WJ Grand Compression Readings - JeepForum.com
post #1 of 2 Old 05-07-2012, 01:42 AM Thread Starter
derekmines
Hi all.
Have just had a potential GC purchase evaluated by my local garage and as part of this they did a compression test.
The car's a 2004 Overland with the 4.7 HO engine with 75k miles approx
all cylinders reported 170 apart from number 4 which reported 145
test was done with engine thoroughly warmed.
What does this mean, am I looking at a new motor, a full top end rebuild or is it fine to leave as-is for a while?
derekmines is offline
post #2 of 2 Old 05-07-2012, 03:32 AM
slick1474
Unless your getting this for a give away price I wouldn't take on a car with uneven compression like that, some work, being valves, or worse rings/bore work could be needed....
slick1474 is offline
Ac static pressure readings jackz WJ Grand Cherokee Forum 2 07-26-2011 09:46 PM
Reliable readings from VIC? howieb4 WJ Grand Cherokee Forum 7 01-13-2011 04:49 PM
Overhead MPG readings Maxxram WJ Grand Cherokee Forum 9 11-13-2010 12:33 PM
2002 WJ, 4.0 TPS readings davets WJ Grand Cherokee Forum 0 05-18-2010 12:03 AM
Got some crazy OBD II readings steelstr45 WJ Grand Cherokee Forum 40 04-08-2010 06:34 PM
