WJ - GC 4.7L Ltd - Will only start when cold - Hot engine will take ages to start. - JeepForum.com
post #1 of 2 Old 04-22-2010, 07:54 AM Thread Starter
JMcLane
Hey guys.
I recently had issues over in this thread.. http://www.jeepforum.com/forum/f13/n...roblem-977062/ .
Initially it was bad at starting and running badly but I have changed quite a few things now and seem to have rectified something..
I have changed in the last 4 weeks...
Battery (optima Red Top, as above post).
Crank Position Sensor.
Coil Pack on the front of engine (front of car) 2 cylinders. (changed on April 20th 2010)
New Spark Plugs.
Serviced.
Now the Jeep runs fantastically on cold startup and when it is running under any hot/cold start conditions. The issue is that it is really hard to start once the engine is running hot.
First thing in the morning since I have changed the 2 coil packs it is about a 2 second start routine and just purr's with no help from feathering the throttle. Perfection.
Where do you think I should be looking to make some progress folks?
Thanks.
JMcLane is offline
post #2 of 2 Old 07-08-2010, 11:15 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Sounds like a fuel pump. WJs were very bad and losing fuel pressure due to the orings in the pump. You can confirm this by priming the system by turning the key to run a few times, then cranking. If it fires right up then you found the problem. Mine had the same issue.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
hard to start when cold liredneck ZJ Grand Cherokee Forum 1 02-12-2009 04:13 AM
cold start problems Mair ZJ Grand Cherokee Forum 2 01-29-2009 09:41 PM
99 4.0 Bad Cold Start windsors03cobra ZJ Grand Cherokee Forum 0 11-08-2008 06:10 PM
annoying noise from engine after cold start Fatsooo ZJ Grand Cherokee Forum 3 09-03-2008 12:59 PM
Hot Start Problem.... Cold Start Injector??? Mase ZJ Grand Cherokee Forum 3 02-03-2003 09:33 PM
