WJ leaking fuel from injector rail - JeepForum.com
post #1 of 34 Old 06-15-2009, 10:47 PM Thread Starter
darinr
Just wondering if anyone could help me figure out what to call this part, it's leaking fuel off the fuel injector rail. I wasn't able to find it in the service manual and the dealer had no idea what I was talking about, but was more than eager to sell me a new rail . I can twist it and it seems to be loose like it once was pressure fitted. Any insight is much appreciated.
thanks,
-darinr
darinr is offline
post #2 of 34 Old 06-15-2009, 10:51 PM
MEinSoCal
no click....
MEinSoCal is offline
post #3 of 34 Old 06-15-2009, 10:57 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Too small of a picture to see whats going on.
The fuel line IS pressure fitted to the rail.
You're supposed to be able to just push it on with your hand, and since I assume you've tried that, maybe you need a new line or something.
If it turns out you need a rail or something I have used WJ parts for sale.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #4 of 34 Old 06-15-2009, 10:59 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
New o-rings on the injector(s).
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 34 Old 06-15-2009, 11:05 PM
Bojeepus
can't realy tell from the picture but isnt that the fuel presure regulator
Bojeepus is offline
post #6 of 34 Old 06-15-2009, 11:12 PM
MEinSoCal
can o-rings be bought from auto parts stores separately?
post #7 of 34 Old 06-15-2009, 11:19 PM Thread Starter
darinr
I'm new to the forum and still trying to figure out how to embed images but in the meantime here are a couple different angles.
http://lh3.ggpht.com/_7BjSzK0MuWY/Sj...s800/IMG_3.jpg
http://lh6.ggpht.com/_7BjSzK0MuWY/Sj...s800/IMG_2.jpg
It's not one of the injectors, may be a regulator or pressure valve of some sort.
darinr is offline
post #8 of 34 Old 06-15-2009, 11:23 PM
xJoshxx
2012 WK
you think you can get closer? so far all your pictures have been far away hard to see anything. and your a new user u dont have 50 tech post's yet.
ALSO make your pictures with the [img ] [/ img] tags so we can no clicky them
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #9 of 34 Old 06-16-2009, 06:28 AM
Marcos
The pressure regulator is in the pump assembly int he tank. That's probably a fuel pressure dampener. It looks like it should be a separate piece, but I didn't see it listed separately on the parts websites, so it may only be available as part of a fuel rail assembly.
Marcos is offline
post #10 of 34 Old 06-16-2009, 10:06 AM Thread Starter
darinr
Thanks a bunch everyone for all your input! Turns out it is the fuel pressure damper, #8 on diagram below.
Darin
darinr is offline
post #11 of 34 Old 11-17-2009, 12:29 PM
WJJIM02
WJ Fuel Rail Damper Leak
What was the fix for this problem? My 02 WJ 4.0 seems to be developing the same leak at 90K.
WJJIM02 is offline
post #12 of 34 Old 11-19-2009, 06:34 PM
quikturbo
Same here I started smelling fuel while outside vents were on. Thought it was the injector o-rings as I felt some fuel by the number 4 inj, so I replaced all of the o-rings. Turns out it was trickling down to the #4 injector from the fuel pulse dampener in the above.
Nobody shows this as a part, so is it safe to assume it's sold along with a new rail assembly? It looks to have metal tabs holding it on a ridge, I've thought about trying to pop it off and see if I could replace an o-ring there.
Like WJJIM02, any suggestions on fixes?
2002 4.0 JGC
1968 Mustang Convertible (Resto Project)
quikturbo is offline
post #13 of 34 Old 11-19-2009, 07:28 PM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
looks like some kind of pressure relief valve maybe? where are you located? in washington? what part, if i see it in person i could probably (maybe) figure it out?
oops, i should probably read the thread first. dangit.
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #14 of 34 Old 05-01-2010, 05:24 AM
u.p.jeeper
Has anyone ever figured out how to fix this my daughters 02 is leaking in the same spot.
u.p.jeeper is offline
post #15 of 34 Old 05-01-2010, 06:35 AM
quikturbo
I ended up just buying a new fuel rail and that regulator is mounted already. After i took the old one off I inspected and while you may be able replace the o-rings under the top cap I wasn't confident it would seal up again. The rail was just under 200 if I recall.
Good luck.
Chris
2002 4.0 JGC
Help fuel leak on fuel rail 2002 4.0 jzhawk ZJ Grand Cherokee Forum 2 11-17-2009 12:56 PM
4.0 possible fuel injector problem or fuel sending unit metroman ZJ Grand Cherokee Forum 2 08-15-2009 02:37 PM
Fuel rail dirtdogg ZJ Grand Cherokee Forum 1 11-21-2008 10:53 AM
Leaking fuel injector grand cherokee sooty521 ZJ Grand Cherokee Forum 4 02-11-2008 12:42 AM
Fuel Rail DEGRANDCHEROKEE ZJ Grand Cherokee Forum 8 03-19-2006 07:41 AM
