Is a WJ Lug Centric or Hub Centric? - JeepForum.com
post #1 of 5 Old 03-07-2013, 09:56 AM Thread Starter
D0dgeRam1500
Wj Is a WJ Lug Centric or Hub Centric?
Is a WJ lug centric or hub centric? I have Pro Comp Series 98 Rock Crawler wheels on my WJ with the Xtreme Steel Wheel Center Cap Kit. I was told that they aren't fitting right and that I might need hub centric rings. I want to make sure that the WJ is hub centric before spending money on the rings. If it is hub centric then which hub centric rings do I need for my WJ?
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #2 of 5 Old 03-07-2013, 10:33 AM
StrokedWJ
StrokedWJ's Avatar
WJ is hub centric. I think almost all steel wheels are lug centric, and there are a lot of people running lug centric steelies on WJ's.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 5 Old 03-07-2013, 11:23 AM Thread Starter
D0dgeRam1500
Is that why the lugs are tapered?
post #4 of 5 Old 03-07-2013, 12:10 PM
StrokedWJ
StrokedWJ's Avatar
Yes, the tapered lugs will help seat and center the wheel. Its not as perfect as being hub-centric, but it works well enough. FYI, from some quick googling it looks like most alloy wheels are manufactured hub centric and steel wheels lug centric.
post #5 of 5 Old 03-07-2013, 08:23 PM
berndog67
2003 WJ
what he said! its because softer metals deform easily, so they are hub centric, and steel being more dense and less prone to deforming get lug centric, but with spacers most would recommend hub centric regardless of wheel type, that way u can decrease the chance of unwanted vibrations in your wheels and drivetrain
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
centric , hub , lug , wheels , wj
