WJ leaking fuel from injector rail - Page 2 - JeepForum.com
post #16 of 34 Old 05-01-2010, 04:50 PM
u.p.jeeper
Thanks for the reply.
u.p.jeeper is offline
post #17 of 34 Old 07-12-2010, 08:34 PM
PIP932
The fuel pressure damper isn't supposed to be replaced individually. The manual for my '04 states that the fuel line isn't repairable. From all the reading I have done, I have come to conclude that the best method to solve a leaking Pressure Damper issue is to replace the whole rail. Mine is leaking right now as well, I am going to take it in to the mechanic shop since I was going there anyway. I just hope the leaking doesn't get worst when I drive. No fires related to this kind of leak right?
PIP932 is offline
post #18 of 34 Old 08-07-2010, 07:37 AM
CTJeepWJ
2010 JK Wrangler
I am getting leaking in the exact same spot and I am also just shy of 90K...it must be something that Jeep set up to fail at 90K haha. Here are my pictures which arent much better...
Has everyone come to the conclusion that the only fix is to replace the entire fuel rail?
What is the actual name of this piece that is leaking? Also is this a dealership only piece?
-Ed
BLACK JEEP SOCIETY
2010 JK & 2004 WJ
CTJeepWJ is offline
post #19 of 34 Old 08-09-2010, 12:03 PM
CTJeepWJ
2010 JK Wrangler
Bump
Anyone have pricing or part number on the fuel rail?
-Ed
BLACK JEEP SOCIETY
2010 JK & 2004 WJ
CTJeepWJ is offline
post #20 of 34 Old 08-09-2010, 06:03 PM
vvreddy
Originally Posted by CTJeepWJ View Post
Bump
$154.10 at moparonlineparts - part # 55014496AC.
No affiliation, just where I buy parts.
vvreddy is offline
post #21 of 34 Old 08-10-2010, 06:50 AM
CTJeepWJ
2010 JK Wrangler
Thanks for the info. How hard is the install? I have never worked on this part of the fuel system, is this something that can be done with general knowledge and tools? Any pictures or write up would be a big help. Thank you.
-Ed
CTJeepWJ is offline
post #22 of 34 Old 08-10-2010, 08:01 AM
xJoshxx
2012 WK
Pm Kolak on here Or Kolak@aol.com He can probably beat that price
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #23 of 34 Old 01-17-2013, 09:24 PM
colt45210
2002 XJ Cherokee
fuel raillll
Originally Posted by quikturbo View Post
I ended up just buying a new fuel rail and that regulator is mounted already. After i took the old one off I inspected and while you may be able replace the o-rings under the top cap I wasn't confident it would seal up again. The rail was just under 200 if I recall.
Good luck.
Chris
Where did you find the fuel rail for that price?
everything ive seen has $245 or so?
colt45210 is offline
post #24 of 34 Old 01-17-2013, 10:35 PM
cykaaro
Ouch. Pulled one from a wreckers that still has the black paint on and no rust at all to replace my rusty one for $10. Would try a wreckers first if you have near you and can get a good one cheap. Ones I deal with give a 90day warranty as standard if there's any problems with the part.
No tips for how to replace although you need the special tool to properly remove the line from the rail. Haven't done mine as of yet as I'm a bit leary of doing damage to the injectors and/or 0-rings. Have never had to deal with the fuel rail before other than testing it's getting fuel.
cykaaro is offline
post #25 of 34 Old 02-14-2013, 03:02 PM
stingray66
ok Here is the part # I replaced my o ring in my damper and all is good
go to any GOOD parts store there is a o ring kit made by standard Part # SK 14
made for the fuel damper cost me a buck today
It is totally NUTS to spend 2 to 300 bucks for a new fuel rail for a buck item
I will tell you it is best to remove the fuel rail to replace the o ring
took me a 30 mims to do
and don't believe tho B/s that you can not service the fuel rail
its really not that hard
stingray66 is offline
post #26 of 34 Old 04-22-2013, 01:22 PM
johngreenedc
Just did the fuel injectors and replaced the o-ring in the fuel dampener. Carefully pried back the tabs, and then replaced the o-ring (which was blue and hard and discolored on one side). I used the borg warner equivalent for the Standard sk-14 part, which is 2 o-rings for a whopping $1.59. Car fired up 1st try and is dry aat all of the injectors and the fuel dampener. I talked to a Jeep dealer mechanic who said the reason they (dealer) said the part is not repairable is due to liability problems. He said he would probably do exactly what I was going to do. I figure replacing the injectors (rebuilt 4 hole bosch from rockauto for $98) and fixing the fuel rail (about two hours total time) I saved $1200. Also replace my wife's O2 sensor ($25) for an additional $150 savings. Not bad for a Sunday afternoon.
johngreenedc is offline
post #27 of 34 Old 04-23-2013, 11:59 AM
johngreenedc
Spoke too soon. Need help
First day the fuel dampener ws dry. Today it is leaking. Any ideas?
The o-ring appeared correct compared to the original and the part seems secure on the rail. I'm stumped
post #28 of 34 Old 06-15-2013, 04:53 PM
Rae228
I have a 99' grand cherokee laredo. 170k miles. Having the same problem and completely nerve racked! We took all 6 injectors off, had them rebuilt. Put them back on, jeep still wouldn't start, just cranks. So we took the damper off thinking we could go buy the part, but I can't find it anywhere not even online! So now we put it back on but fuel is pouring out when we crank the jeep. Please someone help.. Where can I buy this part? What's the part #? Thank you.
Rae228 is offline
post #29 of 34 Old 06-15-2013, 05:02 PM
pinky2252s
Come on, did you even read the thread?
The part itself is only available connected to a new fuel rail. But as seen in this thread, some have had success with replacing the O ring on the dampener.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #30 of 34 Old 10-07-2014, 06:11 PM
mellis1968
when you removed the damper where did the O-rings slip on (the rail or was there a stem on the damper) or some sort of rib for the O-rings cause I have the same problem. I would appreciate a reply please mellis1968@comcast.net
mellis1968 is offline
Help fuel leak on fuel rail 2002 4.0 jzhawk ZJ Grand Cherokee Forum 2 11-17-2009 12:56 PM
4.0 possible fuel injector problem or fuel sending unit metroman ZJ Grand Cherokee Forum 2 08-15-2009 02:37 PM
Fuel rail dirtdogg ZJ Grand Cherokee Forum 1 11-21-2008 10:53 AM
Leaking fuel injector grand cherokee sooty521 ZJ Grand Cherokee Forum 4 02-11-2008 12:42 AM
Fuel Rail DEGRANDCHEROKEE ZJ Grand Cherokee Forum 8 03-19-2006 07:41 AM
