Wj with lean bank1&2 codes low fuel pressure - JeepForum.com
post #1 of 7 Old 09-06-2013, 06:01 PM Thread Starter
stonecol000
Wj Wj with lean bank1&2 codes low fuel pressure
Ok I have 04 Grand Cherokee 4.7 V8 Limited four-wheel-drive just hit 100k About a week ago I had a problem It through two codes 0171 0174 Bank one and bank to lean I had been having starting issues a couple days prior to the codes being thrown It will start according to the fuel pressure regulator gauge I put on it I have around 20 pounds of pressure When I shut it off it drops instantly I am able to drive it at half to three quarters throttle But when I stomp on it It goes to about 3000 RPMs and sits there it does not climb in speed or rpm's At least that I know I don't want to sit there at wide-open and it's not doing anything You can hear it sucking in the air She is not putting out the power though I have blown out all my Fuel lines replaced the fuel pump And the fuel filter I'm at a total loss on what to do. I need help this is all I have to get around thank you
stonecol000 is offline
post #2 of 7 Old 09-07-2013, 01:36 PM Thread Starter
stonecol000
Hey y'all please start giving me ideas I am a disabled marine living off disability I can't afford to throw parts at it this month because of the fuel pump I just bought I can barley afford to live without this jeep I can't get a job please help
post #3 of 7 Old 09-07-2013, 06:17 PM
rm2001wj
rm2001wj's Avatar
It sure sounds to me like either the replacement pump is faulty or the replacement pressure regulator/filter is faulty. Did you buy new parts and/or have any difficulty replacing those parts?
rm2001wj is offline
post #4 of 7 Old 09-08-2013, 08:33 AM Thread Starter
stonecol000
The pump is good the fuel filter regulator were easy to put in with no hiccups this is the second pump I took the first one back to napa because I thought it was faulty and they swaped it out for a new one no questions asked
post #5 of 7 Old 09-08-2013, 09:45 AM
rm2001wj
rm2001wj's Avatar
The fact that the fuel pressure drops to zero instantly indicates probable bad check valves in both the regulator/filter and fuel pump. The attachment, copied from the 04 FSM, justifies that conclusion.
Unless the pressure measurements are really inaccurate, I have to think that the regulator and pump are probably bad, or they were not the correct parts to begin with, or they were not installed correctly. There are ways to check them out individually, but IMO a visit to a professional who has the correct equipment may be a necessary expense for the needed accurate diagnostic help. Good luck!
rm2001wj is offline
post #6 of 7 Old 09-08-2013, 07:07 PM Thread Starter
stonecol000
Ok so I put a new Regulator filter in it and it solved the problem it was only 2 months old... Thank u for ur help
post #7 of 7 Old 09-08-2013, 09:40 PM
rm2001wj
rm2001wj's Avatar
Glad to hear you fixed it.
rm2001wj is offline
