WJ Overland not running well ideas - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ Overland not running well ideas
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 04-29-2010, 05:41 AM   #1
ozscout
My Overland whilst on holidays recently after great performance failed to start first go as usual, when it did start it missed and appeared to run on way less than 8 cylinders. Dealer has checked and replaced #2 injector that was not working, vehicle still will not run properly. They checked the wiring harness and believe it is ok. Now believe the ECU is faulty and are trying to source a new or remanufactured one. Does anyone in the US sell remanufactured ECU's or where is the best to buy a new one. Maybe there is an after market unit that will suit the HO engine? Thanks Trev
ozscout is offline   Reply With Quote
Unread 04-29-2010, 05:46 AM   #2
kentman
2006 XK Commander
I would extract the codes at a minimum. I assume that you were getting a P0302. Any other ones? If one injector was bad, it is entirely credible that others were bad too. I did three on the WJ a couple years ago.
I would check out eBay and car-part.com for used or re-manufactured parts.
Kent
'06 XK Limited, 5.7L Hemi, Quadra-Drive II, Black, 107K Miles
'02 WJ Overland, 4.7L HO, Quadra-Drive, Inferno Red, 92K Miles
kentman is offline   Reply With Quote
Unread 04-29-2010, 09:49 AM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
A bad PCM is not very common.
Has the dealer tried swapping the #2 coil pack yet?
The coil packs are interchangable amongst the cylinders, so they can be easily swapped. Then if the misfire follows the coil pack, you know you have a bad one.
Wheelin98TJ is offline   Reply With Quote
Unread 04-29-2010, 10:24 AM   #4
trailblaze
i'm cringing at the fact your having the dealer do the work....$$$$$$$$$$$
Matt
trailblaze is offline   Reply With Quote
Unread 04-29-2010, 02:43 PM   #5
ozscout
As I understand it the coil pack does not control the injector that is not firing fuel into the cylinder.
Unread 04-29-2010, 02:48 PM   #6
WJeff
There are some good places that will recondition the ECU. Goggle it.
Just for a good horror story. Check compression. My 4.7 started to idle badly and run on 7 cylinders. It did finally generate a check engine code P0308 - misfire on cyl 8. Long story short $1200 to replace a sticking exhaust valve.
WJeff
01 GC Ltd 4.7L
WJeff is offline   Reply With Quote
