WJ noob looking for some tech info - Page 2 - JeepForum.com
post #16 of 34 Old 07-16-2013, 01:11 PM Thread Starter
Empty_Pockets
There are a few on craigslist, or I can rebuild it.
1998 Cherokee 2 door 2.5L 5 speed
2000 Cherokee Sport 4.5in lift 33's (Sold)
1998 Cherokee Sport ORF bumper, Warn vr12, 6.5in long arm ended up netting 8-9in :( (SOLD)
Empty_Pockets is offline
post #17 of 34 Old 07-16-2013, 01:21 PM
Double E
Double E's Avatar
Oh yeah... it's an HO. (Have we seen the HO drop valve seats yet?)
I'm curious to see pics of "drop valves" or whatever it did...
Be sure to price the engine & parts before you pull the trigger on this. I think you may be in the 3.5 - 4K range just for the rotating assembly before shipping. http://www.powertrainproducts.net/JE...FYZ4cAodwhQAuA
and
http://www.ebay.com/itm/02-04-4-7-HO...-/150436353246
It might be north of 5K after it gets to your door.
You have to get the HO to keep wiring the same. There are some differences that do not let you change to non-HO.
Hope the price is a grand or less...and you are really good with a wrench because as I understand it, this thing is a bear to change engines on.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #18 of 34 Old 07-16-2013, 01:28 PM Thread Starter
Empty_Pockets
I already did a 4.0 in a wj and even that was a bear compared to an xj. A 4.0 in an xj takes me 5 hours, it took me 14 in the wj. Im good with a wrench. There are some long blocks on CL for 1200 but Im not sure if they are H.O. I wolnt know whats up until I actually get it home and open it up. Worse come to worse Ill 5.3 swap it like I planned originally, I would rather spend the money on doing that if it ends up being that expensive.
http://www.ebay.com/itm/ws/eBayISAPI...ectorid=229466
Something like that doesnt seem bad tho, I can do everything but the machine work to the block.
post #19 of 34 Old 07-16-2013, 01:55 PM
Jeeples
Jeeples's Avatar
In all honesty a 5.3 swap would cost you just about as much as a rebuilt 4.7 HO, or more.
There is not nearly the options available for plug and play engine management for Chrysler engines as there is for GM. You would probably need to go with something like a MegaSquirt. Of course that still leaves the issue of transmission management, since the 545RFE is electronically controlled. Chances are it would be easier just to toss in a 4L60E as there are several standalone controllers to choose from, but they leave much to be desired when compared to the 4L80E.
Assuming you can get the drivetrain to play nice, you still need to worry about safety systems such as ABS and the airbags, especially since you're going need to be able (presumably) annual safety inspection.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #20 of 34 Old 07-16-2013, 02:01 PM Thread Starter
Empty_Pockets
I think that rebuild kit is going to be the best bet if it needs a bottom end. Im trying to pick this thing up for $800.
post #21 of 34 Old 07-16-2013, 02:08 PM
Jeeples
Jeeples's Avatar
Yep, as long as the heads are salvageable, then just have those milled and rebuilt. HO heads are a bit hard to find and pretty pricey when they're available, so hopefully yours aren't cracked.
Jeeples is offline
post #22 of 34 Old 07-16-2013, 02:15 PM Thread Starter
Empty_Pockets
So everything has to stay H.O. Nothing non H.O. will fit this thing, correct?
post #23 of 34 Old 07-16-2013, 02:25 PM
Jeeples
Jeeples's Avatar
Pretty much. All similarities between the two end at the bare block. Rotating assembly, pistons, cylinder heads, valves, cams, and up until '03 (IIRC) the intake manifolds are all HO specific. The HO underhood wiring harness also has provisions for two knock sensors, unlike the non-HO harness. This means the PCM is HO specific as well.
Jeeples is offline
post #24 of 34 Old 07-16-2013, 02:39 PM Thread Starter
Empty_Pockets
Found a complete 4.7 H.O. at the junkyard in town for $1800...
post #25 of 34 Old 07-16-2013, 03:07 PM
brouwmat
Might as well look into a reman for that money..
brouwmat is offline
post #26 of 34 Old 07-16-2013, 05:11 PM
Jer-Bear
I wouldn't drop a Chevy into it. You'll have to weld on new motor mounts, redo all the wiring, new transmission, maybe even a new rear axle... Not worth it to me lol
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #27 of 34 Old 07-16-2013, 06:13 PM Thread Starter
Empty_Pockets
Didnt get it, he had the head off. Head was bad, piston was all types of beat up. Looked really clean in pics but it was beat up and wheeled. Interior was beat, bumpers cut for bigger tires. Couldnt test anything electronic because it was all appart. Didnt want to take the risk on it.
post #28 of 34 Old 07-16-2013, 06:43 PM
99WJ539918
Good call. Sucks to hear, though. I went looking at a WJ in North Jersey that I was told was a 4.7L and it was not (4.0L). Not running I was trying to get it for $400, but he couldn't sell it that low. He reposted it for $900 after it was up for $1,500. Point is, WJ's are always out there with blown engines or transmissions. You'll find another one. Good luck.
Build Thread
99WJ539918 is offline
post #29 of 34 Old 07-16-2013, 07:44 PM
Double E
Double E's Avatar
Yep ....we were all giggling at the idea of the 5.3 going into the WJ. That would be signing up for a nightmare.
Good for you in leaving that one alone.
Find a 2003 Laredo with the 4.7 & Selec-trac, leather & tow package with 100-150K miles on it. Should be 3000 or less. Check for rust issues too & snatch it up when u find it. Look in Tennessee, KS or a non-salt use area.
Double E is offline
post #30 of 34 Old 07-16-2013, 08:10 PM
99WJ539918
As luck would have it, I was just on Craigslist and I found an '02 Limited with a blown 4.7L and 245,000 miles. Guy said it was run hot and now has no compression. He listed it for $850 and one phone call later he said he'd take $650. New front driveshaft, some front differential parts, transmission has 50,000 on a rebuild, fully loaded (even has RB1, and I think tow package). I might pick it up and part it out. I'm looking at it tomorrow sometime to check for body damage and rust underneath. I'll let you know how it looks Empty Pockets, if you're interested.
Build Thread
