13 PM
rkperry1
IRO 3 inch 3" coils dostech shocks adj trac bar rear sway bar links
245/75/16 BFG
rkperry1 is offline
post #190 of 1960 Old 08-21-2011, 10:54 AM
bigchevyman24
bigchevyman24's Avatar
2000 laredo 4.0, almost 4wd
2" budget boost, front trimmed, 255/70r18 bridgestone dueler a/t on 18" jk wheels with 1.5" spacers
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #191 of 1960 Old 08-23-2011, 08:03 PM
liquidxit2
2002 WJ limited 4.7l Quadra drive. Sure it has 100k and is a stock non HO, but the SOB hauls! So far quite impressed.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #192 of 1960 Old 09-03-2011, 11:02 AM
marco2287
Wj 2000 WJ Laredo
Hey Guys,
My specs are:
Rough Country 4" X-Series Lift
Front:
Coil springs, lower adjustable control arms with X-flex joints, sway-bar quick disconnects, bumpstop spacers, adjustable track rod, transmission crossmember spacers.
Rear
Coil springs, upper control arm bracket, bumpstop extensions, sway-bar brackets, rear shock relocation kit.
Tires
33" x 12.50" R16 Interco TrXus M/T
Wheels
16x8 Pro Comp Rock Crawler Series 98 in Gloss Black with 4.25" Backspacing
Trimming
Very minor trimming was needed in the front so that I could have full range of motion for steering. Small portion of front bumper needed to come off at the bottom. The plastic strips that go along the stock rocker panels had to come off so that some metal could come off behind the front tire. More trimming may be needed eventually for full flex.
marco2287 is offline
post #193 of 1960 Old 09-07-2011, 10:59 AM
liquidxit2
Next the the ol' KJ!
Cant wait to start modding!
post #194 of 1960 Old 09-07-2011, 06:07 PM
mreed21
Rancho Rs5000 shocks
Rancho Rs5000 steering stabilizer.
All fluids changed.
mreed21 is offline
post #195 of 1960 Old 09-10-2011, 06:19 PM
ovdanimal78
Wj 2004 WJ Laredo
Tires: 245/75/16 Cooper Discoverer AT3's
Wheels: MB Chaos 5 Matte Black
Chromed out to give her a newer, more updated look
Painted Black ckadding
ovdanimal78 is offline
WJ - Front axle loose, clunky Pls read - detailed - Search Completed :-) swirls WJ Grand Cherokee Forum 20 02-27-2011 01:54 PM
WJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones WJ Grand Cherokee Forum 4 10-16-2009 01:11 AM
Pulled Trans Pan - 142K miles on original fluid! Pics! Pics! Pics! Soft 8 WJ Grand Cherokee Forum 11 02-02-2009 05:10 PM
Pics of WJ xj9598 WJ Grand Cherokee Forum 4 03-02-2003 09:54 PM
new pics 2002grand WJ Grand Cherokee Forum 2 01-05-2003 05:25 PM
