WJ Manual Transmission Swap - JeepForum.com
post #1 of 9 Old 03-15-2016, 12:27 PM Thread Starter
txmjpunisher
Has anyone performed a manual trans swap on a 4.0 WJ w/ a 42re trans and a 242 case? Even just a parts list would be good!
txmjpunisher is offline
post #2 of 9 Old 03-18-2016, 09:29 PM
ATutt
There is a build thread somewhere in here where someone did this. Search..
ATutt is offline
post #3 of 9 Old 03-21-2016, 11:49 AM
MuddyWJ
AgitatatedPancakes is his name.
MuddyWJ is offline
post #4 of 9 Old 03-21-2016, 11:59 AM Thread Starter
txmjpunisher
Agitated Pancakes did the swap with a 4.7 WJ, I have a 4.0. I'm sure I can follow some of his setup like pedals and the like. I've been doing some digging and I think Im going to go with a NV3550 and use flywheel out the same year XJ. If they have the same distributorless Ignition then I shouldn't have any issues with the Crank Sensor/Timing etc.
post #5 of 9 Old 03-21-2016, 03:46 PM
86cj74.2L
86cj74.2L's Avatar
A manual Trans out of a Cherokee or any jeep with the 4.0. The Asin trannys from a Cherokee are good. If I had a WJ with the 4.0 I'd much rather have a AW4 than a 42re.
86cj74.2L is offline
post #6 of 9 Old 03-21-2016, 06:09 PM
99WJ539918
I thought about taking an engine and trans from a late TJ. It never went farther than just a thought, but it would be a fun project. I'm interested if you can actually get it done. Good luck!
Build Thread
99WJ539918 is offline
post #7 of 9 Old 03-25-2016, 11:22 AM Thread Starter
txmjpunisher
Is the WJ block different on the tail end than a TJ or XJ? If so im screwed...
post #8 of 9 Old 03-26-2016, 01:18 PM
99WJ539918
'01 - '06 TJ blocks are the same as WJ blocks. The early TJ's and all XJ's use a different block.
Build Thread
post #9 of 9 Old 03-26-2016, 03:34 PM
eljeepwj
2003 WJ
I did a pretty good amount of research on this and there don't seem to be too many documented cases of it happening on a 4.0 wj. I found 3 people who have done it just on the jeep forum and the most documented was this one http://www.jeepforum.com/forum/f310/...-swap-1418297/
I plan on also using an AX-15 if I can get one for a good price including pedals. I don't plan on this for a while though. If you end up doing it good luck and make a write up please
2003 Jeep WJ 4.0 2in IRO w Procomp Es9000 on d windows 245/75/r16 DD/weekend runner
eljeepwj is offline
