WJ Picture Thread - JeepForum.com
 69Likes
post #1 of 1959 Old 08-15-2010, 06:46 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Lightbulb WJ Picture Thread
Update: 1/15/15
This got out of hand and is too far gone to bother cleaning it up. I am currently sifting through all 1,500+ posts and am using the posts that followed the rules for some FAQ threads.
Since this thread has become a random picture thread, I'm changing the title from "Submit your WJ pics *READ THE RULES PLEASE*" to "WJ Picture Thread". It will no longer be a sticky and will not be used to submit lift/tire combinations. You can continue to post in this thread as you were. To post proper submissions, use the following thread:
WJ Lift/Tire Submission Thread
Thanks,
ChrisHager
So please submit your pictures of your Jeep. Three specific pictures are ideal.
1) Profile picture (on level ground)
2) Head one picture (on level ground)
3) Flexed picture
Feel free to submit duplicates of a lift/tire combo someone else already did because if your pictures are better, lets face it, we'll it them instead
Requirements:
1) Photos
2) Full lift specs (name of lift and the EXACT components in there)
3) Tire/wheel combo used.
4) Any "non-standard" mods (such as trimming (how much), excessive bump stops, etc...)
I'll let this build up for a week or two (or until we get all the pictures we need for the lift set ups) and then I'll create a new thread with the specific pictures in there.
Thanks,
Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #2 of 1959 Old 08-15-2010, 07:08 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Guess I will be the first
Hybrid lift - 5" IRO front, 4.5" Teraflex rear, 6 IRO adjustable arms, IRO a-arm spacer, Bilstein shocks, JKS disconnects, JKS adj. track bar
Tires - 31x10.5 MTR treadwright retreads
Wheels - 15x7 Cragar Soft 8s
Trimmed front bumper off lower corner, 4" front bumpstop extension, 3" rear bumpstop extension
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 1959 Old 08-15-2010, 07:51 PM
WillMcD
Lift: 4" RCX + IRO Critical Path LA's + KOR 3/4" spacer
Tire: 32" Firestone Destination M/T on Black Moabs
Trim: Front bumper slight trim.
04 WJ Limited Black, 5.5" LA hybrid (IRO Trackbar, Teraflex Springs, Bilstein 5100/5125 Shocks, IRO Critical Path High Clearance LA's + KOR 3/4" spacers, JKS Disconnects) 32" Firestone Destination M/T's, JCR Stage 3 Sliders, Black Moabs, Muffler Delete, Hella 700ff's, Yakima Load Warrior
Phil:4:13: I can do all things through Christ which strengtheneth me.
Originally Posted by billzcat View Post
a lot of people waste their life playing FB games all day like Farmville, Cityville, Gangsterville, Hookersnblowville, Idonteffingcareville
August 2011 GCOTM Winner
Build Thread:
WillMcD is offline
post #4 of 1959 Old 08-15-2010, 08:10 PM
MoonyJohn
MoonyJohn's Avatar
Lift components..
IRO 5.5" Front Long Arm lift kit.. includes 5.5" springs front and rear, front fixed long arms, adj. front track bar, rear fixed lower control arms, rear a-arm spacer, 12" trave' bilstein 5125 shocks, front JKS bar pin eliminators, front JKS shock adapters, extended sway links
15x8 Black Cragar "D window" rims with 3.75" backspacing mounted on 33x12.5r15 BFG A/T
Trimmed front bumper, and rear bumper, no bumpstops.
MoonyJohn is offline
post #5 of 1959 Old 08-16-2010, 12:24 AM
xJoshxx
2012 WK
Lift Hybrid setup consisting of 4" teraflex coils IRO front Adjustable Long arms Including Upper coil retainers KOR A-Arm spacer JKS trac-bar with KOR duro-Meter bushings IRO Swaybar links. RE mono Tube Shocks.
Tires 265/75/16 ON Stock timberlines with spidertrax 1.25 5x5 Spacers
Trimmed front plastic bumper to fit. Stock bumpstops.Soild D35 Diff cover
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 1959 Old 08-16-2010, 02:11 AM
theksmith
2003 WJ
Current Specs (8/2010):
  • 2003 WJ 4.7 H.O. Limited - Brilliant Black Crystal Pearl
  • Eagle Alloy Series 140 Black Wheels - 17"x8", 5 on 5, +2 mm offset, 4.517" BS, 29 lbs each
  • BFGoodrich Mud-Terrain T/A KM2 Tires - LT285/70R17 (~ 33" x 11.5")
  • Clayton Offroad 6" Hard Arm Lift
  • ~5" IRO Bump Stop Extension Front & Rear
  • JKS Track-bar, Drag-link, TieRod, Sway-bar Disconnects & Super-Nerfs
  • Clayton ZJ Belly Skid
  • Custom Radiator Support Skid
  • Relocated Steering Stabilizer to Drag-link
  • Removed Rear Sway-bar
  • Front Fenders trimmed to body line
  • Removed Front Bumper
  • Rear Fenders trimmed and rolled
  • Rear Bumper trimmed
  • Factory Dana 30 with ARB Locker
  • Factory Dana 44HD with Aussie Locker
  • 242HD T-case with Tom Woods SYE (and locally done heavy duty driveshafts)
  • Magnaflow High-flow 3" Cat, Flowmaster 50 Delta Flow muffler, 3" Mandrel-bent Turn-down
  • Custom Rack based on Rola with Shovel/Axe/Hi-Lift Mounts
  • Debadged
  • Custom CB and HAM Antenna Mounts
  • Towhooks in front, Receiver-mount Shackle in rear
  • Ebay Headlights and Taillights (OEM tails in last pic still)
  • Upgraded Headlight Harness
  • Grille Guy Front Grill Insert
  • Dual Battery (almost)
  • Dual Compressor On-Board-Air
  • Misc Interior Mods
Build Thread: http://www.jeepforum.com/forum/f197/...4-7-ho-526660/
theksmith is offline
post #7 of 1959 Old 08-16-2010, 11:00 AM
Atlas92
1989 MJ Comanche
6" Short Arm Hybrid Lift: 4" RC Coils, 2" Rusty's BB, RC Adj. Front Lower CAs, IRO Adj. Front Upper CAs, IRO Adj. Trackbar, RC Front Swawbar Discos, 4" Front Ext. Bumpstops, IRO Fixed Rear Lower CAs, RC A-arm Spacer, 5" rear bumpstops, 12" travel Bilstein 5125s.
35x13.50R20 Mickey Thompson Baja ATZs on 20x8.5 MB Offroad Gunner 5's w/ 4"BS
Front and rear bumber trimmed a lot, front and rear fenders trimmed and rolled, windshield washer fluid bottle relocation, rear swaybar removed.
1989 MJ 4.0L/AX15/NP231
HP30/8.8/4.10s
Atlas92 is offline
post #8 of 1959 Old 08-16-2010, 12:01 PM
Apollo21
Apollo21's 02 Overland
Note: Not Discoed
Discoed
Zone 4in Kit(minus Tcase drop), KOR 3/4 front spacers, 1.5in wheel spacers x4, KOR single SS, Rear Addco Sway Bar, IRO upper front adjustable CAs, IRO coil spring retainers, RC quick discos
17in Stock Hammerhead rims with 265/70R17 Treadwright MTRs/Guard Dogs (actually measure 32.25in)
Trimmed a small amount (around an inch) off the underside of the front plastic bumper.
Build Thread in Sig
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #9 of 1959 Old 08-16-2010, 07:43 PM
WJ04
WJ04's: IRO 4.25'' CP LA lift, 31'' Destination MT's, 16X7 soft 8's with 4'' BS, cut in half front bumper, Full specs in sig.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #10 of 1959 Old 08-17-2010, 06:00 PM
tsconver
2003 WJ
My 03 WJ
Iron Dana 44 Rear
video of me this Oct 2010
<embed src="http://p.webshots.com/flash/smallplayer.swf?videoFile=http://videoserve.webshots.com/video/31476/3021146190041494322XFTnLh_v_0.flv&audio=on&display ImagePreview=http://videothumb37.webshots.com/thumb/31476/3021146190041494322XFTnLhstill_002_0.jpg&videoPage Url=http://rides.webshots.com/video/3021146190041494322XFTnLh&autoPlay=false&shareLink =http://cards.webshots.com/ecard/personalize?photoId=3021146190041494322%26source=v " type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" quality="best" allowscriptaccess="always"></embed><br/><br/><a href="http://rides.webshots.com/video/3021146190041494322XFTnLh">Fall Fling 2010 024.avi</a>
IRO Long Arms Front and Adjustable Rear Lowers,
3in IRO Springs and 0.75" KOR Spacers,
JKS Quick Disco Front,
Addco Rear Sway Bar,
home made front bumpstop extensions,
MX-6 Shocks all four corners,
ARB Air lockers front and rear, w/ 4.10 gears
15x8 Cragar Soft 8s with Treadwright 31x10.5 MT Shoes for wheeling
17x8 American Racing Crush Rims and Wrangler Silent Armor shoes for street driving
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #11 of 1959 Old 08-19-2010, 11:06 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Guess I will do my lower ones since no one else is.
2" BB, Skyjacker shocks, JKS track bar, JKS disconnects, OME SS
Tires - Stock 225/75/16 BFG All terrians
Wheels - Stock 16" Timberlines with 1.25" spacer
2.5" Rusty Springs, Skyjacker front shocks, rough country rear shocks, JKS track bar, JKS disconnects, OME SS
Trimmed lower corner of front bumper, 2.5" front bumpstop
Brian
WJ, WK, CJ5
GraKee99 is offline
post #12 of 1959 Old 08-19-2010, 09:10 PM
HaViiK
Lift: Rough Country 4" X-Series, no T-Case drop.
Wheels: Cragar 15x8 Soft 8, 4" BS
Tires: BF Goodrich KM2 32x11.5x15
Trimmed about .5" of bumper, need to trim .5" off fender
Steven, New HaViiK
2001 WJ, 4.0, 42re (rebuilt at 100k), 30/35, Rough Country X-Series, JCR Stage 3 Sliders, Yakima Megawarrior & Big Powderhound, Grille Guard, KC Daylighter 130w, Custom Sub Box & 2 Kicker 12" CVR
Originally Posted by rulppa(chat) View Post
whats with people (steve) with those monster sigs. reply is usually like ':E' then 2 pages of signature lol
Originally Posted by Sarahdactyl View Post
THE WINNER IS REDHOTCHILIDOG!!!!111!!1!!!!(OBNXIOUS HUGE BEEFSTEW STYLE FONT) I will PM winner for details
HaViiK is offline
post #13 of 1959 Old 08-24-2010, 10:39 AM
RJDJWJ
2001 WJ V8 Limited
Rustys 4.5 Advanced:
4.5" Front & Rear Coils
Rusty's Performance Shocks
Drop Pitman Arm
Front Adjustable Trac Bar
JKS Quicker Disconnects
Upper Control Arms
Adjustable Front Lower Control Arms
Rear Lower Control Arms
Rear 3 Link Spacer
Extended Rear Sway Bar Links
BFG 33" KM2'S
15x10 Allied Simulated Beadlocks
Np231
JCR sliders
AFe Intake
Magnaflow Cat
Flowmaster 40
Jks Bar Pin Eliminators
Jks Quicker discos
Front Spring Retainers(top and bottom)not in last pick
OME Dual SS
Iceland Offroad Bumper
Tail light Guards
Spidertrax spacers
Yakima Rack
Hellas
Midland CB
Laredo Headlights
Tinted Tail lights
Black Emblems
3.5" Homemade Front Bump Stops, Have rear 4" just haven't put on.
Trimmed front bumper up to top bend and trimmed front bumper to follow.
Trimmed rear even with back door and followed around tire.
RJDJWJ is offline
post #14 of 1959 Old 08-24-2010, 11:21 AM
-Shoey-
2010 KK Liberty
Guess I'm the short guy so far.
Used to have these on it, 255/75/17 BFG KM's on Moabs, with a Rustys 2.5" BB...don't do this.
Backing up and turning, no bueno. Again, don't do this.
She had 265/70/17 BFG AT's on before that, rubbed just a smidge here and there.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #15 of 1959 Old 08-24-2010, 11:37 AM
MANUBI
2" BB lift
31" tires
15" american racing rims cause im tired of seeing every wj with cragars on em.
all for about $300. thanks to cl and ebay
MANUBI is offline
WJ - Front axle loose, clunky Pls read - detailed - Search Completed :-) swirls WJ Grand Cherokee Forum 20 02-27-2011 02:54 PM
WJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones WJ Grand Cherokee Forum 4 10-16-2009 02:11 AM
Pulled Trans Pan - 142K miles on original fluid! Pics! Pics! Pics! Soft 8 WJ Grand Cherokee Forum 11 02-02-2009 06:10 PM
Pics of WJ xj9598 WJ Grand Cherokee Forum 4 03-02-2003 10:54 PM
new pics 2002grand WJ Grand Cherokee Forum 2 01-05-2003 06:25 PM
