Wj long arm help? - JeepForum.com
post #1 of 58 Old 09-28-2010, 12:05 PM Thread Starter
jrberry13
Wj long arm help?
Hi i need some help guys....I took my jeep to a auto shop and they said i needed new rods as they called it, but i think they are long arms but not sure since i'm new to lifted jeeps. I will post a pic of it below . I need help on buying new long arms as cheap as possible or is there new bearings i can buy for them???? My jeep is a 99 wj 4.7 with i think 3-5 in lift not sure though since i bought it lifted.
any help will greatly appreciated!!
jrberry13 is offline
post #2 of 58 Old 09-28-2010, 12:48 PM
KDog223
I'm sure he meant the Rod Ends need replacing but with that much rust you might want to replace the whole arm at this point.
KDog223 is offline
post #3 of 58 Old 09-28-2010, 01:49 PM Thread Starter
jrberry13
So are those called control arms or long arms......also would you reccomend a brand to buy?
i also got another question....I need a rear drive shaft too, but i dont know what to get since my jeep has had a 2wd/4wd transfer case installed....i dont know if i should just get a stock 4x4 all-time drive shaft or another? im little confused.
post #4 of 58 Old 09-28-2010, 03:17 PM
85IrocZ-28
Your picture shows the lower control arm. It could be a short arm (mounts at the factory location on the body) or a long arm (the factory body side mount is cut off, and a new one is welded on allowing a longer control arm).
If it is lifted 3-5 inches, you really could have short arms. Take another pic that shows the mounting point on the body. That will allow us to see if these are long arms or short arms. If the arms are solid stock, you can just wire wheel them, apply some new paint, and re-build the joints. I think your joints are different from the heim shown above, but I could be wrong. Post a picture of the joints. With all the rust, It is very likely that your joints need to be rebuilt or replaced.
In regards to the rear driveshaft, what is wrong with yours? Is it bent or out of balance, does it need new U-joints...
Rather than buying a new one (very expensive), it is usually better to find a used one at a salvage yard or have a local driveshaft shop build one. I don't know if the driveshafts are the same length on grands with the 247 or the 242, maybe someone else will.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- Project Yeti Build Thread
85IrocZ-28 is offline
post #5 of 58 Old 09-28-2010, 03:46 PM
Apollo21
those look like the old Teraflex LAs, you could get replacements from many places like IRO or Ironman4x4
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread http://www.jeepforum.com/forum/f22/a...thread-902929/ SOLD
Apollo21 is offline
post #6 of 58 Old 09-28-2010, 03:57 PM
KDog223
Yep, I just grabbed a picture off of Google to show the OP what they generally look like.
KDog223 is offline
post #7 of 58 Old 09-28-2010, 05:42 PM Thread Starter
jrberry13
Alright guys i will get some more pics tomorrow.....the guy told me i needed i a new drive shaft and uv joints....?
post #8 of 58 Old 09-29-2010, 09:33 AM Thread Starter
jrberry13
here are some more pics one is the ones on the back, i measured the front one to be around 31 in if that helps i also can take a video and post it to youtube if needed. Can you buy new bushings for them because they are solid, not rusted throught but the bushing are just wore out bad to where you can move them.
post #9 of 58 Old 09-29-2010, 10:29 AM
sinbad85
That has to be one of the biggest draw backs of living back east(ohio) is that rust!!! Looking at the pic's you have no bushings left, how was your DW? I think I would buy some new upper and lower arms,
2001 WJ 4.7L-selec-trac/4.5" Teraflex springs\IRO Long arms\Iro adj rear LCA/Bilstien 5100 series shocks/ IRO steering Equalizer/|265/75/16 Goodyear Dura-Tracs on Stock rims\Rear Tube Bumper with carrier|sliders|mopar skids.
sinbad85 is offline
post #10 of 58 Old 09-29-2010, 10:40 AM
drwolcot
yes the driveshafts are different lengths depending on transfer cases and engines.
I am so glad I don't have to deal with all that rust... that looks awful!
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
WJ 2WD-->4WD Conversion Build Thread
2003 WJ Overland - SOLD
drwolcot is offline
post #11 of 58 Old 09-29-2010, 11:37 AM
85IrocZ-28
Those joints look rebuildable. It looks like you can spin the two outer peices off, replace the bushings, and re-assemble. I would soak the joints in something to remove the rust before doing that though.
Could those be Rock Krawler long arms? I don't know what all of the kits out there look like, but those look like or are very similar to RK joints.
post #12 of 58 Old 09-29-2010, 03:00 PM Thread Starter
jrberry13
So i should just buy new arms all the way around(what brand shoould i buy and do i buy just any adjustable control arms or does it have to long or short?) or is there bushing i can get. Also what do mean rebuild the joint? sorry im still new to all this stuff?
post #13 of 58 Old 09-29-2010, 04:24 PM
85IrocZ-28
I wouldn't buy new control arms unless the rust has penetrated to the point where it has weakend them and they are unsafe.
If those are RK arms, they are solid stock. Just sand the rust off and re-paint. If they are the RK arms, here is what the joint looks like on the inside:
From the center out on each side on RK joints: The pivoting ball, a poly bushing, a thin metal washer like ring, the outer ring the screws into the joint housing.
On some of the RK kits the spacer is attached to the ball, on other kits the spacer is separate and will fall out when you remove the bolt. The joints pictured have spacers that are not part of the pivoting ball in the middle. The rest on each side of the ball and are held in place by the bolt through the joint. They fall out when I remove the bolts. You just use a pair of vice grips to twist the joint ends off and access all the interal parts of the joint.
Even if they are not RK arms and joints, they are probably something similar. Even if you decide you don't want to rebuild them, you should be able to buy whole new joints that screw into the arm and replace what you currently have. Even if you wanted to buy a different style of joint, you could. Just make sure to measure from the center of the eye on each end of the arm. After you install a new joint on each end, you want to make sure that the arm is the same length (unless you want to adjust the arms, pinion angle, or alignment.
post #14 of 58 Old 09-29-2010, 06:21 PM Thread Starter
jrberry13
can you tell me how to rebuilt the joints? like step buy step.. do i need to buy anything?i went out earlier and wire wheel sand the arms and it was just some surface rust. also could you take a pic of underneath ur jeep so i can see what its suppose to look like?
post #15 of 58 Old 09-29-2010, 09:05 PM
StrokedWJ
StrokedWJ's Avatar
They look like Rock Krawler's Krawler joint to me too. If you can unscrew/remove the current rod ends it'd be easiest to just buy new ones and screw them into the arms. Rock Krawler Catalog
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
How long do the steering stablizers last gdp WJ Grand Cherokee Forum 12 10-24-2010 03:21 PM
Long Island Help chester9189 WJ Grand Cherokee Forum 4 09-05-2010 09:01 AM
Worst Day In a LONG Time.... :( SplitNail WJ Grand Cherokee Forum 34 07-23-2010 04:40 PM
Rustys long arms for wj kathan21 WJ Grand Cherokee Forum 13 05-27-2010 04:56 PM
Long arming my WJ finally hopefully Clayton00grand WJ Grand Cherokee Forum 2 02-02-2009 08:52 AM
