-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   WJ Picture Thread (http://www.jeepforum.com/forum/f310/wj-picture-thread-1089317/)
ArloGuthroJeep 08-15-2010 05:46 PM
WJ Picture Thread
Update: 1/15/15
This got out of hand and is too far gone to bother cleaning it up. I am currently sifting through all 1,500+ posts and am using the posts that followed the rules for some FAQ threads.
Since this thread has become a random picture thread, I'm changing the title from "Submit your WJ pics *READ THE RULES PLEASE*" to "WJ Picture Thread". It will no longer be a sticky and will not be used to submit lift/tire combinations. You can continue to post in this thread as you were. To post proper submissions, use the following thread:
WJ Lift/Tire Submission Thread
Thanks,
ChrisHager
So please submit your pictures of your Jeep. Three specific pictures are ideal.
1) Profile picture (on level ground)
2) Head one picture (on level ground)
3) Flexed picture
Feel free to submit duplicates of a lift/tire combo someone else already did because if your pictures are better, lets face it, we'll it them instead:laugh:
Requirements:
1) Photos
2) Full lift specs (name of lift and the EXACT components in there)
3) Tire/wheel combo used.
4) Any "non-standard" mods (such as trimming (how much), excessive bump stops, etc...)
I'll let this build up for a week or two (or until we get all the pictures we need for the lift set ups) and then I'll create a new thread with the specific pictures in there.
Thanks,
Ryan
GraKee99 08-15-2010 06:08 PM
Guess I will be the first
http://i242.photobucket.com/albums/f...e/DSCN1102.jpg
http://i242.photobucket.com/albums/f...e/DSCN1078.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._6649961_n.jpg
Hybrid lift - 5" IRO front, 4.5" Teraflex rear, 6 IRO adjustable arms, IRO a-arm spacer, Bilstein shocks, JKS disconnects, JKS adj. track bar
Tires - 31x10.5 MTR treadwright retreads
Wheels - 15x7 Cragar Soft 8s
Trimmed front bumper off lower corner, 4" front bumpstop extension, 3" rear bumpstop extension
WillMcD 08-15-2010 06:51 PM
http://i906.photobucket.com/albums/a...d/101_0838.jpg
http://i906.photobucket.com/albums/a...d/101_0846.jpg
http://i906.photobucket.com/albums/a...d/101_0870.jpg
Lift: 4" RCX + IRO Critical Path LA's + KOR 3/4" spacer
Tire: 32" Firestone Destination M/T on Black Moabs
Trim: Front bumper slight trim.
MoonyJohn 08-15-2010 07:10 PM
1 Attachment(s)
http://i577.photobucket.com/albums/s...1/DSC_1126.jpg
http://i577.photobucket.com/albums/s...1/DSC_0933.jpg
http://i577.photobucket.com/albums/s...8-14143354.jpg
Lift components..
IRO 5.5" Front Long Arm lift kit.. includes 5.5" springs front and rear, front fixed long arms, adj. front track bar, rear fixed lower control arms, rear a-arm spacer, 12" trave' bilstein 5125 shocks, front JKS bar pin eliminators, front JKS shock adapters, extended sway links
15x8 Black Cragar "D window" rims with 3.75" backspacing mounted on 33x12.5r15 BFG A/T
Trimmed front bumper, and rear bumper, no bumpstops.
xJoshxx 08-15-2010 11:24 PM
http://i3.photobucket.com/albums/y10...p/DSC03392.jpg
http://i3.photobucket.com/albums/y10...p/DSC03390.jpg
http://i3.photobucket.com/albums/y10...p/DSC03398.jpg
Lift Hybrid setup consisting of 4" teraflex coils IRO front Adjustable Long arms Including Upper coil retainers KOR A-Arm spacer JKS trac-bar with KOR duro-Meter bushings IRO Swaybar links. RE mono Tube Shocks.
Tires 265/75/16 ON Stock timberlines with spidertrax 1.25 5x5 Spacers
Trimmed front plastic bumper to fit. Stock bumpstops.Soild D35 Diff cover
theksmith 08-16-2010 01:11 AM
http://lh3.ggpht.com/_xkFrXZhchqE/TG...0/P1090425.JPG
http://lh4.ggpht.com/_xkFrXZhchqE/TG...0/P1090428.JPG
http://lh3.ggpht.com/_xkFrXZhchqE/TG...0/P1050883.JPG
Current Specs (8/2010):
  • 2003 WJ 4.7 H.O. Limited - Brilliant Black Crystal Pearl
  • Eagle Alloy Series 140 Black Wheels - 17"x8", 5 on 5, +2 mm offset, 4.517" BS, 29 lbs each
  • BFGoodrich Mud-Terrain T/A KM2 Tires - LT285/70R17 (~ 33" x 11.5")
  • Clayton Offroad 6" Hard Arm Lift
  • ~5" IRO Bump Stop Extension Front & Rear
  • JKS Track-bar, Drag-link, TieRod, Sway-bar Disconnects & Super-Nerfs
  • Clayton ZJ Belly Skid
  • Custom Radiator Support Skid
  • Relocated Steering Stabilizer to Drag-link
  • Removed Rear Sway-bar
  • Front Fenders trimmed to body line
  • Removed Front Bumper
  • Rear Fenders trimmed and rolled
  • Rear Bumper trimmed
  • Factory Dana 30 with ARB Locker
  • Factory Dana 44HD with Aussie Locker
  • 242HD T-case with Tom Woods SYE (and locally done heavy duty driveshafts)
  • Magnaflow High-flow 3" Cat, Flowmaster 50 Delta Flow muffler, 3" Mandrel-bent Turn-down
  • Custom Rack based on Rola with Shovel/Axe/Hi-Lift Mounts
  • Debadged
  • Custom CB and HAM Antenna Mounts
  • Towhooks in front, Receiver-mount Shackle in rear
  • Ebay Headlights and Taillights (OEM tails in last pic still)
  • Upgraded Headlight Harness
  • Grille Guy Front Grill Insert
  • Dual Battery (almost)
  • Dual Compressor On-Board-Air
  • Misc Interior Mods
Build Thread: http://www.jeepforum.com/forum/f197/...4-7-ho-526660/
Atlas92 08-16-2010 10:00 AM
http://i981.photobucket.com/albums/a...as92/025-2.jpg
http://i981.photobucket.com/albums/a...s92/005-12.jpg
http://i981.photobucket.com/albums/a...as92/016-4.jpg
6" Short Arm Hybrid Lift: 4" RC Coils, 2" Rusty's BB, RC Adj. Front Lower CAs, IRO Adj. Front Upper CAs, IRO Adj. Trackbar, RC Front Swawbar Discos, 4" Front Ext. Bumpstops, IRO Fixed Rear Lower CAs, RC A-arm Spacer, 5" rear bumpstops, 12" travel Bilstein 5125s.
35x13.50R20 Mickey Thompson Baja ATZs on 20x8.5 MB Offroad Gunner 5's w/ 4"BS
Front and rear bumber trimmed a lot, front and rear fenders trimmed and rolled, windshield washer fluid bottle relocation, rear swaybar removed.
Apollo21 08-16-2010 11:01 AM
288 Attachment(s)
Apollo21's 02 Overland
Attachment 141665
Attachment 141666
Note: Not Discoed
Attachment 141667
Discoed
Attachment 156099
Zone 4in Kit(minus Tcase drop), KOR 3/4 front spacers, 1.5in wheel spacers x4, KOR single SS, Rear Addco Sway Bar, IRO upper front adjustable CAs, IRO coil spring retainers, RC quick discos
17in Stock Hammerhead rims with 265/70R17 Treadwright MTRs/Guard Dogs (actually measure 32.25in)
Trimmed a small amount (around an inch) off the underside of the front plastic bumper.
Build Thread in Sig
WJ04 08-16-2010 06:43 PM
WJ04's: IRO 4.25'' CP LA lift, 31'' Destination MT's, 16X7 soft 8's with 4'' BS, cut in half front bumper, Full specs in sig.
http://i238.photobucket.com/albums/f...4/100_7915.jpg
http://i238.photobucket.com/albums/f.../Photo0056.jpg
http://i878.photobucket.com/albums/a...100_9754-1.jpg
tsconver 08-17-2010 05:00 PM
My 03 WJ
http://i257.photobucket.com/albums/h...p/DSCN0075.jpg
http://i257.photobucket.com/albums/h...p/DSCN0078.jpg
http://i257.photobucket.com/albums/h...9/DSCN0009.jpg
Iron Dana 44 Rear
http://i257.photobucket.com/albums/h...DSCN0015-2.jpg
video of me this Oct 2010
<embed src="http://p.webshots.com/flash/smallplayer.swf?videoFile=http://videoserve.webshots.com/video/31476/3021146190041494322XFTnLh_v_0.flv&audio=on&display ImagePreview=http://videothumb37.webshots.com/thumb/31476/3021146190041494322XFTnLhstill_002_0.jpg&videoPage Url=http://rides.webshots.com/video/3021146190041494322XFTnLh&autoPlay=false&shareLink =http://cards.webshots.com/ecard/personalize?photoId=3021146190041494322%26source=v " type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" quality="best" allowscriptaccess="always"></embed><br/><br/><a href="http://rides.webshots.com/video/3021146190041494322XFTnLh">Fall Fling 2010 024.avi</a>
IRO Long Arms Front and Adjustable Rear Lowers,
3in IRO Springs and 0.75" KOR Spacers,
JKS Quick Disco Front,
Addco Rear Sway Bar,
home made front bumpstop extensions,
MX-6 Shocks all four corners,
ARB Air lockers front and rear, w/ 4.10 gears
15x8 Cragar Soft 8s with Treadwright 31x10.5 MT Shoes for wheeling
17x8 American Racing Crush Rims and Wrangler Silent Armor shoes for street driving
GraKee99 08-19-2010 10:06 AM
Guess I will do my lower ones since no one else is.
http://i242.photobucket.com/albums/f...e/IMG_1023.jpg
http://i242.photobucket.com/albums/f...e/IMG_1158.jpg
http://i242.photobucket.com/albums/f...e/DSCN0057.jpg
2" BB, Skyjacker shocks, JKS track bar, JKS disconnects, OME SS
Tires - Stock 225/75/16 BFG All terrians
Wheels - Stock 16" Timberlines with 1.25" spacer
http://i242.photobucket.com/albums/f...PA240173-1.jpg
http://i242.photobucket.com/albums/f...e/DSCN0775.jpg
http://i242.photobucket.com/albums/f...DSCN0738-1.jpg
2.5" Rusty Springs, Skyjacker front shocks, rough country rear shocks, JKS track bar, JKS disconnects, OME SS
Trimmed lower corner of front bumper, 2.5" front bumpstop
HaViiK 08-19-2010 08:10 PM
http://i622.photobucket.com/albums/t...7/IMG_1085.jpg
http://i622.photobucket.com/albums/t...7/IMG_1091.jpg
http://i622.photobucket.com/albums/t...7/IMG_1169.jpg
Lift: Rough Country 4" X-Series, no T-Case drop.
Wheels: Cragar 15x8 Soft 8, 4" BS
Tires: BF Goodrich KM2 32x11.5x15
Trimmed about .5" of bumper, need to trim .5" off fender
RJDJWJ 08-24-2010 09:39 AM
http://i756.photobucket.com/albums/x...ycamera004.jpg
http://i756.photobucket.com/albums/x...ycamera005.jpg
http://i756.photobucket.com/albums/x...ycamera082.jpg
2001 WJ V8 Limited
Rustys 4.5 Advanced:
4.5" Front & Rear Coils
Rusty's Performance Shocks
Drop Pitman Arm
Front Adjustable Trac Bar
JKS Quicker Disconnects
Upper Control Arms
Adjustable Front Lower Control Arms
Rear Lower Control Arms
Rear 3 Link Spacer
Extended Rear Sway Bar Links
BFG 33" KM2'S
15x10 Allied Simulated Beadlocks
Np231
JCR sliders
AFe Intake
Magnaflow Cat
Flowmaster 40
Jks Bar Pin Eliminators
Jks Quicker discos
Front Spring Retainers(top and bottom)not in last pick
OME Dual SS
Iceland Offroad Bumper
Tail light Guards
Spidertrax spacers
Yakima Rack
Hellas
Midland CB
Laredo Headlights
Tinted Tail lights
Black Emblems
3.5" Homemade Front Bump Stops, Have rear 4" just haven't put on.
Trimmed front bumper up to top bend and trimmed front bumper to follow.
Trimmed rear even with back door and followed around tire.
-Shoey- 08-24-2010 10:21 AM
Guess I'm the short guy so far. :D
Used to have these on it, 255/75/17 BFG KM's on Moabs, with a Rustys 2.5" BB...don't do this.
Backing up and turning, no bueno. Again, don't do this.
http://i221.photobucket.com/albums/d...0/DSCN0733.jpg
http://i221.photobucket.com/albums/d...0/DSCN0734.jpg
http://i221.photobucket.com/albums/d...0/DSCN0735.jpg
http://i221.photobucket.com/albums/d...ro40/159-1.jpg
http://i221.photobucket.com/albums/d...jiro40/158.jpg
http://i221.photobucket.com/albums/d...jiro40/160.jpg
She had 265/70/17 BFG AT's on before that, rubbed just a smidge here and there.
http://i221.photobucket.com/albums/d...jiro40/019.jpg
http://i221.photobucket.com/albums/d...jiro40/015.jpg
http://i221.photobucket.com/albums/d...newbies071.jpg
MANUBI 08-24-2010 10:37 AM
1 Attachment(s)
2" BB lift
31" tires
15" american racing rims cause im tired of seeing every wj with cragars on em.
all for about $300. thanks to cl and ebay:D
The time now is 07:25 PM.
